  1. Jun 5, 2024 at 7:00 PM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    I don't think Davey would appreciate your tone.
    Jack McCarthy likes this.
  2. Jun 5, 2024 at 7:02 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  3. Jun 5, 2024 at 7:03 PM
    Sweet, changing planes in Dallas in 30 mins
  4. Jun 5, 2024 at 7:04 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  5. Jun 5, 2024 at 7:06 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    As long as you're offroading with hub centric spacers, you should be fine.
  6. Jun 5, 2024 at 7:10 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  7. Jun 5, 2024 at 7:16 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I thought you were already honorary status as is anyways
  8. Jun 5, 2024 at 7:17 PM
    I did grow up an hour from the Texas border
  9. Jun 6, 2024 at 5:01 AM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Been a while. Did some fun stuff this past week. Replaced u-joints and new carrier bearing. Fixed the tail seal in the process. Also got a pair of Fox 2.0 coilovers installed and fox rear shocks. OME that I installed two years ago had already failed. The ride has night and day differences between the Fox and OME. The clunk that I had when going over bumps at low speed is gone, and the vibrations from the failed carrier bearing have been erased. Feels like a new truck.IMG_8672.jpg IMG_8673.jpg IMG_8674.jpg IMG_8675.jpg IMG_8677.jpg IMG_8683.jpg
  10. Jun 6, 2024 at 5:45 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Which AAL is that?
    Truck looks good btw.
    I am always surprised to hear from you dra owners about OME difficulties. But it does happen a lot. Which is strange because I've only heard good things about OME from Tacoma owners
  11. Jun 6, 2024 at 7:39 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    My grandfather only ever went to 2 states. KY (the one he was born in), and I'm told he went to Indiana once.
    Never leaving one's county, that's pretty impressive!
    VR6T and Jack McCarthy[QUOTED] like this.
  12. Jun 6, 2024 at 10:33 AM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    What size wheel and tyre are you running?
  13. Jun 6, 2024 at 10:35 AM
    VR6T
    Kentuckian...... Big suprise. :rofl::rofl:
    @455h0le_dachshund @Mr.bee @bmf4069 @FishNinja @JakeJake
    NUDRAT, FishNinja and JakeJake like this.
  14. Jun 6, 2024 at 10:41 AM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    decided it was time to get after the rusted bed, so I got the wire wheel out… IMG_8305.jpg
    and then installed a Ute Bed.
  15. Jun 6, 2024 at 11:37 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Found the culprit for one of the noises in my front end. The hardline on my DS brakes touches the bottom of the spring at close-to-full-lock.
    :annoyed:
    The Black Mamba, oscardog86 and VR6T like this.
  16. Jun 6, 2024 at 12:06 PM
    VR6T
    Don't ya love it when it's so simply stupid that it pisses you off in the first place..... Drives me batty every time
    KNABORES likes this.
  17. Jun 6, 2024 at 12:40 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Kimosabe, Voss, FrenchToasty and 3 others like this.
  18. Jun 6, 2024 at 12:52 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Yea that UTE is pretty awesome! I feel in a few years Ill decide to make a flat bed camper type of build.
    I tried looking at the UTE website, wow is that a primitive site! haha
    455h0le_dachshund likes this.
  19. Jun 6, 2024 at 2:06 PM
    Openbaffle
    Well my dreaded P0172 and P0175 codes are back today. I thought I got it this past weekend when I did the spray in seafoam treatment into the throttle body, then unplugged the battery for 30 mins. All week it was fine and then today at a stoplight I heard the dreaded idle drop and shure enough CEL with the codes. GRRRRR.
    @455h0le_dachshund -- no AAL there; I ended up getting the HD spring from general spring. I do have the pinion angle shim in there, however. I had a 1" block that I removed when the Fox 2.0s were installed as I was able to drop the front a bit to level vs. the OME.
    @VR6T -- wheels are 275/70R17s—method roost rims in bronze.
    I am at a LOSS on the codes. Because it's intermittent and symmetrical, the odds of two failed O2 sensors seem zero. I've already replaced the MAF with OEM. Clean air filter (6 months old, Toyota OEM). I do have a SAIS delete...
  20. Jun 6, 2024 at 2:34 PM
    Arringtonpalmer
    Sam
    New Hampshire
    [QUOTE="oscardog86, post: 3609051, member: 28131”]
    I tried looking at the UTE website, wow is that a primitive site! haha[/QUOTE]
    yeah, the website made me think they weren’t in business anymore. They are, the owner is really cool. Product is great so far. I was looking for something between the ill fitting Aluma, and the over the top Norweld/MITS. This hit the spot for me.
    And aluminum because I’m so over rust.
    oscardog86 likes this.
  21. Jun 6, 2024 at 2:38 PM
    I'm trying to visualize that, can you draw up a pic? Just curious if I may have same going on..
    Hmm.... I mean, you could always unplug the bypass and see if it goes away. This is one of a couple reasons I really hate using aftermarket bypasses for stuff. What you're explaining should've ultimately been solved with the work you've done, unless it's an air leak causing it. I'd be suspicious...
  22. Jun 6, 2024 at 2:44 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    The flatbed is nice. The first Tundra I test drove was an access cab flatbed . More "ranch" looking than the Ute flatbed (it was a Hillsboro). I love the look of flatbeds. I would have bought it if it hadn't been 2wd. But I have to admit, a flatbed doesn't fit my lifestyle very well. I've been driving a pickup with a stock bed and topper for over 20 years and it would hurt to get rid of that secure storage space.
    The lightweight platform for a slide-in camper was the most compelling selling point of the flatbed.
  23. Jun 6, 2024 at 2:47 PM
    Openbaffle
    Right. I mean that is zero cost. This was the second bypass that I have installed. I also did the blocking plates. And I also have it wired to the starter circuit so I def. did it right (well I guess I didn't do it RIGHT since I didn't replace the SAIS). But yea. Good thing to try...
  24. Jun 6, 2024 at 2:51 PM
    VR6T
    I am chasing the same thing. It comes and goes. Bank 1 system too lean, and then bank one catalyst sensor issue. Only trips after the engine has been brought up to temp and driving faster than 35mph for 3 or more miles. It will not trip underload, aka driving at speed, and I get the same idol drop right before it trips. Can't figure it out for the life of me. Next step is to replace the headers and gaskets.
  25. Jun 6, 2024 at 2:53 PM
    FishNinja
    Lee
    06DC2wd
    if it redlines and nothing grenades itself. Send it.
  26. Jun 6, 2024 at 2:53 PM
    Openbaffle
    So I did the valve covers a couple of months ago to address an oil leak. I could do the long tube headers...I think Keith has another pair available :)
    ToyotaDude and 455h0le_dachshund like this.
  27. Jun 6, 2024 at 2:54 PM
    VR6T
    I can floor it, and nothing happens, as far as codes go. It's just a phantom pain in the ass. So IDK, maybe I have a partially clogged injector..... Again idk
  28. Jun 6, 2024 at 2:56 PM
    FishNinja
    Lee
    06DC2wd
    I've lived with my CEL coming and going now for years. YOLO
    VR6T[QUOTED] likes this.
  29. Jun 6, 2024 at 2:56 PM
    VR6T
    I'm gonna run shorties and delete my resonator at some point, step everything up to 2 inch and 2.5 inch going to get a new Borla 2.5" in to a 3“ out straight set muffler.
  30. Jun 6, 2024 at 3:00 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Do our truck have an idle air control valve?
