  1. Apr 11, 2025 at 12:32 AM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Huntington Beach, CA
    00’ 4.7 AC 4x4
    Flex tape works pretty well for small leaks on single rack commercial dishwashers...
    Might have worked really well on a certain someone's miata soft top too...
    shifty` and 455h0le_dachshund like this.
  2. Apr 11, 2025 at 12:57 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My stubby antenna works fine when I've tested it but I rarely listen to the radio. Who does that?
  3. Apr 11, 2025 at 2:01 AM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    Right? The only time I listen to the radio is when I don't have my phone for some reason.
  4. Apr 11, 2025 at 4:47 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    What were you going for?
  5. Apr 11, 2025 at 6:11 AM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    A stubby was installed on my truck by the PO and I still have never used the radio or tested it out, hah. I have no idea how well it works or even if it works at all.
    oscardog86 likes this.
  6. Apr 11, 2025 at 6:24 AM
    notlikejohnny
    notlikejohnny New Member
    Shenandoah Valley, VA
    2005 4WD DC Limited, Phantom Grey
    Wife thinks I'm super weird just sitting in silence if I'm not listening to a podcast when driving. I told her this is how I figure out how good or bad the truck is running.
  7. Apr 11, 2025 at 6:48 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    My bed is just a bit rusty along the bottom edge. Super easy to fix since you never really see it, but make sure it's not jagged before you try to lift the bed up with your hands! Depending on the type, I might be interested in that tonneau cover.
  8. Apr 11, 2025 at 7:24 AM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    I finally won the battle with the front diff plug, I almost lost hope but I pushed on and persevered. I also flushed the power steering fluid following the step by step thread, worked perfectly and seems to be quieter now.
  9. Apr 11, 2025 at 7:45 AM
  10. Apr 11, 2025 at 8:04 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    airflow vs light.
    my foam ‘curtains’ arent quite tall enough. I can leave em be, and block maximum light, i can trim the bubblewrap, and add feet to the foam to raise it enough to let light in the bottom, or i can combine the 2 and have an ambidextrous foam wall that’ll fit either side & i can eat my cake, and have it, too.
    if i trim the corner off my big table i can get it to block one side.
  11. Apr 11, 2025 at 8:10 AM
    Better be careful, @455h0le_dachshund is gonna think it's a coffin, and you'll never be able to get him out of the back of your truck again.
    455h0le_dachshund likes this.
  12. Apr 11, 2025 at 8:13 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Polo’s the one i’m worried about. When he gets in there, he wont get out. Wont even get out if i start the truck, gotta put it in gear and roll.
  13. Apr 11, 2025 at 8:19 AM
    That's a good pup, wants to go everywhere with you. He knows that's his rolling house, you're just the bus driver.
  14. Apr 11, 2025 at 8:24 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Its definitely his truck. Stands on the center console watching for deer. Like i said, no panic stops.
    Tripleconpanna likes this.
  15. Apr 11, 2025 at 8:30 AM
    I can picture the nose prints on the inside of the windshield already.
    oscardog86 and Tripleconpanna like this.
  16. Apr 11, 2025 at 8:34 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I cant get a pic, but he scratched the shit oughtta my drivers side tint when he was a baby. Luckily, it was a phase.
    has anyone with sliding cap windows found a way to reach the latch from the back? I’d like to be able to pull a string with one hand while sliding the window forward with the other. Guess i need to glue a pivot or something to the latch.
  17. Apr 11, 2025 at 9:08 AM
    notlikejohnny
    @Sirfive I've never thought about that, and i'd be worried I would snap the clips trying to yank on it with something rigged up that way. They seem pretty weak and would snap without much effort.
    Sirfive likes this.
  18. Apr 11, 2025 at 9:16 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    :anonymous:
    shifty` and BroHon like this.
  19. Apr 11, 2025 at 9:21 AM
    You could defeat the latch. Mine has enough friction holding it in place that the latch is mostly unnecessary to keep rhe window closed. Then you could slide it open from inside the bed.
  20. Apr 11, 2025 at 9:24 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, i usually only close it to before the latch, but after 4 hrs its open .5-1”. If i’m on dusty gravel roads it wants to open about 4”.
    oscardog86 and notlikejohnny like this.
  21. Apr 11, 2025 at 10:42 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I dont feel real heat on the cardboard or the direct sun bubblewrap. Only on the aluminum window frame.
  22. Apr 11, 2025 at 10:47 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  23. Apr 11, 2025 at 10:50 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    How much to use that machine to set my own alignment? Before or After hours? I’ll bring my own tools.
    Tripleconpanna and Jack McCarthy like this.
  24. Apr 11, 2025 at 11:10 AM
    Jack McCarthy
    Bill
    North of Boston
    Don’t you want your caster over 2.0?
  25. Apr 11, 2025 at 11:25 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    I have no choice but to until I get a new stereo installed, i could always dust off my CD case and shuffle through the pages trying to find something to listen to like back in high-school days. I do listen to local sports radio when driving sometimes as well
    Filthyphil likes this.
  26. Apr 11, 2025 at 11:28 AM
    Dblock500
    DMV
    Those led strips with the strut switch would really come in handy
  27. Apr 11, 2025 at 11:35 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    hat lights & glove lights. Put a red filter on em, and you wont need em as much.
  28. Apr 11, 2025 at 11:47 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    For what point and purpose?
  29. Apr 11, 2025 at 12:08 PM
    If he's happy with how it tracks on the open road, and he's not rubbing, I'd stick with the numbers shown, but that's just me.
  30. Apr 11, 2025 at 2:07 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
