  1. Jun 23, 2024 at 8:45 AM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    100 degrees out? Sure, let's install a new floating screen head unit. It is nice, however. https://www.bestbuy.com/site/pionee...dia-dm-receiver-black/6530257.p?skuId=6530257
    I think the 9" unit is the ideal size for our trucks. Much better than the small recessed double din units and doesn't overlap the HVAC controls or vents like the 10.1" units.
    Used a single to double din adpater, which mounts directly to the frame and a wiring harness. Have the rear view camera wired and it's HD, which is great. Wireless CarPlay, which is life-changing and everything else seems to be working.
    I didn't have the JBL audio system on my truck or steering wheel controls, so I didn't have to worry about those. Pretty straightforward once I got everything apart.IMG_8925.jpg IMG_8927.jpg
  2. Jun 23, 2024 at 9:12 AM
    Curiousity more than anything, but does the screen lift off so you can remove the dash bezel, or are you pulling out the entire radio with the bezel somehow? Clearly the screen is too large to fit thru the bezel hole, right?
    I agree that looks a hell of a lot better than the >9" screen units. I didn't want to use the Alpine Halo 11" (511) units after seeing the fitment. I know Alpine also has a 9" (509) unit that's similar. I like the options, but I have no confidence someone won't see that as a good reason to smash my window when I leave the truck on a trail and I'm off on a 10-15 mile hike, just to yoink my radio. Then I'm out $$ for the glass and tuneless for a while. It's the one bonus about my Alpine W650, it looks fairly stock in the dash. I feel pretty safe parking in the city or on trails for long periods.
    oscardog86 likes this.
  3. Jun 23, 2024 at 9:34 AM
    Openbaffle
    It's really not removable. You have to mount the screen to the 1 DIN unit after the plastic bezel goes back on. It's 4 screws to mount the screen to the bracket and then there is a plastic cover that buttons everything up. You'd have to work at it to get it off.
  4. Jun 23, 2024 at 9:57 AM
    That one have wireless CarPlay?
  5. Jun 23, 2024 at 10:06 AM
    Openbaffle
    Yes this one has wireless CarPlay, works really nice.
  6. Jun 23, 2024 at 10:40 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Post camping wash day.
    Adam's Wheel and Tire cleaner seemed to work well. It's almost time for new rubber. These K bro 2's have served me well for 5 years now.
  7. Jun 23, 2024 at 10:52 AM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Quick stupid question…are the stock rear bumpers compatible for all years?
  8. Jun 23, 2024 at 10:59 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Its hard to make me jelly of a truck with black wheels, but you've got it nailed. White paint too, screams 'i was loved as a worktruck.'
    drove mine today for the first time since NM. Its still not as fast as the titan, but is happy to be unhooked from that trailer. Moderate inspection finds all is well, no new leaks, tires are wearing right, tires are still at 42/40. Kinda wanna do a drain & fill, my oil pressure gauge seems to have more pressure than normal, but w/e. 4.56's would put 60-65 right in the sweet spot for towing. Maybe 4.88 if i get big tired.
    bmf4069, FirstGenVol and FrenchToasty like this.
  9. Jun 23, 2024 at 11:00 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    i believe so, and you can see where the DC's compensate. Sequoia is sequoia only, most likely.
    805Tundra[QUOTED] likes this.
  10. Jun 23, 2024 at 11:00 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
  11. Jun 23, 2024 at 11:34 AM
    What’s the next tire setup gonna be?
    Mr.bee likes this.
  12. Jun 23, 2024 at 11:46 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was almost set on pizza cutters but now I'm leaning towards my current size, 285/70/17. I like the stance and way they look. Undecided on which tire. Everyone seems to love the Falken Wildpeak and they are slightly less than others, but I'm also tempted to try the improved KO3.
    I'll likely stick with load range C for better ride quality and MPG. Tires keep getting heavier which I'm not a fan of.
  13. Jun 23, 2024 at 11:53 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Think i might do toyo m55's, need to find em cheaper. 255/85 if i lift it. 285/75 if i get big boy springs and a worthy bumper.
    805Tundra and FrenchToasty like this.
