  1. Apr 28, 2019 at 5:54 AM
    #6451
    Professional Hand Model
    Hand Protectors
    Discovered good news/bad news with doing yesterdays work. Bad news is the ‘heated mirrors’ require the actual assy, as in buy all new side mirror assys for $250 each (new).
    Good news is if the actual mirror plates break they can be replaced relatively easy by pulling them off without removing the entire assy.
    Tools needed to remove back plate are flat screw driver and 2 popsicle sticks.
    NUDRAT, Darkness and bmf4069 like this.
  2. Apr 28, 2019 at 5:56 AM
    #6452
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You can try and fish 2 wires through your mirror housing.. that’s all that’s different
  3. Apr 28, 2019 at 5:58 AM
    #6453
    Hand Protectors
    Thanks! I’m going to draw a new sketch of what think needs to happen based on your knowledge. Give me a minute.
  4. Apr 28, 2019 at 6:08 AM
    #6454
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'm assuming that's Toyota pricing. FWIW I bought a TYC power/heated mirror for my 04 for $45. No discernable difference in quality besides the new one doesn't shake :)
  5. Apr 28, 2019 at 6:09 AM
    #6455
    Hand Protectors
    The “two new wires” go to?
  6. Apr 28, 2019 at 6:11 AM
    #6456
    empty_lord
    05 rollover special
    I’d have to pull up the diagram. But yes the 2 wires on the mirror are right, as for the connector it might be, in mine it’s on the 2 bottom connectors, but I have an 05.. I’ll take a peak when I get home from Indy. Won’t be till late though
  7. Apr 28, 2019 at 6:18 AM
    #6457
    Hand Protectors
    I saw those when on a search. The OEM Toy are $250. Just the mirror ‘heated plate’ is $50 if bought separately.
    Makes sense to just buy the entire assy $45. And yeah my drivers side shakes a little, but the pass side is good (new) as its been replaced due to a ‘recycle yard accident’ where a drunk backed into the mirror.
    Now I just need to figure how to wire/switch these mirrors.
  8. Apr 28, 2019 at 6:31 AM
    #6458
    Festerw
    Festerw New Member
    04 Tundra DC
  9. Apr 28, 2019 at 6:57 AM
    #6459
    Casper421
    In the woods
    06 DC
    Not me, I have plenty of clearance on both sides but makes me think... @Rheywood456 did you encounter this?
    Rheywood456 likes this.
  10. Apr 28, 2019 at 10:32 AM
    #6460
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Some $40 one(dont remember the brand off the top of my head but if had it for a year now and still bright as ever (ill update u one brand later)). Not in but on my bumper, just a curved 32 inch one. The origonal plan was to put it in my bumper in the little air channel for the radiator. But it would require cutting.
  11. Apr 28, 2019 at 11:37 AM
    #6461
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Yup. I did a little grinding down. That seems to be the only flaw with Total Chaos. If that’s the only flaw... I’m happy...
    Casper421[QUOTED] and Darkness like this.
  12. Apr 28, 2019 at 11:38 AM
    #6462
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    Cleaned up the truck now that pollen isn't as bad. Started cleaning the commuter as well..
  13. Apr 28, 2019 at 1:06 PM
    #6463
    Hand Protectors
    Toying around with going clean bro look.
    Also, here are some bumpstops I fabricated up a few weeks ago. Cut them in half and scalloped out the surface which will adhere to the OEM stop. Going to use an organic 2 part epoxy to glue the new right up to the OEM ones. Still unsure on doing this and leaning to do all 4 stops if so.
    because_wumbo-truck and Darkness like this.
  14. Apr 28, 2019 at 1:49 PM
    #6464
    Need to know stuff
    Autofeul brand light bar
    MNtundra[QUOTED] likes this.
  15. Apr 28, 2019 at 2:33 PM
    #6465
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    If you decide to do it let me know. There’s a few little things that have to be changed to make the case work like replacing the trans output seal and a plate needs to be welded to the side of the case because the flange on the case and trans are slightly different.
