  1. Aug 11, 2024 at 11:43 AM
    AlexiosTundra02
    AlexiosTundra02 New Member
    Ventura County
    2002 Tundra AC 4WD
    IMG_1505.jpg IMG_1281.jpg Picked her up 12/23/23. 166k miles for $7k
    - FJ wheels w falkens
    - camper
    - Rear differential service for leak
    - Bilstein 5100 rear and front
    - new LCA
    - new radio unit for wireless Apple CarPlay
  2. Aug 11, 2024 at 12:25 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Different plugs on the same engine??
    bmf4069, VR6T, Jack McCarthy and 2 others like this.
  3. Aug 11, 2024 at 12:30 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    Question is will it fit in the tundra?
  4. Aug 11, 2024 at 12:40 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  5. Aug 11, 2024 at 12:40 PM
    shifty` Inside his chest they found ten thousand pencils
    I'd like to see someone find out.
    455h0le_dachshund likes this.
  6. Aug 11, 2024 at 12:49 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Yeah in the bed maybe. Make it a mid engine design for a regular cab Tundra.
    Looks like it takes 16 quarts of oil though from the size of that oil pan if it’s not deceiving me.
    Kimosabe and 455h0le_dachshund like this.
  7. Aug 11, 2024 at 12:49 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I'm just trying to imagine how the lower end of that all comes together... holy shit what a behemoth.
    Never seen that engine, like one with the heads off.
    But then I've never put 2 different kinds of plugs in an engine before either.
    A lot of life passes me right by, and I'm perfectly ok with that. I'm just along for the ride.
  8. Aug 11, 2024 at 1:11 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Possibilities are endless. However, as long as you're not gettin too crazy with it, most leaf packs designed for our trucks specifically, will bolt up to the original mounting points. The springs get longer with more lift because they have more arch to them. Measure eye to eye and they'll be close to the same
    You can beef up the hangers, shackles, perches, etc. with stuff you'll find here https://archivegarage.com/
    check out the resource center link too. Lotsa good info, even if you buy from somewhere else
  9. Aug 11, 2024 at 2:30 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    which is exactly why i still want to one day convert my AC truck to a long 8’ bed AC.
    This is the grass clippings from just mowing the lawn. And if you really squint, you can see the Baja Design S2 Sport wide cornering headlights on the John Deere. The BD’s have pretty much the same wattage at the OEM JD 1156 matchstick headlights. That’s right, i have enough light now that i can now mow at 11pm!
  10. Aug 11, 2024 at 2:59 PM
    whodatschrome
    lots of dents
    Lunch box locker! I’ve installed them in the front and back of CJ7 waaay back before the turn of the century. They worked pretty well for a couple years…until i bent the axle housing and the Lock Right quit locking. And of course it happened at the most inopportune time. Luckily it was only a 5 mile walk home.
    I got ride of my Lock-Rights (and swapped axles) and went with a temporary “lincoln locker”. I’ve welded up multiple diffs with my welder…maybe around 6 different housings? More reliable would be a full spool. I currently have two CJ’s with spools, but they kinda suck on the pavement.
  11. Aug 11, 2024 at 3:05 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Sick! in a good way.
    The only thing the light on my Deere is good for is draining the battery. Im on the fence about its replacement. A 48-60" cut zero turn, or about a dozen goats. Leaning towards the goats, because that's what Dale wants.
    Edit to stay on topic:
    I have been welding the flatbed over the last few days. Tig on not the cleanest prepped joints and no shielding gas on the backside :thumbsup: good enough for who it's for.
    bmf4069, oscardog86, BroHon and 6 others like this.
  12. Aug 11, 2024 at 3:16 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Dale wants to be a herder, doesn't he?
  13. Aug 11, 2024 at 4:34 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    I set had my diff set to 15 backlash. Some advise tighter like 9-11. I have had zero issues. I would think with that type of locker you are going to want to change diff fluid at 259 miles, 500 miles, then 2000 k to inspect magnet. You should only have minor metal glitter maybe first two. If your not switching R&P its much less involved.
  14. Aug 11, 2024 at 5:09 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Changed out my dash bezel for a like new junk yard AC bezel. My original bezel had sun damage (pictured below). swapped over the rear defrost button, vents and electronics.
