  1. May 14, 2019 at 12:57 PM
    #6841
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Did you check for play in the inner tie rods as well? I think that is where my problem is coming from.
  2. May 14, 2019 at 1:01 PM
    #6842
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I haven't yet. I wasn't sure if you could really pinpoint the issue until you remove the outer tie rods. How would you know which one is causing the issue? The inner tie rods are $175 each so I was going to start with the cheap and easy outer's first and go from there.
  3. May 14, 2019 at 2:03 PM
    #6843
    NMTundra
    NMTundra New Member
    Has to be a really long Phillips. At the rig or I'd take pictures but you should see 2 guide shafts on top of the head light assembly to stick a screwdriver in, one for up/down and one for right/left.
  4. May 14, 2019 at 2:07 PM
    #6844
    Outbound
    Aaron
    Northern Alberta
    Do we have a consensus yet on the best LED bulbs? I have headlight housinslgs in my rockauto cart. Either this monh or next i'll pull the trigge and i want to try LED bulbs.
    Auxbeam, Beamtech and Sealight at the ones I'm looking at.
  5. May 14, 2019 at 2:13 PM
    #6845
    Professional Hand Model
    Hand Protectors
    Not sure. Follow Festers FSM. I looked and my OE assys. have the screw driver adjust. Stoked on this as its so much easier than the way I was doing before.
  6. May 14, 2019 at 2:21 PM
    #6846
    Alltimehigh
    Alltimehigh New Member
    Had a leak where the transmission and the driveshaft meet. So yesterday I decided to finally take off the driveshaft and replace the extension housing seal. Everything went smooth for the most part.
    Unfortunately, after driving around today I came home and saw the leak again.
    I noticed it looks like its actually coming from the yoke. So I did some research and it sounds like this is actually a common problem with the yoke leaking through a hole. Some people had the hole welded shut to fix their leaks. Anyone ever have this issue? Anyone know what the easiest and cheapest way to plug this would be?
  7. May 14, 2019 at 2:37 PM
    #6847
    Hand Protectors
    Katanas are very nice for $50. Bright Pure White light, but not blinding if that makes sense. The cut off is perfect. Bulb has the cup on it like the OE halogen so the trajectory is spot on. 2 year warranty.
    High Beams will blind for sure, but they rarely get used unless needed for a flash or when other vehicles are not around. A non-issue.
    They have cooling fans and are so quiet they can’t be heard. I have to check with my hand if they are blowing. OEM running lights were half dim from lowbeam and these Katanas run the DTR power at the same as lowbeam. This is the only difference in performance I can see which is another non-issue. Some LEDs do not have the capability to run the DTR per reviewers (an issue for me).
    I have no other LED to compare these Katanas, but can say I’m amazed.
    The PerfectFit Fogs are truly amazing, as well. They fill in the void with about 220° of wrap around light off the front bumper plane on the 2002 lenses. My favorite light source by the way. $129. Fanless.
    Both mentioned LEDs are plug and play. No funky weirdness on sound system, need for resistors, or rewiring etc.
  8. May 14, 2019 at 2:46 PM
    #6848
    Hand Protectors
    I’ve read (if I remember correctly but do not hold me to this) that after this same repair you performed that the leak will slowly seal itself up over time with driving. Its common for it to leak right after then it stops. Doesn’t make sense, but this is what I read. Assuming you used the proper parts and technique.
    Jerry311SD likes this.
  9. May 14, 2019 at 3:33 PM
    #6849
    Hand Protectors
    How are you obtaining your price quotes?
    I just punched in Cool Springs Toy via Toy.com and searched a price for an oil filter YZZD-3 type OEM for 1st Gen. and the price was like almost $6.
    Toypartsdeal is $3.81.
  10. May 14, 2019 at 3:53 PM
    #6850
    NMTundra
    NMTundra New Member
    As Hand Model said, we've had really good luck with the Katanas. The 2nd and 3rd Gen guys swear by the Auxbeam lights in their reflectors, probably can't go wrong with either.
    Outbound[QUOTED] likes this.
  11. May 14, 2019 at 4:34 PM
    #6851
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I first use Toyota Parts Deal to identify the correct part#(they have my vin saved so I don't have to worry about compatibility). From there I put the same part # in at cool springs. Every item I've checked so far has been a few bucks less. Cool Springs offers 20% off shipping for forum members. Also, the one time I ordered from TPD they were extremely slow to ship.
