  1. May 2, 2025 at 6:27 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Pretty cool gadgets he has. Unfortunately it broke off at an angle with just a bit out of the hole so won’t be able to use what he used.
    It’s in there tight too. Haven’t been able to get it to budge at all grabbing the extruded portion.
    Jack McCarthy and Hutcheson like this.
  2. May 2, 2025 at 8:06 PM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    What rack is that?
  3. May 3, 2025 at 6:15 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Got all the AZ washed off. Next bath will be in 2026.
  4. May 3, 2025 at 7:35 AM
    taranovich92
    taranovich92 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Nitto TerraGrappler G3 285/70/17, Apple CarPlay, CB radio, Randy Ellis Design front bar, Hella 500 rally lights, Mini LED projector headlights, Trailrunner Customs fogs, SkidRow Offroad skid plate, 333 Fab steering rack clamp.
    SkidRow Offroad skid plate, Trailrunner Customs LED fogs, new CB radio.
  5. May 3, 2025 at 7:40 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    look at that purple shine!
  6. May 3, 2025 at 7:42 AM
    How you liking the Eibachs? Probably my next set of shocks.
    Filthyphil likes this.
  7. May 3, 2025 at 7:46 AM
    taranovich92
    I like them a lot, mine are set one notch off the lowest setting, ride quality is pretty good.
  8. May 3, 2025 at 7:52 AM
    Using the Eibach springs as well? How much front lift did you get?
  9. May 3, 2025 at 8:01 AM
    taranovich92
    Yes Eibach springs and struts, I got 3" of lift on the second notch from the bottom.
    Filthyphil and G_unit3000 like this.
  10. May 3, 2025 at 8:40 AM
    shifty` Dead heads and frog legs. Mmm... cake mix!
    Mine had same. In fact, anytime anything black, rubbery, or greasy would rub against it, it would leave a pencil-like mark. That's because the paint is oxidized, and that porous layer of oxidation will hold onto any contaminants introduced to the body panel.
    Wax won't do anything to fix it, but once you take a mild polish to it, in my case Meguair's Ultimate Polish, with any corrective sponge, it'll gently slough off that oxidation layer, and there won't be anything to stick to anymore.
    Is that the rope you were using for your steering wheel wrap?
    Bought2Pull[QUOTED] likes this.
  11. May 3, 2025 at 8:48 AM
    Voss
    2003 AC TRD 4x4
    Making my own
    bmf4069 and Sirfive like this.
  12. May 3, 2025 at 9:47 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I just put billies and OME coils on my Tacoma last night and the ride is night and day very happy with them.
  13. May 3, 2025 at 11:22 AM
    Those look like billies
  14. May 3, 2025 at 11:23 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    driver side front caliper is wearing uneven. Kinda want some reman powdercoated calipers. Anyone happy with slotted rotors? They’re not warped, just the driver side is wearing uneven, and it probably a sticky caliper. Newwish master cylinder, no trouble with the booster, just a c-clamp in/out while troubleshooting the mc. These brakes are adequate for me. & i’d prefer to keep 16” wheels, since i expect to use 32” tires.
    why so expensive?!?
    455h0le_dachshund likes this.
  15. May 3, 2025 at 11:25 AM
    Yeah, it’s paracord
    shifty`[QUOTED] likes this.
  16. May 3, 2025 at 12:09 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I had stop tech slotted rotors on my last truck and really liked them. The ones I currently have are still pretty new but once I need to replace them I’ll probably go to slotted stop tech again.
    From what I remember the drilled are more prone to warp and there isn’t much point in slotted and drilled.
    FrenchToasty and Sirfive[QUOTED] like this.
  17. May 3, 2025 at 12:15 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I dont panic brake, so i’d imagine they wont warp, but some of these hills are steep, and i dont wanna scrape dust onto my wheels. In fact, i glaze my pads a bit to make the power brakes a bit more linear to the pedal.
  18. May 3, 2025 at 12:26 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Doesn't need to be a panic brake. I've warped at least two (older pair) when doing a mountain pass (without any added weight) and happen to catch a puddle from snow melt.