  16. Apr 28, 2019 at 2:45 PM
    #6466
    Hand Protectors
    ‘4hi on the fly’ is a beautiful thing we have on our 1st Gens which was a selling point for me when I bought it.
    As long as it works, I am not changing it. Exercise your 4hi button once or twice a week for a mile or two to keep the actuator in shape. I think many problems come from not using the 4hi and things sieze up in there once it comes to be needed.
    The 4low actuator is separate from 4hi and needs exercise too?
  17. Apr 28, 2019 at 3:19 PM
    #6467
    ethan1911
    X2 on this. It is really convenient and is pretty reliable when used on a regular basis. I would have kept mine if I still had a stock front axle.
  18. Apr 28, 2019 at 3:42 PM
    #6468
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I've always heard you should engage each about once a month.
    speedtre likes this.
  19. Apr 28, 2019 at 3:43 PM
    #6469
    because_wumbo-truck
    Jon
    Houston, Texas
    What do you have? Solid front axle swap?
  20. Apr 28, 2019 at 3:45 PM
    #6470
    because_wumbo-truck
    Jon
    Houston, Texas
    What's the clean bro look?
  21. Apr 28, 2019 at 3:49 PM
    #6471
    ethan1911
    Yes Dana 44
  22. Apr 28, 2019 at 3:54 PM
    #6472
    Hand Protectors
    Yeah thats what the manual says. I say once a week so if I forget, then at least I remember twice a month.
    I went a few years not using the 4wd and think the actuator got stuck, but finally engaged after a few minutes. Never exercised it like the manual says.
    The clean bro look is removing the badges. Looking at the trim removal, too. I like the wheel flares and will be keeping those.
    If I do the trim removal, I start with the little pieces on the bed body for practice.
  23. Apr 28, 2019 at 4:43 PM
    #6473
    because_wumbo-truck
    Jon
    Houston, Texas
    Man fuck white. I just spent.all my quarters plus a dollar bill at the self serve carwash and my truck is still not quite clean. I guess it's gunna need a hand wash and a detail/wax soon.
  24. Apr 28, 2019 at 4:45 PM
    #6474
    because_wumbo-truck
    Jon
    Houston, Texas
    I debadged my 03 taco. It was clean
    I wanted to remove my trim and fender flares, but ultimately decided against
    it... For now.
    :popcorn: keep us posted
  25. Apr 28, 2019 at 4:47 PM
    #6475
    because_wumbo-truck
    Jon
    Houston, Texas
    You got a build thread? Why have I not seen your truck? Lol sounds sick
  26. Apr 28, 2019 at 4:49 PM
    #6476
    abcinv
    Tommy
    NW Georgia
    I'm considering de-badging the Tundra as well - or blacking them out...
    because_wumbo-truck likes this.
  27. Apr 28, 2019 at 5:08 PM
    #6477
    Aerindel
    Aerindel New Member
    Montana
    Yes, its pointless but its just how the gearing works. You can't go from 4hi to 4lo directly anyway, neutral is where you stop on your way. Its the same basic reason you have to stop, go in neutral and then push the button on our push button tundras.
    Now...with a manual transfer case on an automatic transmission it could be pretty useful...I THINK that it could allow you to tow the truck flat without damage which would be great as I view that as a huge limitation of automatic transmissions.
  28. Apr 28, 2019 at 5:45 PM
    #6478
    ethan1911
    Thanks, Yeah there’s a build thread on here for it
  29. Apr 28, 2019 at 6:01 PM
    #6479
    empty_lord
    05 rollover special
    It’ll be a while, there’s a new used transfer case under the truck already from The previous owner when his actuator failed
    ethan1911[QUOTED] likes this.
  30. Apr 28, 2019 at 6:06 PM
    #6480
    Dpy
    Dpy New Member
