  1. Aug 29, 2024 at 5:33 PM
    Not sure that post deserved a ban
  2. Aug 29, 2024 at 5:35 PM
    shifty` Inside his chest they found ten thousand pencils
    I dunno, when someone warns you "who's next?" and you throw your hat in the ring, I feel like you get what you get. FA&FO, "Play with fire", I think it applies here.
    I learned that lesson the hard way IRL a couple times in my teens and twenties because I wanted to be the funny guy.
  3. Aug 29, 2024 at 5:36 PM
    Maybe so
  4. Aug 29, 2024 at 5:40 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  5. Aug 29, 2024 at 5:47 PM
    G500XL
    G500XL New Member
    SA, Tx
    Sliver 05DC 2wd
    Is the assembly OEM or aftermarket, where did you get it and how is it working now?
  6. Aug 29, 2024 at 6:20 PM
    WTHamIdoing
    WTHamIdoing New Member
    Eric
    2001 tundra v8(2uzfe) auto extended cab
    Killmat entire cab Method 703 wheels King 2.5 coilovers w/ 700lb springs JBA UCA Coastal Off Road high clearance front/rear bumpers and sliders Dirty Deeds 250cc 12 hole fuel injectors
    I was fortunate enough to not have to make it myself and bought it like this! It's much lighter than my snugtop was and is riveted together with an aluminum frame. I can post detailed pics if anybody is shopping around for fabrication ideas.
  7. Aug 29, 2024 at 6:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Do it
  8. Aug 29, 2024 at 6:35 PM
    WTHamIdoing
    Eric
    It's now on the list to be done when I get back from this work trip. That along with 12 hole injectors and wheel swap to 0 offset wheels so my tires stop rubbing on frame and UCA!
  9. Aug 29, 2024 at 6:48 PM
    They’ll just rub the front bumper and pinch welds and mud flaps instead. But 0 offset looks dope
    oscardog86 and 455h0le_dachshund like this.
  10. Aug 29, 2024 at 6:51 PM
    WTHamIdoing
    Eric
    At least I can cut and hammer those. Don't want to be cutting my frame! Trying to get method 703's on labor day sale. Anybody know anything about their bead grip? Effective or just marketing?
  11. Aug 29, 2024 at 6:52 PM
    I just looked my setup up. 16x8 with I believe 4.5” backspacing (not confirmed). I also run 1.25” spacers, so I’m rocking -32 offset apparently .:rofl: I’m removing the spacers when I get my 285s.
  12. Aug 29, 2024 at 6:58 PM
    WTHamIdoing
    Eric
    Is that offset on your grey one in your pictures? -32 seems like its barely poking out!!!
  13. Aug 29, 2024 at 7:05 PM
  14. Aug 29, 2024 at 7:07 PM
    WTHamIdoing
    Eric
    Oh that's definitely some poke! What do you think you'll have to do to get the 285s to fit?
  15. Aug 29, 2024 at 7:08 PM
    Take the spacers off
    Weejub likes this.
  16. Aug 29, 2024 at 7:11 PM
    WTHamIdoing
    Eric
    How do you know that they won't rub frame or anything?
  17. Aug 29, 2024 at 7:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I've always had trouble understanding BS and offset. It there a way to easily calculate those numbers with spacers?
    I currently have 0 offset and 1.25 spacers.
    The wheels I want are -10mm offset. Part of me hopes I'll be able to run em with 35x10.5 tires without spacers. But that's probably wishful thinking.
    I know my 295/75 tires rub frame without spacers on the 0 offset wheels.
    WTHamIdoing likes this.
  18. Aug 29, 2024 at 7:20 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    According to Google that's the same as 1.25". So the equivalent to a Spidertrax spacer with 0 offset wheels. Which is exactly what I have.
    KNABORES likes this.
  19. Aug 29, 2024 at 7:21 PM
    WTHamIdoing
    Eric
    There are wheel fitment calculators but i havent found one thats accurate because my 275/70/17 rubs on frame and stock uca with stock wheels and the fitment calcs all say that sizing should be fine
    I would be curious to know how crazy offset effects performance. like what if we went -90 offset and like 1.0 backspace as an extreme example. when would the strain on parts be too much to where it wouldnt be worth it to push the wheels out that far?
  20. Aug 29, 2024 at 7:26 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    https://youtu.be/RAMN2rfdEd8?si=j2cVyU5XYltbmbBM
    I just saw this last night.
    Sounds like you need spacers for sure. My buddy had stock 16's with 285/75 and rubbed the UCAs til I sold em some Spidertrax
  21. Aug 29, 2024 at 7:33 PM
    WTHamIdoing
    Eric
    Yeah that guy brought up the same point. but what is the difference in wear of parts between 0 offset and -90 offset? thats what id like to know
  22. Aug 29, 2024 at 7:35 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    By the sound of it, the amount of leverage is the difference.
    I just got new wheels bearings on my front and am in the process of having the rears done. But I also have 250k miles and abuse my truck off road when ever I get the chance.
    khooiii and oscardog86 like this.
  23. Aug 29, 2024 at 7:47 PM
    An 8” wide wheel with 4.5” backspacing is a zero offset setup per the online calculators. So if I pull my spacers, I’ll be 0 offset.
    455h0le_dachshund likes this.
  24. Aug 29, 2024 at 7:49 PM
    WTHamIdoing
    Eric
  25. Aug 29, 2024 at 7:52 PM
    Depends on wheel width. EDIT: What I mean, at 10" wheel, 0 offset is 5.5 backspace and you're slapping spring. 7" wheel at 0 offset is 4.25 backspace and maybe would look alright?
    See the megathread. All the info on wheel offset and backspacing you need is in the wheel and tire section.
  26. Aug 29, 2024 at 7:59 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Sounds about right.
  27. Aug 29, 2024 at 8:01 PM
  28. Aug 30, 2024 at 4:02 AM
    Weejub
    Weejub New Member
    Jamie
    Pittsboro, NC US
    2001 AC TRD
    Bilstein 6112 - Set @ 5/4; General Spring: 2000 - 2006 Toyota Tundra heavy duty rear leaf spring, 5(4/1) leaves
    You consider the Eaton Elockers? I haven't heard a ton about them, but not as active as I was on cruiser boards :(
  29. Aug 30, 2024 at 4:51 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I have one in my rear diff. Been installed for like 3 years. No complaints.
    I'm not sure if Toyota used Eaton or not for the first gen Tacomas e-locker, but I had two TRD Tacos with the rear e-lockers and loved em.
    oscardog86 and Weejub[QUOTED] like this.
  30. Aug 30, 2024 at 5:14 AM
    Weejub
    Weejub New Member
    Jamie
    Pittsboro, NC US
    2001 AC TRD
    I know over on the Land Cruiser boards, there are a lot going in, just hadn't heard much - thanks for the update!!
