  1. Feb 2, 2025 at 6:45 PM
  2. Feb 3, 2025 at 12:49 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    238mi+5.2%=250.4mi
    13mpg
    Why is your truck getting the same MPG as my truck that weights like 500 extra pounds and has taller/wider tires than you?
    Want to buy mine? OEM new in box.
    I don't need em for the 06 because the uniballs will be going on soon.
    Can your 04 use the bigger LBJs?
    I don't think my 03 can use em, plus it had em done by Toyota like 30k miles ago. Basically right before I bought it.
    Edit: NVM you said UBJ.
  3. Feb 3, 2025 at 9:17 AM
    Yeah, I dunno, been asking myself the same thing for a long time now. The only thing that makes sense is "city driving". I always have at least 20% city driving. But even on the highway at steady speed, I've never been able to hit anything 17+. I think my best was 16.7mpg fully stock.
  4. Feb 3, 2025 at 9:37 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Realized today that I'm running my 265/75s at the same pressure as the stock 265/60s. Is this fine? They look fine and aren't wearing funky, but it's only been 5k miles.
  5. Feb 3, 2025 at 9:55 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    i’ve run between 30-45psi and my tires have been fine. Even did 1000miles at 65psi to see how the 6112’s handled it. No troubles.
    FiatRunner[QUOTED] and BroHon like this.
  6. Feb 3, 2025 at 10:21 AM
    FiatRunner
    Jack
    How did the 6112s do? I'll be buying a set sometime this spring.
    oscardog86 likes this.
  7. Feb 3, 2025 at 10:32 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    A little rougher than the 37f/35r i usually run, but it handles rough & gravel roads just fine. The biggest difference was removing the sway bar. Truck still powerslides predictably, but it took a few tries learning the lean to get it smooth. The 6112’s valving means speedbumps and traintracks are smoother if you go over em a little faster. But i have no complaints, theres enough weight in/on my truck that i handle crowned intersections or misaligned expansion joints better than most new vehicles. But before the 6112’s i thought my shocks were worn out because it was so smooth, i was just used to the stiffer stuff under the titan & the solid acle under the jeep xj.
  8. Feb 3, 2025 at 11:58 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Yup. Probably should check mine. I eyeball filled at a QT last time and it's been almost 2 months since I've even checked. :anonymous:
  9. Feb 3, 2025 at 12:12 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    I had the same issue; tapped mine and they thread in much more easily, but I also agree with above saying remove oil filter from engine bay/topside.
  10. Feb 3, 2025 at 1:05 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Just looping back around. I’m happy to report that my vibration is gone!
  11. Feb 3, 2025 at 1:07 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    soobaroo have a driveshaft balancing machine? I still want a longbed AC.
  12. Feb 3, 2025 at 1:08 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Nope. See pics where the old weight clearly was
  13. Feb 3, 2025 at 1:09 PM
    I need to go insect mine. Have a rumble around 38-45mph.
  14. Feb 3, 2025 at 1:11 PM
    FiatRunner
    Jack
    My cheap RockAuto driveshaft is fine below 80. Which is fine as I rarely go faster than 70 or 75, but once you get to 90+ it gets pretty bad.
    The Black Mamba likes this.
  15. Feb 3, 2025 at 3:04 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Want to go halvsies on a RC?
    You can get your ACLB and I can get a RCSS. We can drop in a carbed Chevy V8 and fuck shit up all over the hill country.
    We'll be the Dukes of Kendall You can have the bench seat. I'll take your buckets.
  16. Feb 3, 2025 at 5:09 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Looks like my airbag/seatbelt light no longer turns on when the seatbelt is detached. I know the light works since it lights up when I turn the key over. I’m not sure if Toyota is one of the few manufacturers where the airbag won’t deploy if the seatbelt thinks it’s disconnected.
    Should I be worried? :confused:
  17. Feb 3, 2025 at 5:48 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    More pics in my build thread.
  18. Feb 3, 2025 at 6:00 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Dale works fast
    oscardog86, bmf4069, BroHon and 2 others like this.
  19. Feb 4, 2025 at 4:06 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Leather bench seat......on a base model v6? That has to be a re-cover. I like the sellers description too. Very thorough.
  20. Feb 4, 2025 at 4:10 AM
    Believe that’s vinyl
    bmf4069[QUOTED] likes this.
  21. Feb 4, 2025 at 4:19 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    How do you know it's a v6?
    The V8 emblems could've fallen off :p
    But you're probably right. It doesn't even have a tach. Too bad it's an auto. I always thought it was so ghetto that my manual Ford Ranger had no factory tach. The PO installed a sweet back glowing tach with a shift light. It was sloooo fast and the furious. :rofl:
  22. Feb 4, 2025 at 4:41 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    My seatbelt latch "press" button stays pushed in when the seatbelt is un-latched causing the seatbelt light to stay off all the time. When I latch my seatbelt in there are no issues or anything so I just let it be. My airbag light comes on when I cycle key so all good there.
  23. Feb 4, 2025 at 5:09 AM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    My button stayed half stuck in.... I worked on it a while and was able to get the light to stick ON..... :facepalm: Unplugged the wire harness to it. Yet again another lesson learned to Not Fuck with shit that isn’t really broke.
  24. Feb 4, 2025 at 5:18 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Sure as shit is. I can see if now that I'm not half asleep sitting in the dark. It also has vinyl floors. I'd LOVE to have vinyl floors.
    No tach, vinyl seat and floors. Someone probably threw those patricks on there.
    KNABORES[QUOTED] likes this.
  25. Feb 4, 2025 at 6:57 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Sometimes I wish I had vinyl flooring. Would be nice to just sweep and wipe it out. I guess that's why I have weathertech mats
  26. Feb 4, 2025 at 8:17 AM
    Jack McCarthy
    Bill
    North of Boston
    It’d be available if our Tundra were sold with a police package. One thing I liked about the Chevy Tahoe back in the day.
    bmf4069 likes this.
  27. Feb 4, 2025 at 8:41 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yup. the Vic has vinyl floors. I think I remember seeing it for sale on RA. I may check that.
  28. Feb 4, 2025 at 8:45 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You CAN get vinyl floors. Hmmmm.....
  29. Feb 4, 2025 at 9:25 AM
    Jack McCarthy
    Bill
    North of Boston
    I’ll bet it isn’t cheap unless they already have a pattern for it.
  30. Feb 4, 2025 at 9:38 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It says $200. I may try it later.
    455h0le_dachshund likes this.
