  1. Sep 8, 2024 at 1:10 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
    My "mix" was just going to be waste oil, but I forgot I had flushed my PS fluid, so the first 5qts was about 80% atf.
    Ive installed a few of those rings, that and bar oil would be thick. He must have to brush that on or apply/spray really hot.
    Great idea though, makes me want to try that out.
  2. Sep 8, 2024 at 11:05 AM
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2000 Access Cab
    Pulled out the plastic Toyota bed liner that had been in there for over 25 years, don’t know if I’ll just put in a bed mat or have it sprayed.
    Looks pretty good.
    des2mtn, oscardog86, bmf4069 and 8 others like this.
  3. Sep 8, 2024 at 11:06 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I’ll eventually bedline mine, but I prefer a rubber mat over a plastic liner any day of the week.
  4. Sep 8, 2024 at 12:36 PM
    I'd skip the bedliner. Seen too many times where the bed rusted out from underneath as a result. A lot of people rotate thru their trucks before it happens to them. Seems to be worst in the rust belt when water wicks up the bolt shaft and rests up under the edge of the liner.
    If you insist on spray liner, make sure the bed bolts get pulled before spraying. Yes, if a shop is doing it they're going to argue, fight, look at you crazy. But they're not the ones who will need to deal with rust later.
    Hi06silver and oscardog86 like this.
  5. Sep 8, 2024 at 12:54 PM
    Jjclamdips
    Wichita, Ks
    2000 Access Cab
    Pretty sure I’ll do a Westin rubber mat, just touch up some of the rub spots with some primer and lay it in.
  6. Sep 8, 2024 at 1:23 PM
    WardenTruck
    WardenTruck New Member
    2006 OEM Tundra
    Dangerously Stock
    Washed it.
    It is pleased.
    That is all.
    oscardog86, BroHon and Jjclamdips like this.
  7. Sep 8, 2024 at 2:14 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I have a Westin in my truck. I'd prefer a thicker mat, but wasn't willing to pay for one. For what it is, it's great. Pretty cheap, custom fit, stops every little thing you throw in the bed from scratching off paint. And keeps things from sliding around. I hadn't thought of that at all, but a lot of reviews mentioned it. Sure enough, it's pretty "sticky". Not to the touch or anything, but things just don't move around as much in the bed as they used to.
  8. Sep 8, 2024 at 3:03 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Save the money. Get a rubber stall mat from tractor supply and cut to fit as necessary.
    NUDRAT, oscardog86, BroHon and 5 others like this.
  9. Sep 8, 2024 at 3:31 PM
    Jjclamdips
    Wichita, Ks
    2000 Access Cab
  10. Sep 8, 2024 at 4:03 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
  11. Sep 8, 2024 at 4:14 PM
    MT-Tundra
    Montana
    3/4" thick. Damn. That's what I should have done. Maybe I'll upgrade at some point. The Westin is a bit less than 1/2".
  12. Sep 8, 2024 at 7:07 PM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    Methodical, khooiii, CodyP and 10 others like this.
  13. Sep 8, 2024 at 9:15 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Serra Toyota 25% off parts sale back on through 9/12/24. Here's the fine print on the sale and the free shipping for orders over $75.
  14. Sep 9, 2024 at 3:48 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Pretty happy with the quality of these. Had not seen a pic in dark with backlighting. Holy crap were they tight pressing on. Went well into cringe territory on 24 year old plastic HVAC controls. Fan knob is about 1/8" ish further out than the rest, pressed as hard as i dare. Glad my truck cab hasn't seen the heat cycles like you guys get down there in the south (surface of the sun:bananadead:)
  15. Sep 9, 2024 at 4:24 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I had the exact same issue with mine.
    BroHon[QUOTED] likes this.
  16. Sep 9, 2024 at 6:16 AM
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    @BroHon @FirstGenVol those knobs are sitting on a "truck list" I created on Amazon. Looks great, think they will get added to cart when I start buying stereo stuff.
    oscardog86 and BroHon like this.
  17. Sep 9, 2024 at 6:38 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Thx for confirming that it's not just mine.
  18. Sep 9, 2024 at 6:58 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Horse mat from tractor supply is a well priced thick hunk of rubber mat. Trim to fit required.
    Oh - late to the party.
    2nded.
    Jjclamdips likes this.
  19. Sep 9, 2024 at 4:07 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I did this on my not Tundra truck and it works great. Sliding items in off the tailgate requires a boost but otherwise all good.
  20. Sep 9, 2024 at 5:23 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Nothing you can trim with a nail file on the inside of the knob to make it easier?
  21. Sep 9, 2024 at 6:04 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    :thumbsup:Yeah, I've though about pulling it back off and getting the caliper out to check the depth/length, and determine if the knob or shaft is too long.
    I also know how a guy can fuck with something like this and then end up worse off :facepalm: so I'm thinking about it for a minute.
    EDIT: I think maybe you were just talking about fixing how tight they are. Awful small spot to file INSIDE the end of the knob. you could file the shafts, but then there is no going back easily. I like the tight fit, I just want the blower knob to go in farther and be even with the other two.
  22. Sep 9, 2024 at 6:23 PM
    Jack McCarthy
    Bill
    North of Boston
    Yeah, I meant inside the knob but with something like this… or some other needle file set.
  23. Sep 9, 2024 at 7:52 PM
    phudz
    phudz
    Michigan
    2004 DC V8 4WD
    Replaced my front brakes today along with an oil change at 103,xxx miles. Not entirely sure what caused the uneven pad wear on the passenger side. The caliper piston compressed back in fairly easily, so maybe slide pin was just never greased?
  24. Sep 9, 2024 at 7:54 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    IMG_7066.jpg IMG_7067.jpg IMG_7068.jpgWired in my DC/DC MPPT controller. The two mounting bolts near the bedside were a test of master hand yoga skills and moves I didn’t even know existed! I guess I need a different blue toof communication app/monitor, that will be here tomorrow.
    oscardog86, shifty`, bmf4069 and 2 others like this.
  25. Sep 9, 2024 at 8:04 PM
    Jack McCarthy
    Bill
    North of Boston
    That’ll do it. When I replaced and greased mine, the wear went back to being pretty even.
    oscardog86, BroHon and phudz[QUOTED] like this.
  26. Sep 9, 2024 at 8:06 PM
    Jack McCarthy
    Bill
    North of Boston
    You got a portable solar panel? Nice.
  27. Sep 9, 2024 at 8:12 PM
    FrenchToasty
    Mo
    Bone stock
    I guess they are portable? They live on top of my truck…… 2-100w panels, and the alt/starter can deliver 30 amps to the controller- not sure what the controller does with it after that to the 100amp lipo9 battery
  28. Sep 9, 2024 at 8:14 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Portable until your truck dies
  29. Sep 9, 2024 at 8:24 PM
    Jack McCarthy
    Bill
    North of Boston
    It typically uses some modulation method to charge the battery. I’m sure there’s a good reason why but I’m no battery expert. Most likely has to do with the physics behind battery charging. There’s probably a YouTube video out there explaining it.
    FrenchToasty[QUOTED] and des2mtn like this.
  30. Sep 9, 2024 at 8:26 PM
    FrenchToasty
    Mo
    Bone stock
    Oh it definitely uses modulation and other weird stuff. The mppt controller supposedly has a higher efficiency rate than a pulse with modulation(pwm) controller, I think their charging profiles might be a little different too