  19. May 3, 2025 at 12:40 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    2001 Tundra SR5 Access Cab TRD 4.7
    Replaced the fuel filler neck today. A PITA, one stud at the bottom was busted so had to drill it out and put a bolt in it's place. Forgot to take pics. :facepalm:
  20. May 3, 2025 at 1:06 PM
    Filthyphil
    Phil
    Jesus Christ lol that’s what I get for multitasking.
  21. May 3, 2025 at 2:52 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I put 2883s and OME Nitrocharger shocks on the front of my Tacoma and never liked the ride. Uncomfortably stiff at first, and never got any less stiff. Now that I've got 2883s with Bilsteins on my Tundra and really like the ride, and hearing that you like the ride on your Tacoma with the same setup, it's really confirming that it was the Nitrochargers that caused the harsh ride, not the coils.
  22. May 3, 2025 at 3:45 PM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    2006 Tundra DC Limited
    Threw on the FLF gusset spindles the other day. GX brake conversion and Wilwood manual valve/LSPV delete. Also installed a rear SS brakeline and front extended lines. Deleted the hardline as the fronts came with the banjo bolt conversion.
    Slight but definitely noticeable brake feel improvement.....dramatic increase in brake performance. Valve adjusted...Slightly nose dip but confident stopping now.
    Found the reason for my front end chunks and vibes....garbage steering rack is shot. Leaking and bushings. Ordered the rebuilt OEM one with poly bushings from FLF.
    Sidenote: factory spindles will be blasted and powder coated, then listed for sale. All parts will be included.....Koyo bearings, seals and hubs have 15k miles on them. Spacer and tone rings are OEM. The below pic are the FLF spindles...not the ones that will be sold...lol.
    Been a bit busy chasing turkeys and redoing the entire trailer 12v.
    Listing these in the Marketplace section. Trail Gear / Wheelers front brake lines.
  23. May 3, 2025 at 4:38 PM
    Filthyphil
    Phil
    Yeah there was a lot of conflicting information out there when I was trying to figure out my setup. I ended up calling Wheelers and just talking to their tech and he was super knowledgeable and told me the 881’s on my Tacoma would be fantastic for what I use the truck for and he was right.
    Also told me wheelers bought out OME and is remaking all their stuff under their own name.
    oscardog86 likes this.
  24. May 3, 2025 at 5:02 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If you stay long enough at Casey's house, with a dirty truck, it might get washed. It's majick
  25. May 3, 2025 at 5:05 PM
    MT-Tundra
    Montana
    Whoah. Crazy. Well I noticed OME doesn't (currently) make a front shock for 1st gen Tundras anyway, so it wasn't an option for me. Even though OME says not to use any other type of shock with their coils.
    Filthyphil[QUOTED] likes this.
  26. May 3, 2025 at 5:15 PM
    Filthyphil
    Phil
    Yeah the nitro chargers are now made by wheelers but they have a different name for them.
  27. May 3, 2025 at 5:56 PM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    1st oil change done since purchase, also replaced the engine air filter, and got a new battery today. Getting a new oem rack and pinion + outer tie rods put in Tuesday.
    PO made a bizarre choice with a group 34 size battery. It was so small in the tray that they had to stuff some type of cardboard under the hold down rail. So glad that trash ain't under the hood anymore...My '02 has the larger battery tray so I upgraded to a 27f flooded Ultra Gold Duracell--wasn't too many 27f locally available so I went with this (3 year warranty).
    Voss, oscardog86, bmf4069 and 3 others like this.
  28. May 3, 2025 at 6:09 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    OK, that is motivating, thank you.
    What did I do today with the Tundra? I drove it around, looking at some new potential mowing locales. All owned by a real estate company. It's easy-to-see why they are having problems getting people to mow. Most I am not interested in but a couple look decent.
    I haven't pulled anything with the Tundra in several days.
    Yesterday I learned I can unlock the driver's side rear door by making two turns to the right with the key on the driver's front door. Only one turn unlocks the passenger side rear door from the passenger side front door lock. Odd.
    MooreKen and Dakillacore like this.
  29. May 3, 2025 at 6:20 PM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    This is a trick on all Toyotas.
    1 turn to the right = driver door unlocked.
    2 turns to the right = all doors unlocked.
  30. May 3, 2025 at 6:23 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    OldGuy03, Kalannar97, bmf4069 and 2 others like this.
