  1. Nov 17, 2024 at 10:03 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    I once threw a smoke out that window which came back in through the bit the main window was down and went into my ear lit side. As I went to swipe it away from my ear, I pushed it further in. I can still hear my ear drum sizzling thinking about it. Needless to say I learned an important lesson about littering that day.
  2. Nov 17, 2024 at 10:04 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Captain Planet karma
  3. Nov 17, 2024 at 11:56 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Changed the oil and greased the UCA's. 195,020.
    G_unit3000, bmf4069, KNABORES and 7 others like this.
  4. Nov 17, 2024 at 12:04 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Not sure what you use to grease your upper ball joints, but I use this. It exceeds SPC's spec requirements, and, for here in the desert, at least, zero issues with "thinning" and leaving surfaces unprotected and requiring more frequent treatment to compensate. Very happy with it.
  5. Nov 17, 2024 at 12:13 PM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    Swapped out to a better radio. Put in a Pioneer AVH 241EX.
  6. Nov 17, 2024 at 1:07 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
    Not a euphemism.
    Yes, I used to flip machines as a side hustle though. I know the insides of a couple of big brands pretty well. I got that specific superautomatic when we shut down the office, but it wasn't functioning. Vibe pump lost its prime and it was chock full of nasty shit. Slowly been working at it, only thing that may need replacing in the mid-to-long term is the burrs. I looked at the brew count yesterday and it's made just over 27,000 cups of joe.
    This is the way!
    Yup, swing the rounded edge of the window out to 5 o'clock and everyone inside gets blasted.
    BroHon[QUOTED] likes this.
  7. Nov 17, 2024 at 1:37 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Biggest pet peeve with my ‘74 Fiat 124 is those windows/vents. They don’t angle far enough! Literally 15° more and the air would be right on you. But no- right on your arms. Not your torso.
    It’s hard to see in this photo since it was taken on a grainy film stock, but they don’t angle forward very far. So close but yet so far. IMG_0722.jpg
    whodatschrome, KNABORES and BroHon like this.
  8. Nov 17, 2024 at 1:43 PM
    FrenchToasty
    Mo
    Bone stock
    Greasing LCA bushings today; noticed some pink stuff…… IMG_7308.jpgFound the culprit up top on my throttle body bypass hose, tightened up the clamp and hosed it all down to monitor in the future.
    Also got around to putting 90 degree zerks on the rear Total Chaos shackles, should be much easier to lube those up now. I also checked my TB sticker; I’m at almost 80k and ten years since the last service, I’ll start collecting parts asap
  9. Nov 17, 2024 at 3:36 PM
    Desert Dog
    After what happened to me recently, I'd recommend checking the fan pulley bracket's bearing function when you go in. It's not a cheap part, but you're there already. Better than going 1/2 way back in later just for that one part.
  10. Nov 17, 2024 at 3:39 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Dude, that's Nucking Futs! My prolific ear hair would have blocked that :rofl:
  11. Nov 17, 2024 at 5:39 PM
    808basswolf
    808basswolf New Member
    Los Angeles, CA
    2002 tundra SR5 v8 AC 2WD
    Bought floor mat clips, there's no floor mat holes for the clips on the floor. is this common to not have the ability to put in clips?
  12. Nov 17, 2024 at 5:49 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I need to put zerks on all my suspension parts. Maybe I'll do the OEM shackles too, when I try to add a leaf to my Alcans. Any advice for someone who's never added zerks to anything before?
    I've wanted to do that bypass, but never found a solid "how to" thread or video. Probably better not to, since it gets cold n wet here in the winter
    Filthyphil likes this.
  13. Nov 17, 2024 at 5:54 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Your truck did not come from the factory with holes in the floor for floormat clips. I believe there was a recall in 2009 or so where Toyota installed holes and clips for floormats to prevent the gas pedal from getting stuck on them. I can't remember if our trucks were actually included in this recall, but I would contact a dealer with your VIN to see about it.
    Again,I can't remember if our trucks were actually included in this recall, but Toyota 100% installed a hole in my truck for free back in the day. Toyota was facing lawsuits due to this, and anytime I take my truck to the dealer for service, there is always a line saying they checked that the clip was properly installed.
  14. Nov 17, 2024 at 5:58 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Not sure if the 00-02 had clips
    I know my 03 and 06 have em. But the dipshit that installed my 5 channel amp ripped mine out
  15. Nov 17, 2024 at 6:11 PM
    FrenchToasty
    Mo
    Bone stock
    How many pesos we talkin?
  16. Nov 17, 2024 at 6:12 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Mine has them. '02. Maybe in the early years it was a Limited model thing?
    455h0le_dachshund likes this.