  14. Jun 23, 2024 at 1:25 PM
    805Tundra
    Ben
    Central Coast
    thanks! I kind of figured but wanted to make sure
  15. Jun 23, 2024 at 1:25 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    CEL light popped up with the pesky P1126 code which I hadn't seen in several years. I cleaned the throttle body with a rag and some CRC TB Cleaner. Actually looked pretty clean before I started. Also cleaned the MAF w/ CRC MAF cleaner. Notice the negative battery terminals although clean on the outside was dry against the post with some mild corrosion so I cleaned those and applied new felt pads and grease. CEL went out and running good. Did notice the ventilation hose #2 that goes from right valve cover to the air box Toyota P/N 12262-0F010 is starting to split. Appears to be discontinued. It has different diameters at each end. Anyone found a substitute? Thanks.
    oscardog86 and shifty` like this.
  16. Jun 23, 2024 at 1:29 PM
    805Tundra
    Ben
    Central Coast
    definitely been going back and forth on if I want 285/75 or 285/70. I’m thinking 285/75. Whatever tire I get I can’t wait to get rid of these mud tires though, so obnoxious. Definitely interested in the KO3s as well
  17. Jun 23, 2024 at 1:31 PM
    I’m tempted to be more aggressive with tire size and tread pattern, but will likely stick with 265/75/16 Wildpeaks since I still need to tow a TT. The larger heavier tires are just too much of a compromise and I swore I would never buy mud tires again.
    shifty` likes this.
  18. Jun 23, 2024 at 2:28 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Why not tow with the Tundra that has twice the power?
  19. Jun 23, 2024 at 3:09 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Not today, but I went to remove the block lift in the rear of the truck and there appears to be a stud or the remains of the leaf spring bolt stuck in the spring perch.
    I couldn’t get it out so I’ll have to figure something out.
    Maybe heat and drill?
  20. Jun 23, 2024 at 3:23 PM
    That Tundra won’t be around much longer
    455h0le_dachshund likes this.
  21. Jun 23, 2024 at 5:08 PM
    Did you dress the rubber with anything after, or is that how Adam’s left it? If it truly gets tires that black I need to get some. Bleached white will get all the oily residue out of rubber, but I’m never happy with the haze it leaves behind. I may need to check that stuff out.
  22. Jun 23, 2024 at 5:25 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No I sprayed the tires down with a Chemical Guys dressing but that was my first time using Adam's and I was impressed.
    shifty`[QUOTED] likes this.
  23. Jun 23, 2024 at 5:27 PM
    I think I ultimately need to find a good tire dressing. Something that doesn’t collect more grime, and isn’t overly shiny. I haven’t found one yet.
  24. Jun 23, 2024 at 5:31 PM
    Believe or not, the Armor-all Foaming tire dressing has been on the least shiny and grimy one I’ve used. And you can just foam it on and let it be. I cut a cardboard wheel protector out the size of the wheel and hold it up against the wheel while spraying to keep the overspray off of the wheels. Just looks black after a day or so, no real shine or evidence of a dressing to speak of.
    immediately after applying:
  25. Jun 23, 2024 at 5:32 PM
    I’ve never used, hafta try it out.
    I recently tried 303 and it kinda worked. Better than most. Still too shiny though.
  26. Jun 23, 2024 at 5:35 PM
    If your into shine though, the black magic foaming tire shine has a nice even shine that lasts for days. Not too grimy either. A little too extra for the Tundra though.
    black magic shine:
    BroHon likes this.
  27. Jun 23, 2024 at 5:42 PM
    Yeah, that’s so shiny, I feel like I’m looking at another Sheen brother.
    FrenchToasty likes this.
  28. Jun 23, 2024 at 5:52 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Chemical Guys silk shine works well. It's water based and I've read that's the key to avoiding the oily residue, dust collection. I use it on the dash too and it protects without leaving a greasy mess.
    FrenchToasty and shifty`[QUOTED] like this.
  29. Jun 23, 2024 at 5:54 PM
  30. Jun 23, 2024 at 6:09 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I looked this up and got some really really different answers. Probably shouldn't have done that on work computers. LOL
    oscardog86 and Weejub like this.
