  1. May 20, 2024 at 5:56 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Nice, any Dyno results? what changes does he do on VF Tune?
  2. May 20, 2024 at 5:56 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah it's getting hot and I'm broke AF. So the truck ain't going anywhere anytime soon unfortunately
  3. May 20, 2024 at 5:58 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    No dyno. But I'd like do one some time. Trucks been having some major maintenance items (wheel bearings) that needed attention
  4. May 20, 2024 at 5:59 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    @KNABORES @KingSequioa007 @455h0le_dachshund
    They did the graph in MPH since they didn't have a way for spark reference for cylinder 1. If it helps, the torque split (point where HP and TQ diverge) on a dyno is always at 5252RPM.
    A lot of different companies offer their version of the VF Tuner that they can flash into your ECU. Storm Peacock and Yota Works were two different companies I reached out to for custom tune.
    In the end I chose to get the VF Tuner directly from the source so that I can make my own maps. With the amount and variety of mods I want to explore Storm Peacock and Yota Works couldn't offer a custom tune for every step of the way.
    Gears, cams, supercharger, high PSI supercharger, then E85. Those mentioned companies can help with some, but not the entirety of what I needed.
  5. May 20, 2024 at 5:59 AM
    Have a Link?
    455h0le_dachshund likes this.
  6. May 20, 2024 at 6:01 AM
    Riverdale21
    OTP ATL
    I'm still waiting on my VF Tuner, almost 4 weeks later. I ordered the day before they released their Gen 4 support so they are back ordered due to everyone (consumers and tuners) ordering theirs for the newer models.
    Hand to heart I will post a dyno of the 'as delivered' 2UZFE VVTI 93 octane tune from VF. It may be different from the Yota Works results because they make their own version of the tune.
  7. May 20, 2024 at 6:10 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
  8. May 20, 2024 at 6:10 AM
    If the tune and bolt ons require 91-93 octane I would likely pass.
    Tundra2 and shifty` like this.
  9. May 20, 2024 at 6:15 AM
  10. May 20, 2024 at 6:19 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    sure does. the Tech said he was basically aiming for a peak number on the 3rd run. I'm going to do a last run with my original tuner and a new calibration on the URD MAF calibrator early next year.
  11. May 20, 2024 at 6:19 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Got my hidden snorkel finished up this weekend. I saw a video on youtube about a guy who built his snorkel and ran it into the chamber between his fender and engine bay. I tried that route so we'll see how that works out. So far so good and kept me from having to cut a hole into my engine bay.
    Thanks guys for the tips, the 3" PVC that I believe @Voss recommended fit perfectly!
    I also cut the tip of my snorkel to help maximize the opening for air to enter the snorkel. I drove it for a bit and seems to work just fine, didnt change any sound either that I could hear.
    PXL_20240518_210825408.jpg PXL_20240518_211934147.jpg PXL_20240519_004326464.jpg PXL_20240519_005303962.jpg
    Tundra2, BroHon, Voss and 8 others like this.
  12. May 20, 2024 at 6:24 AM
    Nice work, seems like it turns it into a hot air intake though
  13. May 20, 2024 at 6:27 AM
    oscardog86
    Southern California
    Yea im kinda wondering about that too. However another guy built a similar one with good results and also, theres a lot of fresh air rushing from the front of the fender into that chamber so maybe it will suffice?
    That is my one concern with this setup as well though. Appreciate any feedback!
    Voss and FrenchToasty like this.
  14. May 20, 2024 at 6:34 AM
    Doubt it will have any dramatic effect on how the engines runs. It will definitely have a dramatic effect on whether it ingests water or not, so mission accomplished. We used to flip the air cleaner lids on our old carbureted cars to hear all that rushing air power! That made them hot air intakes too and they ran fine.
    NUDRAT, Voss, Weagle and 2 others like this.
  15. May 20, 2024 at 7:54 AM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
  16. May 20, 2024 at 8:01 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Needs more overloads.
    yeengleeng for scale.
    dont forget to run a hose for the diff breather.
  17. May 20, 2024 at 8:01 AM
    Looks good, y’all do fine work.
  18. May 20, 2024 at 8:03 AM
    VR6T
  19. May 20, 2024 at 8:04 AM
    VR6T
    I'm sure the other 3 dudes that showed up to make shit happen will be glad to hear that.
    Also thanks
    FishNinja likes this.
  20. May 20, 2024 at 8:12 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    How's that brake line holding up?? Lol I still think it's sketch
    VR6T[QUOTED] likes this.
  21. May 20, 2024 at 8:15 AM
    VR6T
    Nope they're firm and in place. It's just an odd fit. Casey adjusted the clip, no issues
    FishNinja[QUOTED] likes this.
  22. May 20, 2024 at 8:15 AM
    The Black Mamba
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Yeah, Texas boys doing Texas shit!
  23. May 20, 2024 at 8:16 AM
    VR6T
    Would you expect less?
    Or should we be doing "Carolina" stuff
    I puked in my mouth typing that a little
  24. May 20, 2024 at 8:17 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    Texan...big surprise. :rofl:
  25. May 20, 2024 at 8:19 AM
    VR6T
    Lol, fucking legend
  26. May 20, 2024 at 8:24 AM
    VR6T
  27. May 20, 2024 at 8:29 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Pumping that machine sounds painful. The tube in a jar is so much easier and just push the pedal.
    Looks great. What did you install to get level?
  28. May 20, 2024 at 8:30 AM
    FishNinja
    Lee
    06DC2wd
    The Black Mamba and VR6T[QUOTED] like this.
  29. May 20, 2024 at 8:31 AM
    FishNinja
    Lee
    06DC2wd
    Aka the "beaver leaf pack"
  30. May 20, 2024 at 8:35 AM
    VR6T
    3 to 4 to 6 lol
