  1. May 19, 2025 at 7:41 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    I think it's in the fine print that they will leak lol. My rears started within the first year of installing. Got the stuff to rebuild just need to find a decent video on how to. Just disappointed that it happened so soon for what they cost
    FirstGenVol and oscardog86 like this.
  2. May 19, 2025 at 8:07 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    What model of Billies are you coming from? I cant help but think id prefer kings or some other progressive shock like ADS possibly. Ive only had stock or Bilstein 5100 and now 6112. Both digressive. I would really like something smoother over washboard roads and such and have an itch to try kings up front. Also not sure what id run in the rear since king doesnt make rear shocks for our trucks. Maybe progressive in the front and digressive 5160s in the rear? I dont know just thinking out loud. I should probably give king a call and see what they think.
    455h0le_dachshund likes this.
  3. May 19, 2025 at 8:36 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    I bought new leaf packs and an AAL. I don't carry weight in the bed so I don't need increased capacity. The AAL was just for lift and more flex.
  4. May 19, 2025 at 8:38 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    I think ADS is digressive as well. @memario1214 was saying to go with 6112s, Alumas, or ADS for crawling. I could be wrong and mis-remembering.
  5. May 19, 2025 at 9:38 AM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    2" spacer level 285/70/17 Falken Wildpeaks
    Getting ready to order Bilstein 5100's with 2884 springs and new mounts from 1stgenoffroad ($1072.10 after tax)....are there any coupon codes or better deals out there?
    MooreKen and oscardog86 like this.
  6. May 19, 2025 at 9:41 AM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    Honestly, that sounds about right, or a great deal if Josh is going to pre-assemble. Typically the 5100s run $650-750, the 288x springs run around $250, and assembly around $125.
    You may be able to wait until Memorial Day next Monday and score a deal, but ... Josh is a reputable vendor, you may not get the same with someone else.
    455h0le_dachshund and Filthyphil like this.
  7. May 19, 2025 at 9:45 AM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    Thanks for the input. Pairing that with the blue sumo springs in the rear so I can load her down and not sag, new ubolts. Pulling the cv's after memorial weekend to reboot them as they have been torn a while. Got the Porsche boots inner and OEM outer (I have new OEM inner if anybody wants to make an offer). Any advice on boot clamps OEM style vs SS worm style clamp?
  8. May 19, 2025 at 9:47 AM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    Glad to have one side almost done. Had to buy a whole bedside to fix the driver's side but haven't torn into it yet haha
  9. May 19, 2025 at 9:49 AM
    If you go OEM, you'll need a proper tool to work with the Oetiker clamps. It may take 2-3 attempts to actually get it tight enough to hold with the newer, steeper angles. Sling has continued to be a problem for some folks.
    If you go with the SS worm drive, choose a brand with rolled edge like NORMA, all you need is a ratchet or a screwdriver to install and get as tight as needed. @ToyotaDude dropped the numbers for clamp sizes over here. The smaller 25-40 is clearly for the inner clamps. 70-90 and 90-110 will be for the respective outer/larger clamps. You should be able to throw eyes on the CVs and figure out how many you need of each.
  10. May 19, 2025 at 9:49 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    ADS is progressive.
    @FirstGenVol ADS and King are great and those would be my recommendations. The only other name I would throw out there is Radflo. I haven't tried them yet, but have heard good things and their customer service is good. A little less expensive than ADS. I have nothing bad to say about ADS.
    I know they come with a 700# spring which I wish I had tried a 650 because the ride was a little too firm for a while, but no complaints at all.
  11. May 19, 2025 at 9:52 AM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    Worm drive it is then. Is it true that there needs to be 2 clamps per side to balance or will one clamp per side be a non issue?
  12. May 19, 2025 at 9:56 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I opted for the ear style clamps just because I was nervous about the worm sticking up and spinning and being susceptible to catching debris or hitting something at an odd angle. That thought is not based on anything and is probably not at all likely. But, I found this site that offers clamps in different sizes.
    https://hcl-clamping.com/?srsltid=AfmBOopj0r3t9spWydTNKEFgNx9joC3TBizM5VZDr6lRT78CZzLNqBuH
    I would definitely suggest getting an oem style clamp tool if you don't go worm drive, and an earless clamp tool if using the oem clamps.
    shifty`[QUOTED] likes this.
