  1. Jun 6, 2024 at 6:04 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    metalpete, bmf4069 and Azblue[QUOTED] like this.
  2. Jun 6, 2024 at 6:14 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    About to spring a leak?!
    des2mtn, metalpete[QUOTED] and BroHon like this.
  3. Jun 6, 2024 at 6:17 PM
    ToyotaDude
    ToyotaDude Member
    Nice caster!
    BroHon likes this.
  4. Jun 6, 2024 at 6:22 PM
    ToyotaDude
    ToyotaDude Member
    What height was the rear to install the pinion shim? Might consider it but haven't had issues AFAIK. So you're lower now and took it out?
  5. Jun 6, 2024 at 7:30 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I am finding that to be true...These just weren't sealed. Corrosion got in, did its work.
    If you're talking about the 4-pin that's actually a 3-pin, I don't think so...but yes that confuses me. There is no wire in that "node". Never was. It's sealed, no hole missing a wire. Just a node sticking up. I assume it gets its ground from somewhere else...I just zip-tied all that stuff up out of the way otherwise I'd take a photo. But you can see if you zoom into the photo, there's no hole for a wire on that node.
    The bad news is that the new Tekonsha wiring isn't quite as plug & play as I expected. I haven't thought long enough to describe what confuses me about it, though I tried in the thread over in the towing forum. I'll figure it out. At least my efforts to look closer at what wires go where before I started cutting things led me to find that corroded, almost exploded connection.
    Good news is that since I couldn't install the new wiring harness, I installed the new 7-pin socket using the existing wiring, newly cleaned and reconnected, and I have trailer lights! Both blinker, tail lights. Haven't tried brakes yet but I'll set the phone up on camera to see if they work. I'm confident they do.
    I'm sure that corroded connection was the sole culprit, but I'm absolutely happy I dug in as far as I did and cleaned or re-did all the other connections.
  6. Jun 6, 2024 at 7:34 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    She'll be alright. Time to shop the internet for car parts!
  7. Jun 6, 2024 at 7:44 PM
    metalpete
    ID
    But...
    Just strange. Who cares though? You got the lights working, nice job!
  8. Jun 6, 2024 at 7:48 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
  9. Jun 6, 2024 at 7:49 PM
    MT-Tundra
    Montana
    Yes, and thank you for the help trouble shooting.
    I'll need to cut the zip ties and electrical tape tucking everything up out of the way once I learn more about the right way to connect the new wiring harness. When I do that I'll look closer at that 4-pin connection. Like you said it works, so...
    metalpete likes this.
  10. Jun 6, 2024 at 7:55 PM
    VR6T
    Voss and Mr.bee like this.
  11. Jun 6, 2024 at 8:03 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The Black Mamba likes this.
  12. Jun 7, 2024 at 1:51 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  13. Jun 7, 2024 at 1:56 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Tub them wheel wells!
  14. Jun 7, 2024 at 2:23 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I was trying. Her parents are not as jazzed about it as she is lol
    NUDRAT and shifty` like this.
  15. Jun 7, 2024 at 3:58 AM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Yes, I am lower now, about 1" lower total, which I am OK with. I always felt I had too much height with the OMEs and 2885 coils, plus I never liked using the block in the back. I still may drop the front another .5" after it settles. I've got about 200 miles on the new setup now. It's sitting pretty level right now, maybe the front up just a 1/4"-1/2" or so. The pinion angle shim was just something that I kept as it was recommended with the extra leaf spring AFAIK.
    ToyotaDude[QUOTED] and shifty` like this.
  16. Jun 7, 2024 at 5:06 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Tire rotation time. I always have better luck if I don't make an appointment.
  17. Jun 7, 2024 at 6:06 AM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    About 4500.
  18. Jun 7, 2024 at 6:09 AM
    shifty` Inside his chest they found ten thousand pencils
    As much as I want to, I just can't do it. IIRC in the past, you said the place you go only torques and not with the quick sticks. I can't trust shops in the ATL area to use anything but an impact.
    To that point, I've been threatening for years to get one of those portable floor jack systems that'll lift your vehicle from the framerails to get all 4 wheels off the ground. They've really come down in price in the last 10yrs. I may need to pull the trigger on one sooner than later.
  19. Jun 7, 2024 at 6:23 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    FGT - First Gen T100
    Buy a T100
    Voss[QUOTED] and FrenchToasty like this.
  20. Jun 7, 2024 at 6:33 AM
    After starting my lugs by hand, I use torque sticks to seat and pre torque mine with my impact. Every time I check them against a torque wrench, they are right on. Tools are tools. They just need to be used appropriately.
  21. Jun 7, 2024 at 7:09 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You don't have a Discount Tire near you? They always use a torque wrench at mine.
    455h0le_dachshund and oscardog86 like this.
  22. Jun 7, 2024 at 7:12 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    sounds like a Dodge truck! lol
    455h0le_dachshund likes this.
  23. Jun 7, 2024 at 7:12 AM
    MT-Tundra
    Montana
    I just get sick of taking the time out of my day to hang out at the shop. One of the main reasons I bought a floor jack was so I could rotate my tires. Still kind of a janky operation but I get it done. I'd rather take 20 minutes after work or on a weekend than an hour at the shop. Even though of course a free rotation comes with buying the tires from them.
    ToyotaDude and oscardog86 like this.
  24. Jun 7, 2024 at 7:27 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Yea I politely asked my discount tire if they could use a torque wrench for my lugs, and they did.
  25. Jun 7, 2024 at 7:34 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Decided for shits and giggles to measure the capacitance, impedance and inductance of my Denso secondary coil to the TRQ replacement with my new IET knockoff LCR meter.
    TRQ:
    2k impedance
    1.2H inductance
    20 pF capacitance
    Denso:
    25k impedance
    4.0H inductance
    5 pF capacitance
    Wow, now I know why they’re so much more expensive than aftermarket. I really wonder how good of a spark I’m getting with these TRQs. :eek2:
    bmf4069, w666, NUDRAT and 4 others like this.
  26. Jun 7, 2024 at 7:48 AM
    So, basically same.
  27. Jun 7, 2024 at 8:28 AM
    Jack McCarthy
    Bill
    North of Boston
    No. No, it’s not. :rofl:
    The inductance is roughly 1/4 the Denso coils. If the primary to secondary ratio for the two coils is the same, you have 4 times the voltage created with the Densos than you do the TRQs.
    KNABORES[QUOTED] likes this.
  28. Jun 7, 2024 at 8:51 AM
    VR6T
    Meh it was a good truck for the lost part
  29. Jun 7, 2024 at 8:53 AM
    VR6T
    I kindly ask discount tire to never touch my vehicle over the f*** again. I just throw the rims in the back of the truck drive them up there let them mail them put them back in the bed and I drive off and put them on myself. It's the Converse Texas location The manager there I forget to do his name he is such an incompetent a****** I don't understand how that place runs it all. So to save the guys the time and the headache of dealing with that manager I just mount them on the truck myself.
    oscardog86[QUOTED] likes this.
  30. Jun 7, 2024 at 9:05 AM
    VR6T
    CodyP and 455h0le_dachshund like this.
