  1. Aug 15, 2024 at 4:30 PM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    I've got the Master Tailgaters black metal one on my truck. It's been great, install was easy. I bought direct from Master Tailgaters, probably overpaid... I think I paid $159... didn't realize they sold through Amazon
    455h0le_dachshund likes this.
  2. Aug 15, 2024 at 4:30 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    isn't there a square stake pocket cap built into the bed rail cap that can be removed(or drilled for wire & grommet)? I seem to recall there being one.
    kodyquist21[QUOTED] likes this.
  3. Aug 15, 2024 at 4:35 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    All the more justification to get a nice tight set of off-road bumpers.
  4. Aug 15, 2024 at 4:59 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    That looks like the one I ordered, will try to find my install post, I think I linked to it.
    Yep, hur it go.
  5. Aug 15, 2024 at 5:06 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    @VR6T is your latch busted or you just want a camera? I found another comment of mine where I recommend buying just the camera and drilling your OEM latch handle if yours is good.
  6. Aug 15, 2024 at 5:26 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    I'm going to relocate my camera. Latch is just fine
  7. Aug 15, 2024 at 7:18 PM
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    All of the FSMs (2004/2005/2006) for the larger 17 mm LBJ bolts first introduced in 04 show a torque value of 48 ft lb. I've read on here that these bolts should be tightened to 59 ft lb and, perhaps, can be tightened to 80 ft lb. I've read a lot on this forum but don't recall reading a thread where these upward values are directly referenced and sourced. Maybe I just missed it or suffered a memory lapse.
    Where do these values come from and is there a link? Is it tied to a specific bolt (part #) since there are at least 3 different Toyota LBJ bolts that I know can be used on our later year trucks with the big balls. I have two sets of them myself:
    90105-A0187
    90105-12316
    Depending on the TMC parts dealership, one of these bolts shows up in their system. I talked to Toyota South and they sent me the installation page from the manual - which I already had (Hats off to des2mtn) as well as the 05-06 manual (Thanks, Shifty for posting).
    Just one of the things I am sorting thru before replacing week after next.
  8. Aug 15, 2024 at 7:25 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    https://www.tundras.com/threads/spiker-engineering-lower-ball-joint-bolt-test-1st-gen.111746/
    FrenchToasty likes this.
  9. Aug 15, 2024 at 7:34 PM
    TnPlowboy
    But that just references, compares, and discusses bolts for the smaller LBJs and their 14 mm bolts (with or without protectors) found in Tacomas and early 1st Gen Tundras 01-03 and a few 04s, doesn't it?
    I seem to recall a couple of followup comms, maybe with ARP, that discussed the longer bolts and a few other things but haven't been able to locate it since. Plus, I don't quite remember what was said.
  10. Aug 15, 2024 at 7:41 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Read further through the thread.
    https://www.tundras.com/threads/spi...-bolt-test-1st-gen.111746/page-3#post-2966429
  11. Aug 15, 2024 at 7:49 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I hope that 670 works better for you. Maybe it’s not meant for bright sun. I couldn’t see that screen in dawn or dusk. Let us know.
  12. Aug 15, 2024 at 7:51 PM
    shifty` Inside his chest they found ten thousand pencils
    Beyond that, the values are in the FSM, but we have no digital copy of the FAM for ‘00-‘02, ‘04, and ‘05. The ones being passed around are for ‘03 and ‘06.
    That said, @assassin10000 is on point as usual. And there is a typo I. The FSM, it says 48 in one spot and 59 in almost all others. I opted for larger value on my ‘06 and probably need to edit my recent reply where I think I said 48 again. Dammit.
  13. Aug 15, 2024 at 7:53 PM
    I went 48# on the black boots with the protectors. Split the difference. It’s pretty darn tight.
  14. Aug 15, 2024 at 7:53 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You did
  15. Aug 15, 2024 at 7:56 PM
    VR6T
    Gotta fuck with them brightness settings. It's my only bitch about alpines
  16. Aug 15, 2024 at 7:58 PM
    VR6T
    I defaulted to the 59 lbft for mine as I was getting conflicting info on the interwebs
  17. Aug 15, 2024 at 7:58 PM
    VR6T
    I mean for a state that sure like their 1st and 2nd cousin you picked a hell of a user name lmfao.
  18. Aug 15, 2024 at 7:59 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I maxed them out. Updated firmware, customer service, etc. still sucked ass. Maybe it just didn’t do well with the altitude up here. Not so alpine after all.
  19. Aug 15, 2024 at 8:00 PM
    VR6T
    Maybe you just got a shit screen. I had my OEM screen do that in my 12 JSW, luckily for me there was an open recall through VW on it
  20. Aug 15, 2024 at 8:01 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Y'all gonna shit, because I directly disobeyed orders and hit it with the impact and some blue loctite. I've had to remove my spindles two other times prior for suspension swaps and both times popped off the lbj bolts and reused em, with the impact, no loctite, and was fine for 6 years of on and off road abuse. But this time I did use new bolts and loctite... So that's nice. :rofl:
  21. Aug 15, 2024 at 8:02 PM
    VR6T
    SMFH Assdog, smfh
  22. Aug 15, 2024 at 8:03 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You can take the lubie out of the lube shop, but you can't take the lube shop out of the lubie. :thumbsup:
    VR6T[QUOTED] likes this.
  23. Aug 15, 2024 at 8:58 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So I was babysitting the job at the airport today and one of the Jman says, "hey, I think this is mo old truck" and proceeds to show me that bottom picture. I said "hey, I know that guy!". So I showed him those pics we took back in December. Small world.
  24. Aug 15, 2024 at 8:58 PM
    TnPlowboy
    FWIW, Tyler 208 posted FSM torque values for the various Tundras at the end of his LBJ video found here:
    https://youtu.be/aQt_3nxOtNs?feature=shared
    I found it interesting that TMC obviously changed bolt types and sizes with the introduction of the rubber protector in 2001 (mixed year that required a longer bolt) and the larger 17 mm bolt heads in 2004 (also a mixed year).
    LBJ Components_2005-2006.jpg LBJ Components_2004.jpg LBJ Components_2003.jpg LBJ Components_2002.jpg LBJ Components_2001.jpg LBJ Components_2000.jpg
  25. Aug 15, 2024 at 9:05 PM
    TnPlowboy
    Lol...Coming from Texas where family relations take on a whole new meaning if you get my drift.
    shifty` likes this.
  26. Aug 15, 2024 at 9:11 PM
    VR6T
    Whoa whoa whoa..... whoa, just hold yer dip can their buddy. This ain't Alabama, Texarkana or Arkansas now. This is Central Texas. Learn you geography lol
    shifty` likes this.
  27. Aug 15, 2024 at 9:13 PM
    TnPlowboy
    I've been to Texas...spent a good chunk of my career in and out of there and 12 more in AK working on O&G and other resources.
    Would TX exist were it not for the brave Volunteers of Tennessee? Go Vols!
  28. Aug 15, 2024 at 9:14 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Boys, let's not fight over whose got the hotter cousin...
  29. Aug 15, 2024 at 10:06 PM
    VR6T
    You're right Assdog, we all know we got the best BBq and gas stations.
  30. Aug 16, 2024 at 3:26 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    They have oil and gas in Arkansas? Neat!
    KNABORES likes this.
