  1. Oct 7, 2024 at 8:38 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Heated mirror button on my truck is underneath the cargo light button on the center dash.
    This one is for side airbags though, mine is blank too.
    This DC has them https://www.victorymotorsofcolorado.com/inventory/2006-toyota-tundra-sr5/277141
    G_unit3000 and Kimosabe[QUOTED] like this.
  2. Oct 7, 2024 at 8:40 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's where my heated mirrors button is on my 06 AC
    G_unit3000 likes this.
  3. Oct 7, 2024 at 10:09 AM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    Who has recommendations for wash/wax on the chalky white paint? I know you have opinions, Shifty? I will be hand buffing.
    oscardog86 likes this.
  4. Oct 7, 2024 at 10:39 AM
    shifty` Goons of Hazzard
    I not only have opinions, I wrote a whole writeup about how to do it with a random-orbit sander with hook-and-loop pad. :rofl:
    But you want by hand. If hand buffing, Get a GOOD orange cutting pad. I recommend this specific pad, which you can probably get on scAmazon. Buy a couple of them.
    Never led the pad touch the ground (sand risk); rinse and wring out before putting it away.
    If you use that in combination with Meguiar's Ultimate Polish, I suspect you'll get a long way. I used orange hexlogic pads to do the tight areas on my truck, like the 3" perimeter around my rear window, the A-pillars, and a few of the nooks and crannies.
    The hardest parts to really get done, especially with an orbital, are the body lines up over the wheel wells, the body line on the tailgate, and the body lines on the hood. I actually need to go back over all of those spots by hand with my truck. And I need to touch up the passenger's side then re-seal.
    Be sure to wax after.
  5. Oct 7, 2024 at 11:22 AM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Thanks! I knew you would have the answers, do you have any preference on what type of wax to use? Stick with Meguiar's or whatever’s cheap?
  6. Oct 7, 2024 at 11:24 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I have an old Coats 40-40 tire changer in my shop. I suppose it would be nice to have a balancer as well, but i haven’t felt a need for one. I think i must be a less discerning driver than most, because i haven’t had my tires balanced on any vehicle that i’ve owned for at least the past 15 years.
    ToyotaDude[QUOTED] and JakeJake like this.
  7. Oct 7, 2024 at 12:09 PM
    I am old school, and used a good Turtle Carnuba (sp?) wax. But I need to Claybar and reseal the damn paint anyway, the wax was a temporary solution. One that’s held up really well on the polished panels, but not on the one panel I used compound on without fully polishing out after.
    G_unit3000 and Bed Tundy[QUOTED] like this.
  8. Oct 7, 2024 at 1:32 PM
    Methodical
    Methodical New Member
    Maryland
    2006 Tundra SR5 DC TRD 4x4
    That bad tie rod sounds like the culprit for the tire cupping.
  9. Oct 7, 2024 at 1:42 PM
    Methodical
    Maryland
    What should the number and letters be for the new and old caliper?
  10. Oct 7, 2024 at 1:44 PM
    Methodical
    Maryland
    What is the TPMS disable trick?
  11. Oct 7, 2024 at 1:45 PM
    Cut/ground out a wire to bypass the TPMS system, basically.
    G_unit3000 and Kimosabe like this.
  12. Oct 7, 2024 at 1:46 PM
    2006 should have “13WL” cast into the caliper.
    Methodical[QUOTED] likes this.
  13. Oct 7, 2024 at 1:48 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    There's a link in my earlier post that has good pictures and info on how to do it. But if you run tires at a lower PSI than that normal, or are too cheap to replace TPMS sensors (like me) then this will keep the tire pressure light off your dash.
  14. Oct 7, 2024 at 1:52 PM
    Methodical
    Maryland
    I just had the tires on my Sequoia spin balanced and the lug nuts were hard to remove, but they barely tightened the wheel lock, which I am ok with. I believe they torque them using the torque specs for the steel wheels, which is 154lbs, and not the alloy wheels (97lbs). I always remove and re torque the lug nuts after the tire shop does anything with them. I try to do it in the parking lot that way if there are any issues they can't try and blame me because I never left the premises.
    whodatschrome and oscardog86 like this.
  15. Oct 7, 2024 at 1:53 PM
    Methodical
    Maryland
    Thanks. Is that for the new version? I will check because I will be replacing the brakes in the near future.
  16. Oct 7, 2024 at 1:55 PM
    Methodical
    Maryland
    Thanks. I don't give a crap about the TPMS light. My 95 Cobra and 80 Supra (no longer own her) never had this and we survived for many years without. Hell, I am the TPMS.
  17. Oct 7, 2024 at 1:57 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The stupid light has been on in my 06 since long before I bought the truck. It doesn't bother me at all
  18. Oct 7, 2024 at 1:57 PM
    whodatschrome
    lots of dents
    See if you can find an old bottle of Simoniz.
    It might prove to be difficult to find at the local Kmart anymore, but surely you can find a half used bottle in the glovebox of someone’s old Buick.
  19. Oct 7, 2024 at 1:58 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I used to work at a Simoniz carwash/lube shop in Conroe, TX.
    whodatschrome[QUOTED] likes this.
  20. Oct 7, 2024 at 2:10 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    but you get rid of it. The dash looks so much nicer........
    Kimosabe likes this.
  21. Oct 7, 2024 at 2:19 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Psh. I ain't nice and neither are my rides.
  22. Oct 7, 2024 at 3:15 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Decided to try an Avery carbon fiber vinyl wrap on my faded hood. Didn't like it at first but it is growing on me. I messed up a few tiny spots but overall it went well.
  23. Oct 7, 2024 at 3:16 PM
    2004+ all had 13WL. Possibly 2003 also, I always forget.
    All the brake reference info you could want is in the megathread/so you just bought a 1st gen thread.
  24. Oct 7, 2024 at 3:20 PM
    I need to do this. Wifey ain’t on board. She says repaint the truck. Only really need the hood and roof, which this would work for.
  25. Oct 7, 2024 at 3:22 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Awesome seeing this done, as it's something I've also considered doing.
    My roof needs it too. The whole truck does. But I hadn't even considered wrapping the roof. Now I'm thinking CF hood and roof would look sick on my black truck.
    Auburn02, oscardog86, BroHon and 3 others like this.
  26. Oct 7, 2024 at 4:44 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Smaller pad calipers - S13WE
    Larger pad calipers - 13WL
    A lot of 2000-02 and maybe some 2003, which had the smaller from factory, were upgraded to the larger caliper due to a TSB which addressed pulsation and premature wear.
  27. Oct 7, 2024 at 4:45 PM
    FishNinja
    Lee
    06DC2wd
    I'll allow one fake CF hood.and only cause it looks fucking like real carbon. Is it textured?
    but what a disappointment when that hood ever goes up LOL
    just color match you twats
    BroHon, bmf4069 and FrenchToasty like this.
  28. Oct 7, 2024 at 8:39 PM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    went on to Insall new winter blizzaks on my extra rims,thats what works here in alaska..winter rims...summer rims and tires...ended up throwing on some napa brake pads...just trying to get threw winter
  29. Oct 8, 2024 at 3:31 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    :rofl:remember?
    NUDRAT and whodatschrome[QUOTED] like this.
  30. Oct 8, 2024 at 4:13 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :eek:o_O:crapstorm:
