  1. May 23, 2024 at 9:24 AM
    shifty` Inside his chest they found ten thousand pencils
    MEOW, MOTHERFUCKER!!
  2. May 23, 2024 at 9:56 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Hey if you want that invertor, it's yours. PM me your address and I'll pack it up and get you a price on postage.
    **Full Disclosure: I never tested it, but it turned on and looked like it works since the owner had it hooked up still.
  3. May 23, 2024 at 10:32 AM
    Oldfart01
    Oldfart01 New Member
    PA
    2006 Silver Tundra SR5 DC 4.7
    ToyotaDude, BroHon, Voss and 10 others like this.
  4. May 23, 2024 at 10:49 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Glad you got that fog light issue fixed, I know it took all the strength you had to turn that ring! Haha
  5. May 23, 2024 at 1:28 PM
    phudz
    phudz
    Michigan
    2004 DC V8 4WD
    I'm already running the ATS HD leaf pack in the rear. Guess we'll see with time how far they settle.
    As for this noise... alignment seems to have made it quieter? I checked the steering rack bushings for play, and didn't notice any. Going to try disconnecting the sway bar later to see if I can rule that out.
  6. May 23, 2024 at 1:34 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The bypass seems to be causing fueling issues from what I can find. It’s also messing with the transmission shift schedule for some reason on mine I’m talking about removing the sais on the software of the ecm. Should prevent the limp mode issues. I’ve got a friend able to do it
  7. May 23, 2024 at 1:53 PM
    Which springs and which circlip?
    Wait for settle, 200ish miles or less if on bumpier roads. Then doublecheck your swaybar bushings after and make sure they're stil alright. Think about it. You just set them on suspension that'll settle. It has probably already settled a fraction of an inch. Those little increments will ultimately add up, and suddenly where you set the links may not be appropriate anymore.
    phudz[QUOTED] likes this.
  8. May 23, 2024 at 1:55 PM
    This ultimately supports the warning I toss out there about the bypass kits. And you're not the first person I've seen write similar. This is also not the only vehicle I've owned with an SAIS-like emissions function that doesn't play nicely with perf upgrades.
    FrenchToasty likes this.
  9. May 23, 2024 at 1:57 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    Aside for OEM who makes a good HD tie rod end? I have to look but at full lock on turn I'm getting a slight clunk when I start moving, it's both sides. And yes I used Moogs, did them when I first did the ball joints. I know I know...
  10. May 23, 2024 at 2:08 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Detroit axle.
    VR6T[QUOTED] likes this.
  11. May 23, 2024 at 3:03 PM
    phudz
    phudz
    Michigan
    2004 DC V8 4WD
    I went with the OME 2884s with perches on the lowest circlip. That's a good point, suppose I should wait till everything settles into place. Appreciate the 2 cents.
  12. May 23, 2024 at 3:27 PM
    VR6T
    Knowledge acquired
    Tundra2 likes this.
  13. May 23, 2024 at 4:05 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    Lower ball joints today. Pretty straightforward but my outer tie rod stud was spinning when trying to put the castle nut back on. Shot some wd on the threads and used the impact to snug it up, torqued down so should be good. Started to rain so passenger side tomorrow
  14. May 23, 2024 at 4:19 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I suspect it's because he modded his ECU
  15. May 23, 2024 at 4:55 PM
    Correct. Deletion/bypass kits often cause issues with performance improvements. Been screaming it from the rooftops for eons and been told some colorful things for my opinion along the way.
  16. May 23, 2024 at 5:07 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Not what I'm saying.
    He physically modded his ECU.
  17. May 23, 2024 at 5:18 PM
    Yup. I understood you. Bypass kits can be fine ... until you take something from OEM/factory to no-longer-OEM/factory. Stack chips, plug-in programmers, misc performance add-ons.
  18. May 23, 2024 at 5:28 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Luckily for me, mines fine with mostly the same power mods, but a VF Tune.
