  1. Jan 24, 2025 at 8:06 AM
    Head appears to thick to be a roofing nail. Probably a screw of some kind. We’ll find out when I get home.
  2. Jan 24, 2025 at 8:08 AM
    shifty` Inside his chest they found ten thousand pencils
    Ah, I think I see the plus, now you mention it.
    Fingers crossed it's only a little shorty ½" screw.
  3. Jan 24, 2025 at 8:42 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Ordered timing belt kit and radiator from RA; I better get a cool magnet!
  4. Jan 24, 2025 at 8:46 AM
    Here’s hoping. Doing oil change today, so I’ll fix it with tire rotation if needed. On a brighter note, averaged 15.1mpg this tank on these 285s. Not shabby. Normally would get around 15.8mpg with the 265s before.
    G_unit3000, bmf4069 and BroHon like this.
  5. Jan 24, 2025 at 8:48 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Jealous. With all this cold I'm only getting 9-11mpg around town.
    BroHon likes this.
  6. Jan 24, 2025 at 8:51 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Dude, you’re like a magnet for these occurrences now. Someone put bad juju on you.
    bmf4069 likes this.
  7. Jan 24, 2025 at 9:02 AM
    No telling where they are all coming from
  8. Jan 24, 2025 at 9:05 AM
    Jack McCarthy
    Bill
    North of Boston
    If you’re waking up and finding it when you go out to start your truck on the morning, I’d invest in a 24/7 security camera.
  9. Jan 24, 2025 at 9:07 AM
    Got one of those already.
  10. Jan 24, 2025 at 9:17 AM
    Jack McCarthy
    Bill
    North of Boston
    I had the same issue and when I got a wired PoE camera, it went away. Someone was able to get around the security of my WiFi spotlight camera and put a nice new drywall screw 1/2 sticking out of the rear tire. Even the cop admitted it was vandalism.
    G_unit3000 likes this.
  11. Jan 24, 2025 at 9:19 AM
    No one hates me enough to go through the trouble. Plus I just fix em myself, so they aren’t really accomplishing anything. I don’t want holes in my tires, but plugging them is quite satisfying.
  12. Jan 24, 2025 at 9:33 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    I wouldnt be surprised to find grandma slitting my tires.
  13. Jan 24, 2025 at 9:34 AM
    Jack McCarthy
    Bill
    North of Boston
    Whatcha do now to piss her off? :rofl:
    Sirfive[QUOTED] likes this.
  14. Jan 24, 2025 at 9:36 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Threatening to go home. Finally got her a dr appt, but its not until feb 7th.
    made sure her pipes didnt bust was the main point of this trip. I’ve gotta get home and check on my plants.
  15. Jan 24, 2025 at 1:01 PM
    Oil change and tire rotation done. Greased the drive line (ya lazy sod!!!) and adjusted the rear brakes. Also wiped the frame down with some penetrating oil. They’ve been brining the roads here during snow and ice events now :mad:
    small screw, not enough to penetrate the tire, so no repair necessary
    Frame and rear axle wipe down. Nice and clean and mildly protected
    IMG_2682.jpg IMG_2685.jpg IMG_2683.jpg IMG_2684.jpg IMG_2681.jpg IMG_2686.jpg
  16. Jan 24, 2025 at 1:09 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    My sequoia antenna never really worked. I replaced it with this one and reception is good. https://www.amazon.com/AntennaMastsRus-Conversion-Compatible-Sequoia-2001-2007/dp/B07B8WD7WV
  17. Jan 24, 2025 at 1:11 PM
    Jack McCarthy
    Bill
    North of Boston
    Someone needs a new catback exhaust. I’ll bet those pipes are paper thin up front.
  18. Jan 24, 2025 at 1:27 PM
    That’s mostly dried mud
  19. Jan 24, 2025 at 1:35 PM
    Jack McCarthy
    Bill
    North of Boston
    My mistake then, carry on. :burp:
  20. Jan 24, 2025 at 1:39 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
  21. Jan 24, 2025 at 1:55 PM
    FrenchToasty and G_unit3000 like this.
  22. Jan 24, 2025 at 2:01 PM
    oscardog86
    Southern California
    I just saw the ad a bit ago and texted the guy. We'll see!
    FrenchToasty likes this.
  23. Jan 24, 2025 at 2:03 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    That's not the original license plate that it came with, might not be a California truck originally.
  24. Jan 24, 2025 at 2:07 PM
    oscardog86
    Southern California
    yea i definitely wanna check it well for rust and get the VIN and carfax it
    G_unit3000 and des2mtn like this.
  25. Jan 24, 2025 at 2:09 PM
    It’s barely half the normal market price there. And only 140k miles? Surprised Jordan motorsports hasn’t scooped it up, slapped the new TB, LBJs, 2.5” lift and BFG tires and relisted it for $29k yet.
    bmf4069, JasonC., PNW15 and 4 others like this.
  26. Jan 24, 2025 at 5:12 PM
    Pulled a bone head move and over filled my engine by 1qt. My 2019 used 8 qts and I had that in my head instead of the 7qts my 2000 takes. Oops. Drove it home from the shop and realized my mistake when entering the info in the note I use to track maintenance. Drove back to the shop and used a YouTube trick to drain exactly one quart out. With a helping hand, I used a shop vac on the oil fill opening while I removed the drain plug. No oil came out. We turned the shop vac off and the oil began to drain. I had the 5 qt jug under there to catch the quart I wanted to drain out. Then turned the vac on once the quart was captured, replaced the drain plug. Worked great.
  27. Jan 24, 2025 at 6:00 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've seen that online before too. Cool to know it really does work
    oscardog86 and FrenchToasty like this.
  28. Jan 24, 2025 at 6:08 PM
    FrenchToasty
    Mo
    Bone stock
    I love your plate facts!
  29. Jan 24, 2025 at 7:32 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Did you get a frame replacement? That thing looks mint bud.
    PNW15 likes this.
  30. Jan 24, 2025 at 9:36 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    My neighbors having an upholstery shop. They were working on this first GEN today, it has a wing!!!