  17. Nov 17, 2024 at 7:35 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Just did this job with the AISIN. 2199 pesos :D
    https://www.rockauto.com/en/moreinfo.php?pk=1871558&cc=1357938&pt=11548&jsn=937&_nck=RaosfcaC2rGfgWZf6hBZg5NUf6MSkocsWVfFT2iAXgaYeHXf1/ILNWxHjselgYmonJpDjJ+CXVchX+WjGNgOaj0i1ckWjPcUSYUDTZ2ajdhh2GbF2s1bMKy5u72/28B7gRNfvgFb6M2VC6vqYX7FNPUWdvXdHJlvD1hmuBL+DnxPbh0iBK6rjQPAcPxceGEYbjDQIvkiWIDuu5crumttm64oTG3GC7tYEX78nAwX9Ie325pY3yjTBamRAQpzckj+1TCReXZWfZZP0raljzjR2s+q+Ja/ZZzxQBQsE+vsKGg5dWGDq4rlZw==
    EDIT: thought I better drop in a pic, or it didn't happen right?:rofl:
    And I mean how few steps are left to just go ahead and do the timing belt and water pump... right?
    Voss, bmf4069, KNABORES and 4 others like this.
  18. Nov 17, 2024 at 9:22 PM
    Desert Dog
    I bought a genuine OEM Toyota part. It was $320.
    I'm pretty sure Aisin sells their comparable product for less if you choose to go that route, as well.
  19. Nov 17, 2024 at 11:55 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    My 03 SR5 does too.
  20. Nov 18, 2024 at 12:01 AM
    des2mtn
    SW
    Tonto cover
    My '04 limited did not come with them from the factory.
    Your guys' might've been done by the dealer by a PO or a dealer did it without telling you. I distinctly remember when Toyota installed mine because the accident that set forth the Toyota recall was local.
    Here's an article from the time: https://www.sandiegouniontribune.com/2009/10/27/feds-raise-concern-over-gas-pedal-in-fatal-crash/
    ToyotaDude[QUOTED] likes this.
  21. Nov 18, 2024 at 12:04 AM
    ToyotaDude
    ToyotaDude Member
    MT-Tundra and des2mtn[QUOTED] like this.
  22. Nov 18, 2024 at 1:26 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Got a link to the clip?
  23. Nov 18, 2024 at 4:34 AM
    Aisin is OEM on that part. Toyota doesn’t make it internally. Nearly all of the rotational bracket style parts on our engine are made by Aisin, with exception of free bearings. Aisin appears to use KOYO bearings in their parts also, but I haven’t seen all of them so not saying “all” parts. What I have observed is every one of these factory brackets and every water pump I’ve seen come out have Aisin cast into the housing. Plenty of other mechanical parts on our trucks also, but …. Dunno.
    JakeJake and Desert Dog[QUOTED] like this.
  24. Nov 18, 2024 at 4:56 AM
    Desert Dog
    Yes, true, but I chose to purchase through Toyota. If someone is in need of the part and the Aisin is readily available through a LAP outlet, I wouldn't hesitate to use it.
    FrenchToasty and shifty`[QUOTED] like this.
  25. Nov 18, 2024 at 4:57 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Driver mat should have had grommet for hook. Passenger and rear mats did not.
    These are original mats in 04 AC SR5. Can confirm that 03 AC Limited is same.
    Along the way, had to buy new mats from Toyota dealer, and they matched original.
    Voss and MT-Tundra like this.
  26. Nov 18, 2024 at 5:43 AM
    kentuckyMarksman
    Were these hooks in the carpet for holding the floormats an AC and Regular Cab only thing? My 2006 Double Cab does not have a hook, but the aftermarket floor mats the previous owner put in has a hole for a hook. I thought maybe he just bought the wrong mats...
  27. Nov 18, 2024 at 6:00 AM
    My '06 has the provision for the clip in the OEM carpet. But not sure if it came from the factory/dealer that way or what. I just know I had OEM mats which have the hole, and the carpet had the clip when I bought it w/barely 60k miles on it back in 2018/2019 or whatever.
  28. Nov 18, 2024 at 6:17 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Is there a hole in the floor to put a hook in? I think the hook just breaks off sometimes.
  29. Nov 18, 2024 at 6:53 AM
    MT-Tundra
    Montana
    Amazonian Link
    No idea what happened in the 22 years of life my truck led before I bought it. But yeah, I've got a grommet in the carpet and a OEM floor mat with a hole. I bought a '2-pack' online, without looking to see if my passenger side had a hole. It doesn't. And turns out each pack comes with 2 hooks. So I now have 3 spare hooks. If anyone wants one, let me know. They're plastic and I'm surprised I didn't break it trying to get it in the hole (...). Probably good to have a spare but I don't need 3. But...they're $5 for four of them online.
  30. Nov 18, 2024 at 7:53 AM
    A little trimming for tire clearance. Pics at close to max static compression, wheel turned for maximum contact. A little off the airdam, a little off the fender liner, a couple solid whacks with a hammer on each bumper edge to deflare.
    Obligatory tuck and Flex shots. Near but not complete articulation for each. The back tire may rub the inner fender slightly if fully articulated. Off-road testing must be done.
    Voss, kodyquist21, Tlar25 and 6 others like this.
