  1. Jan 5, 2025 at 11:54 AM
    CS_AR
    CS_AR New Member
    Craig
    2000 Tundra TRD
    Just starting.
    Possibly, power seats lift the front to give the driver more room. I have long legs and driving my LC100 was not as comfortable before I installed Seat Jackers. Adding extra lift to the front helps to keep my knee from slamming the CSL switch. I have a 99 Tacoma with a manual seat that is painful to drive without seat jackers. Seat Jackers are not for everybody. There are versions that lift the rear mounts when someone needs a lift for better vision over the hood.
    I keep a stick of Gummi Pflege in the workshop. The ingredients must be very different. I can feel ShinEtsu give a warming sensation when I apply it. I've been using ShinEtsu since 2010 on Japanese vehicles with good success. The key is to use some product to treat dry seals as we move into a harsh winter. I can tell you it does keep doors from sticking when it snows and freezes.
    shifty`[QUOTED] likes this.
  2. Jan 5, 2025 at 12:01 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Grandpa has short legs, so the left side of my drivers seat is a little more collapsed than the right, i just keep my wallet on the left to compensate. Still more comfortable than most new vehicles with fresh foam. But i’m 5’10” & my truck has 150k of ass + extra hours from grandpa sitting and working sudoku while grandma went shopping. Since i pulled my swaybar, i do want a bit more bolstering, but if i slow a bit before corners, its not a need.
    455h0le_dachshund likes this.
  3. Jan 5, 2025 at 12:51 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You don't have to pop either ball joint to change the coil assembly. Just unbolt the four LBJ bolts and shift the entire spindle to the front of the truck a few inches. You'll have plenty of room to get the old assemblies out and the new ones in.
    ToyotaDude and FrenchToasty like this.
  4. Jan 5, 2025 at 12:55 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I've never done.any of that fluff when changing coil assemblies. No need unless you're swapping spindles.
    It would've been easier had I removed the sway bar links though.
  5. Jan 5, 2025 at 1:05 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Recent discussion on this. It's a resurrection of an older thread asking about the 3.4, but as always, we wander...
    https://www.tundras.com/threads/3-4-valve-clearance.126321/
    shifty` likes this.
  6. Jan 5, 2025 at 6:08 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    New windshield wipers, and air filter
  7. Jan 5, 2025 at 6:09 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I didn't even know they made wipers. I bet they're the best wipers ever haha
  8. Jan 5, 2025 at 6:11 PM
    They’ll last 120k miles like the originals streak free. No stutters. No fade finish.
  9. Jan 5, 2025 at 6:24 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    IMG_8927.jpg Finished up front struts. Will upload a pic tomorrow since it was too dark outside / too unlevel in garage. I am guessing any possible lift from the suspension though is counteracted by the 150+ pounds of metal bumper I bolted on the front. Looks exactly the same to me!
  10. Jan 5, 2025 at 6:37 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    Power steering flush and also finished doing the parking brake bit on the stereo. For the stereo, ended up just doing a bypass for the parking brake switch. Just way easier than fiddling around trying to find the right color wire down there in the kick panel.
    Power steering flush was ridiculously easy. I spent more time making sure I had all the tools back on the bench before closing the hood. Could not find the pick I used to loosen the return hose before I removed it. Ended up finding it had fallen to the left of the air filter box. Thank goodness I always make sure I have all my tools accounted for!
    Which made me think of something. Who here has also has started to back out of the driveway the next morning and gone 'crap, forgot to remove the wheel chocks'? :)
  11. Jan 5, 2025 at 7:06 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I don't think anyone can beat Bosch wipers. I mentioned before that my last set lasted over 6 years. Ridiculous. My current set is almost 3 years old.
  12. Jan 5, 2025 at 7:09 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Don't you park in a garage?
    Wipers last me a year tops, because I park outside and have to use them often because I drive a lot at night and early morning. Coastal Texas is humid AF.
    When I worked at the plants, they'd last 6 months. I think the salty air from the water and the chems in the air would ruin em faster.
    Methodical, Fragman and Jack McCarthy like this.
  13. Jan 6, 2025 at 6:32 AM
    Fragman
    Fragman New Member
    TX
    Wipers last me a year max too. Texas heat may have some bearing. I've done Bosch, Rain-X, OEM Subaru etc. They last about the same. I don't buy off brands as wipers are really not that expensive anyway. I put Rain-X on the Tundra as those were the ones that would 'arrive tomorrow'. They are fine, but only been on there a month.
  14. Jan 6, 2025 at 6:41 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Repackaged Bosch Icon. If you'll buy them from the dealer, you can get a 12month warranty. I will keep my receipt and then swap them out under a parts warranty ticket every 11months. I also do Bosch Icon on the Tundra.