  13. May 19, 2025 at 9:58 AM
    @FrenchToasty is who (I think?) originally recommended to use the worm drive to me, and I think he said he's running one per?
  14. May 19, 2025 at 10:02 AM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    I also read somewhere putting the worm drive on the outer boot could cause rubbing/contact....anyone experience this?
  15. May 19, 2025 at 2:00 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Idk about after the Holley merger, but before that ADS customer service was literally unmatched.
  16. May 19, 2025 at 2:16 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Yep just one per each side of the boot
    They definitely come close but no contact at full droop
  17. May 19, 2025 at 2:27 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I had no idea about that. Good to know. Looks like that took place after I bought them.
    khooiii[QUOTED] likes this.
  18. May 19, 2025 at 4:11 PM
    @Dakillacore @FrenchToasty
    Apparently 50k miles of dirt road driving not only left a bajillion fine scratches on the windshield, but also packed the blower motor fan. Here's a little before/after, couldn't even see light thru the blades they were so caked.
    DKC, you had smoker tar. I had silt dust. But not anymore.
    Oh, and I found absolutely nothing in here, so I assume it was a pine needle and it's already moved along into the evap core housing.
  19. May 19, 2025 at 4:14 PM
    PS, some bonus shots looking up to the cowl from the motor opening. I wiped it out with a terrycloth shop towel because it had a fine haze of dust cake on the walls too.
  20. May 19, 2025 at 4:15 PM
    FrenchToasty
    Mo
    Bone stock
    I should probably pull and clean mine. And also I had putting/sand blasted windshield as well until I got it replaced
  21. May 19, 2025 at 4:20 PM
    Factory glass, I really don't want to replace mine. I've always heard about cerium oxide, and was inspired by everyones favorite "OHMAH GAHD ITS NAHT A GAAAARRRLLLL" YT celeb make some great progress with it. I'm tempted. To polish my windshiled, I mean.
  22. May 19, 2025 at 4:23 PM
    Pulled the seat belts out and closed the door on them for the power wash and silicone treatment.
  23. May 19, 2025 at 4:24 PM
    Small split at the seam on the drivers seat. Creeping ever closer to a leather replacement
  24. May 19, 2025 at 4:30 PM
    For some reason I thought you'd swapped out your steering wheel.
  25. May 19, 2025 at 5:02 PM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    So the only number I could find on the clamps on my CV's now say 80. So I just need 2 of the 70-90, 2 of the 90-110, and 2 of the 25-40, per side? @ToyotaDude @Shifty
  26. May 19, 2025 at 5:21 PM
    Jack McCarthy
    Jack McCarthy My work anxiety is my morning alarm clock
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    How often would you have to condition the leather seats to keep it from cracking over time, or is that impossilble?
  27. May 19, 2025 at 5:33 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Depends on if it actual leather or soflex which is what maybe in there which is coated in plastic. No need to condition that..
    https://blog.mccarthytoyotaofsedalia.com/2021/05/21/toyota-softex-vs-leather-whats-the-difference/#:~:text=Leather: What's the Difference?,-May 21, 2021&text=First things first: Let's answer,in the making of SofTex.
  28. May 19, 2025 at 6:00 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    I don't know if this helps but this is from a. New OEM cv
  29. May 19, 2025 at 6:38 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    With all the dusty dirt roads I drive, I can't imagine how mine looks...I've only had the Tundra just over a year but my old Tacoma had 20+ years of arid western dirt roads under its belt.
  30. May 19, 2025 at 6:48 PM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    It blows my mind how many people have issues with Icons leaking. I remember at one point in time the big 3 shocks were fox, icon, and king. Shoot now I'd recommend bilsteins over icon... especially with them dipping their toes into the remote resis these past couple years. But ya with the price they cost, it doesn't seem right at all
    Not sure if you could do it for our tundras, BUT on the 1st gen tacomas you could take the rear stock shocks off a raptor, which were fox with resis, and make them fit with a little modification. I'm curious if the tundra could do the same. Had a friend do that and they rode fantastically!
    What about Fox?
    oscardog86[QUOTED] likes this.