    I've heard about people having issues with the Hewitt in combo with the URD MAF calibrator. I was gonna ing to buy one and take my chances before VF tuner came out with our tunes.
    I have enough issues with my other modded truck haha. I think when it's inspection is due in January, I'll replace the cats with Magnaflows. I think that should do the truck. I hope it does. Then I just gotta wait for my ECU Cal ID to be cracked. I wish URD made a MAF calibrator for the 00-04. They do have a universal unit that isn't plug in play. But Eff that
  19. May 23, 2024 at 5:38 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    seems Detroit axel has decent parts
  20. May 23, 2024 at 6:26 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Yep that happens but is something I tend to forget after 100,000 miles. Putting the bottle jack under it to press the joint together a bit is usually all it takes to get that nut off or back on, if the stud is spinning.
    In other news...I scanned through the cab water leak thread a few times after noticing discoloration along the entire edge of my carpet. Today we had a couple inches of heavy wet snow, which melted all day. Perfect time to investigate, because I also noticed most of my cowl grommets are completely MIA. Sure enough, dripping right here. Guessing the driver side does the same, but I'm parked on an angle so all the water is running toward the passenger side.
    Luckily, since I already knew I was missing grommets, I have some on their way. This confirms it was money well spent.
    Tlar25, Voss, hammeron and 2 others like this.
  21. May 23, 2024 at 7:01 PM
    VR6T
    And prices
  22. May 23, 2024 at 7:14 PM
    Nope. It’s just one, sometimes two cowl fasteners just above the fresh intake box.
    BroHon likes this.
  23. May 23, 2024 at 7:24 PM
    MT-Tundra
    Montana
    Hm, ok. Makes sense though, no staining on the carpet on the driver side opposite where it's dripping on the passenger side. I wonder whether the previous owner did his own leak-fixing from time to time. When I say the entire edge of my carpet is stained, I mean the entire perimeter of it is a slightly darker color. All along the passenger and driver side doors. To the point where I don't think it could just be the cowl leak anyway. Must be door gaskets. They're dry today, so I figure it's either something the PO addressed, or it only happens driving on wet roads with water spraying up at the door bottoms. Guess the car wash is a good place to test that theory...
  24. May 23, 2024 at 7:31 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I think we've all seen that exact staining your talking about when looking at sales adds... Mine has it too, I swear it wicks back along there because my doors aren't leaking.
  25. May 23, 2024 at 11:26 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    My ECU is tuned/modded. By pass kit for over 3 years, zero issues. Plus URD MAF Calibrator.
  26. May 23, 2024 at 11:28 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Now I'm worried about getting a VF tune, if it messes with my SAIS by pass.
  27. May 23, 2024 at 11:56 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    IIRC he did more than tune his ECU, I believe he had it physically modified. I couldn't comment on it beyond that, being as this is from memory and I don't know the details
  28. May 23, 2024 at 11:57 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It shouldn't.
    It hasn't on my 06. Thing runs like a top with the VF tune, JBA long tubes, Dirty Deeds 12 hole injectors & exhaust, Airaid intake tube, and Hewitt bypass. I ran it with these mods minus the tune for a few years.
    My 03, on the other hand, keeps popping a CEL for p0420 and p0430, with the same off brand cats as my 06, JBA longtubes, TRD catback, Volant intake, and Dirty Deeds 12 holes.
    It of course doesn't have a bypass or a tune.
    I would assume a decent tune would render the URD MAF calibrator redundant. Curious why you use it and a tune.
  29. May 24, 2024 at 2:45 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Good to know. I originally installed the URD MAF Calibrator with tune for it before sending in my ECU to R9K to maximize my power gains. It was nice for a while but I wanted more, hence the R9K tune, which I don't think gained much other than removing the governor. Fun times past 95 MPH. LOL.
  30. May 24, 2024 at 2:46 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Ah I see. Makes sense now.