    I typically check eBay as well.
    For oil filters, eBay has the best prices I've seen once you consider the shipping is free.
    speedtre likes this.
  12. May 14, 2019 at 4:42 PM
    #6852
    Hand Protectors
    Link to the CoolSprings site you use?
  13. May 14, 2019 at 5:37 PM
    #6853
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  14. May 14, 2019 at 5:46 PM
    #6854
    Hand Protectors
  15. May 14, 2019 at 6:14 PM
    #6855
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The mirror was free from work. Warranty because the Bluetooth mic didn’t work. Yes it bolts up. You just have to wire the thing in.
    TX-TRD1stGEN likes this.
  16. May 14, 2019 at 7:38 PM
    #6856
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I guess I need to find a Camry in a junkyard or something
  17. May 14, 2019 at 7:40 PM
    #6857
    empty_lord
    05 rollover special
    eBay, just look for gentex mirror. It’s who makes them for all the manufacturers
  18. May 14, 2019 at 7:47 PM
    #6858
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Warranty aside, I wonder how those do (longevity) if one daily drives on dusty dirt roads...
  19. May 14, 2019 at 7:47 PM
    #6859
    Outbound
    Aaron
    Northern Alberta
    Thanks guys. Looks like the Katanas are $120+ on Amazon Canada and it doesn't look like they have the right ones for my truck.
    I may end up giving the Auxbeams a try.
    @Professional Hand Model, do you have a link to the Perfect Fit Fogs?
  20. May 14, 2019 at 9:26 PM
    #6860
    FlightSimGuy
    FlightSimGuy New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    Washed the ride and got an oil change. Also had them check the leak, it is from the 4x4 actuator. Also got a quote for a CV axle. $300.
    NUDRAT likes this.
  21. May 14, 2019 at 9:27 PM
    #6861
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
  22. May 14, 2019 at 9:29 PM
    #6862
    SoCalPaul
    Paul
    Is that a Toyota CV axle? Or is that aftermarket including installation?
    FlightSimGuy[QUOTED] likes this.
  23. May 14, 2019 at 9:30 PM
    #6863
    FlightSimGuy
    I'll have to ask as I don't remember. It's from Carquest and that includes install. Probably just gonna get a CVJReman and do it myself.
  24. May 14, 2019 at 9:32 PM
    #6864
    SoCalPaul
    Paul
    I paid $350 each for my Toyota CV axles. I installed them myself.
    FlightSimGuy likes this.
  25. May 14, 2019 at 9:36 PM
    #6865
    FlightSimGuy
    N
    Not surprised if they are Toyota. I want the higher angle ones.
  26. May 14, 2019 at 11:19 PM
    #6866
    empty_lord
    05 rollover special
    Any first gens running scs wheels? I may just be blind.
    I’m debating f5s in bronze with 285/75r16s when the trucks all done. (Eibach shocks are happening, so the front will be level with the rear)
    Also debating between cement grey or the new trd pro green. Hmm decisions. Body works coming sooner rather than later... got people lined up to remove my bed Sunday. The. It’s off for frame straightening (if it even needs it) before I do suspension work
    Darkness, Sunnier and FirstGenVol like this.
  27. May 15, 2019 at 3:55 AM
    #6867
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Casper421 has SCS wheels. I'll be ordering some soon as well.
    So does this guy. He's running 305/70/16s with OME suspension.
  28. May 15, 2019 at 3:57 AM
    #6868
    Hand Protectors
    Not sure. $50 is about what one would pay for regular incandescents. 2 years is a long time to figure out if the dust will effect the fans which are rated for water use. Either run them without washing occasionally or not. Return if necessary.
    NUDRAT[QUOTED] likes this.
  29. May 15, 2019 at 4:14 AM
    #6869
    Hand Protectors
    I double checked the link and these linked bulbs are not called ‘PerfectFit’ anymore. The picture looks the same. The described Philips Chip Tech is the same. All things look the same, but with a new name. Same price $129.
    https://headlightrevolution.com/gtr-lighting-csp-mini-led-headlights-9006-bulbs/
  30. May 15, 2019 at 4:15 AM
    #6870
    Casper421
    In the woods
    06 DC