    Anyone with loose air vents. Might have Figured out what causes this. Look to see if this plastic pcs is missing or broken off (D shaped plastic pc in the photo) on the vent side. Mine was attached to the bezel still.
    when I moved over the vents I found that they were very loose and felt defeated after all that work. But added that plastic pc and back to firm vents
    bmf4069, BroHon, ToyotaDude and 5 others like this.
  15. Aug 11, 2024 at 5:44 PM
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    those are in the actual vents?
    jerryallday[QUOTED] likes this.
  16. Aug 11, 2024 at 6:06 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Not sure if it part of the bezel or vent now. Looking at vents online (eBay) and that pc is missing on the vents. Mine looks like it’s broken off tho
    On my next junk yard trip I will check other trucks and sequoias. I get them if anyone needs them for their loose vents
    shifty` likes this.
  17. Aug 11, 2024 at 7:35 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'm interested in a fog light button
    Mr.bee likes this.
  18. Aug 11, 2024 at 7:38 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Send me a message I have one currently, it will be the one with the white
  19. Aug 11, 2024 at 7:42 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    look for another & combo the shipping.
  20. Aug 11, 2024 at 7:51 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Kinda thinking i might use this as an aux reverse light.
    Might see if i can get a twin when i go to town tomorrow & recess em into the rear bumper.
    BroHon and 455h0le_dachshund like this.
  21. Aug 12, 2024 at 6:58 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Early morning trucktivities. This tree choked itself by growing through a rock.
    Was hoping to use the hole to plant a tree, but its not deep enough, and above a bigger rock.
    BroHon and FishNinja like this.
  22. Aug 12, 2024 at 8:25 AM
    MK18_Obe
    MK18_Obe New Member
    AZ
    2004 DC SR5 4x4
    Welp Murphy's Law strikes again. Attempted to do drivers CV axle(inner and outer boot rip) and both lower ball joints last night. A few hiccups but managed to stroll along. Came down to the last bolt(managed to get castle nut off), passengers side lower ball joint was seized pretty bad to the lower control arm. I'll try again tonight.
    Parts are OEM btw
    Bought2Pull, BroHon and oscardog86 like this.
  23. Aug 12, 2024 at 8:30 AM
    Jack McCarthy
    Bill
    North of Boston
    I’d suggest an impact wrench if you have one and not too much torque, just enough to get it to break free.
    MK18_Obe[QUOTED] likes this.
  24. Aug 12, 2024 at 8:34 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Went to the salvage yard and got the passenger mirror back cover I needed to complete the set. Found another V6 manual trans 4wd tundra just like mine! Was hoping to grab a CV axle to use as a spare but these were totally rusted out. Cool to see another of these tundras in the wild though.
    bmf4069, Bought2Pull and BroHon like this.
  25. Aug 12, 2024 at 8:34 AM
    MK18_Obe
    MK18_Obe New Member
    AZ
    2004 DC SR5 4x4
    I got the castle nut off. I cant break the ball joint off from the lower control arm. Smacked the crap out of it for an hour and a half. Decided to stop because I didn't want the neighbors to get annoyed haha.
  26. Aug 12, 2024 at 8:35 AM
    oscardog86
    Southern California
    I believe I used the ball joint wedge tool the you hammer into there to spread them apart. Harbor freight has those
    Or am i thinking of the wrong part that you are trying to get apart?
  27. Aug 12, 2024 at 8:37 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    assuming your not trying to save so a pickle fork, heat
    oscardog86, FrenchToasty and MK18_Obe like this.
  28. Aug 12, 2024 at 8:38 AM
    MK18_Obe
    MK18_Obe New Member
    AZ
    2004 DC SR5 4x4
    One of these? I was thinking of doing that since I won't need the old ball joint, can damage it as much as needed to get if off.
    oscardog86[QUOTED] likes this.
  29. Aug 12, 2024 at 8:40 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I prefer Fire and blunt force trauma, but I am an unrefined animal.
    @oscardog86 Pickle fork :thumbsup:
  30. Aug 12, 2024 at 8:44 AM
    MK18_Obe
    MK18_Obe New Member
    AZ
    2004 DC SR5 4x4
    I was trying to channel my inner Neanderthal but my extra medium hands couldn't generate enough energy.