    NUDRAT, bmf4069, shifty` and 4 others like this.
  15. Jan 6, 2025 at 6:47 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes I'm sure it helps that I park inside though there was a year during that 6 year stretch where I parked outside. Our heat isn't as intense as Texas either.
    I also don't really know how old they were. They were on the truck when I bought it in January 2016. I finally replaced them in January 2022. They were still working, but getting noisy.
  16. Jan 6, 2025 at 7:04 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    One thing that has extended my wipers life a year or more is treating them with 303 a couple times a year. It even rejuvenated an old pair and I got almost another year out if them. Calibrate result/MI weather.
    Edit: if I had a dime for every time I meat fist fat fingered the "i" when I wanted an "O" I could have a mint FGT...
  17. Jan 6, 2025 at 7:36 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Rain-x wipers have beefier springs than normal. The bosch has a large single spring, instead of the doubles most have.
  18. Jan 6, 2025 at 7:40 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    If your wiper blades don't match your tires don't talk to me
  19. Jan 6, 2025 at 7:45 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Anyone remember the double wipers on minitrucks (maybe it was lowriders)?
    not this, but whole wiper pairs on each arm.
  20. Jan 6, 2025 at 7:46 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  21. Jan 6, 2025 at 7:52 AM
    Yes, but they also had the deflector spoilers on them to be 100% rad.
  22. Jan 6, 2025 at 7:56 AM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    Haha, we used to sell those at Trak Auto, my first job in high school.
    whodatschrome likes this.
  23. Jan 6, 2025 at 8:07 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    Really? i would have expected you to gain at least an inch, considering it lifted mine about 2.5 inches. Although mine is 2WD and doesn't have a bumper.
    JasonC.[QUOTED] likes this.
  24. Jan 6, 2025 at 9:19 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    I’m also a schmuck and didn’t measure before and after (tape measure only disappoints me and the ladies) so am kind of just eyeballing it. It looks roughly the same as before to me. I’m actually not sad about it because now I can wait to do something on the rears, haha. Was expecting a Carolina squat on her. Burned up a lot of marital capital with a week working in the garage while kids were off school….gonna need to get that account balance up before I start talking about leaf springs and whatnot, to say nothing of actually installing them. :)
    I do notice it goes over speed bumps a little more smoothly though. Today is first time driving it so I will report back after a few days.
  25. Jan 6, 2025 at 9:22 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    Also y’all talmbout windshield wipers shoot I’m still on factories, like this when it’s foggy:
  26. Jan 6, 2025 at 10:22 AM
    shifty` Dead heads and frog legs. Mmm... cake mix!
    I did this in high school driving down a highway at 50-60mph, and a bee or something tagged me in the lower forehead, right above the bridge of my nose. I dunno if it stung me or what, but there was a tiny red dot at the epicenter of the impact, and my head swole up so damn big it was ridiculous. I'm incredibly happy digital cameras didn't exist back then, because the picture would've surely become a meme.
  27. Jan 6, 2025 at 10:27 AM
    I absolutely wouldn't have been able to get my coilovers in if I hadn't popped one joint. If you're not doing more than 1" - 1½" lift, maybe not, but with 2½", they absolutely wouldn't have fit.
    This is the way! I put Icons on everything.
    @KNABORES beat me to it.
    Having those things and those stupid ass Bad Boy Club stickers were so cliché bitd. (in my locality, it meant the drive was more douché than cliché, it was always the prep/jock/roper dickheads who rocked them)
    NUDRAT and bmf4069 like this.
  28. Jan 6, 2025 at 10:44 AM
    Ours was the No Fear stickers
  29. Jan 6, 2025 at 10:51 AM
    Shit, yeah, those came next. I remember seeing a lot of those too.
    And Oakleys! The kind rent-a-cops stereotypically wear nowadays.
    bmf4069 likes this.
  30. Jan 6, 2025 at 10:51 AM
    TXTundraGuy23
    TXTundraGuy23 One piece at a time
    Dallas
    2004 DC 4.7L 4WD
    6112s up front w/ 650 lb springs, 5160s in the rear, JBA UCAs, Suspension Maxx Links, ATS leafs w/ Wheeler's AAL and overload spring, Toyota Gloss Gunmetal TRD Wheels, Toyo Open Country AT3s 275/70/17
    Alright guys. Done with the lift and wheels and tires. Below is the after pic. I did a big write up on the build thread and you can see before and after pics and stuff there. https://www.tundras.com/threads/2004-dc-4-7-4wd-build-log.128950/. I’ll post the measurements on the measure up thread soon. I’m still waiting on the 5160s, but that really shouldn’t change height or anything, just ride. I love it, I’m super pumped with how it turned out.
