  1. Jan 31, 2025 at 10:10 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
  2. Jan 31, 2025 at 10:17 AM
    The Black Mamba
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    You couldn't hear them over the rubber squeal anyway, lol
    455h0le_dachshund, bmf4069 and BroHon like this.
  3. Jan 31, 2025 at 10:25 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
  4. Jan 31, 2025 at 10:36 AM
    Careful with that. If you rub thru the mudflap, which you eventually will, there's a pinch weld on the other side of the very-thin inner fender liner.
    I made a thread on how to trim down the larger plastic flaps, here.
    But here's the thing. Your pinch weld is right behind the inner fender liner where circled. You see how shiny mine was? That was after, I dunno, maybe 3-4 weeks of running 285/70r17? A week later it busted through and the pinch weld started eating lines into my tires every time I backed out of the garage. You can apparently drop the mudflap, unbolt the inner fender liner, hammer or bend the pinch weld out of the way, re-secure the fender liner, then take a heat gun to re-mold it out of the way to a point it won't rub. But ... just be aware: It doesn't take long for this process to happen, especially if you remove the mudflap or modify it. Nobody wants to hafta replace a $275+ tire over some stupid shit like this. Fortunately, mine were used and the pictured tire was at ~50% tread.
    oscardog86 and FrenchToasty like this.
  5. Jan 31, 2025 at 10:37 AM
    No.7! That stuff is fucking awesome.
    FiatRunner[QUOTED] likes this.
  6. Jan 31, 2025 at 10:40 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Cleaned my MAF & throttlebody. I was gonna polish the air tube & airbox lid, but the protect-all didnt change the grey spots, so meh, but i had an idea. I cleaned my air filter, and what if i got a paper filter for the truck to learn on, then swapped to my lightly misted k&n? Think there’d be enough difference to make a difference?
    i can be the judge.
    cant find my k&n oil, my airfilter is gonna catch dust with olive oil this month.
  7. Jan 31, 2025 at 10:43 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Yeah, it ain’t cheap, but they work so much better than other products that you’re essentially buying in bulk.
    I wash my Fiat every week and the tundra every other week in the summer. I go through one bottle of soap and one bottle of wheel cleaner, total of $35. Still feels like you’re getting ripped off a little bit when you order 4 or 5 products and your total is over $100.
  8. Jan 31, 2025 at 11:02 AM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    2" spacer level 285/70/17 Falken Wildpeaks
    Thanks for the heads up, I'll keep an eye on it. eventually when the weather gets better I'll get in there and smooth things out.
  9. Jan 31, 2025 at 11:12 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    I did exactly this. Cut and hammered pinch weld behind the liner, reinstalled the liner and then used a heat gun to mold it down to the new shape. Barely if ever contact it now with my 33s
  10. Jan 31, 2025 at 11:27 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Warm water and soap on those sticky frank n beans will attract more ladies. Or so I've been told. Hasn't worked for me yet.
    bmf4069 and JakeJake[QUOTED] like this.
  11. Jan 31, 2025 at 11:30 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Those Ray10s look solid. did you go with -10 offset?
    KTM_AJ421[QUOTED] likes this.
  12. Jan 31, 2025 at 11:35 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Self clearancing tires. :D
    bmf4069 and FrenchToasty like this.
  13. Jan 31, 2025 at 11:59 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    Yes they are -10 fit perfect
    Filthyphil likes this.
  14. Jan 31, 2025 at 1:49 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
  15. Jan 31, 2025 at 4:21 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    My truck is lucky if it gets washed once a year.
  16. Jan 31, 2025 at 5:11 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Drove it to fill the tank before the tariffs spike the price. In@ $2.85/gal. :bananadance:
  17. Jan 31, 2025 at 6:23 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    @shifty` i think my tires are too small what were you saying about 275’s? Do they make any that aren’t load e?
  18. Jan 31, 2025 at 6:33 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah my trucks are the same and I couldn't tell you the last time soap was involved.
    But we were talking about our rusty nuts.
  19. Jan 31, 2025 at 6:59 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You still have OEM bumpstops??
    Plus 650lb coils on your big girl... Yikes
  20. Jan 31, 2025 at 7:10 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Not for long….
  21. Jan 31, 2025 at 7:25 PM
    DBombs
    DBombs I Like Old Trucks
    NE Atlanta
    2006 Tundra DC SR5 V8 4x4 TRD
    Removed the stupid spacer lift on the front end tonight. I hate them more now than before. I was thinking my struggles with getting the strut bolt out and the upper ball joint wanting to rub on the spring was because maybe the spacer changed some geometry. But after searching threads and reading a bit more, sounds like it’s a normal wrestle.
    Had I known, I would have waited to get the spacers out until I do all the other front end stuff. I’m a noob, and was thinking it would be an easy in/out to get rid of the spacer. The strut assemblies I’ve done on Hondas were simple like that.
    I ended up slightly damaging the CV boot clamp on my first go. Stupid mistake. (pic below). I’ll need to keep an eye on that axle.
    I ended up taking off the LBJ bolts and disconnecting the sway bar end link to get lots of movement. I’ve read other posts about a bottle jack at the UCA. A lot of wasted time in some sense, but I learned a lot of valuable lessons and really enjoyed it.
    My biggest struggle was getting pressure off the strut bolt. Other vehicles I’ve been able to easily manipulate with bottle jacks, but I must have been missing something because I could not manipulate it correctly. I read a lot of good threads AFTER I finished tonight. :notsure:
    Can you guys confirm that reversing the direction of the strut bolt is acceptable/preferred? I’m not convinced. Plenty of clearance? I’ll be doing it all again shortly when I start replacing components on the suspension. IMG_8252.jpg
  22. Jan 31, 2025 at 7:27 PM
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
  23. Jan 31, 2025 at 7:37 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Atta boy
  24. Feb 1, 2025 at 4:03 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Did the small ones I gave you fit your truck?
  25. Feb 1, 2025 at 4:19 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, had to swap in some longer bolts.
    455h0le_dachshund likes this.
  26. Feb 1, 2025 at 4:53 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I can't zoom in enough to see who makes it. It's a buffing compound? I need to try something for the hood on the RAV4. It has some haze in the paint I haven't been able to buff out. Not clear coat failure thankfully, just age.
    FiatRunner likes this.
  27. Feb 1, 2025 at 4:54 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I didn't know this.
  28. Feb 1, 2025 at 5:01 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Better upgrade those bumpstops if you haven't already
  29. Feb 1, 2025 at 7:15 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    oscardog86 likes this.
  30. Feb 1, 2025 at 8:11 AM
    I left my strut bolts in the original position without issue. To get an over length strut in or out, you need to unhook the sway bar and the LBJ bolts and use a prybar to get the LCA to flex further down than the bushings want to let it. You can loosen the LCA bolts, but that is easier said than done depending on rust condition. Also messes with the alignment, but you’ll need a new alignment anyway now. I was able to replace my struts without loosening the LCA bolts. However, if you’ve drastically changed the ride height in the front, the LCA bolts should be loosened and retourqed after the truck is back on the ground so the bushings are not in a bind. It would be minor, but probably prolongs the life of the bushings.
