  1. May 14, 2024 at 2:29 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Thanks for the input. I checked the steering rack and it's torqued to spec. TREs are new with the steering rack (last 2 years) and no play in the wheels to indicate LBJs or bearings. If I think about it, the steering wheel does seem to get off if I hit a bump right and will stay a little off for a while but will correct later on. Not sure if that's me making things up, or not. I'll check the torque on the alignment bolts and see about an alignment.
    metalpete[QUOTED] and FishNinja like this.
  2. May 14, 2024 at 3:22 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    If you haven't got new bushings already. I'd recommend it. Have your phone record your rack and go turn the steering wheel to full lock (both directions) and watch the video to see if your rack is moving. Or have a friend turn the wheel for you like I did. My rack would literally move like 1-2" compressing the old, worn out bushings.
  3. May 14, 2024 at 3:45 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Funny you mention that. My buddy was talking about wanting Lambo doors the other day and I was very against it haha
    NUDRAT[QUOTED] and Voss like this.
  4. May 14, 2024 at 3:46 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Pretty sweet rear seat delete set up ya got there.
    oscardog86[QUOTED] likes this.
  5. May 14, 2024 at 3:49 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    My 03 dims with the headlights, my 06 doesn't. One of these days I guess I need to rewire it. Honestly I'll probably replace that particular touch screen with an updated Pioneer or something.
  6. May 14, 2024 at 3:52 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'm not sure what you mean.
    Pics?
  7. May 14, 2024 at 4:10 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    455h0le_dachshund likes this.
  8. May 14, 2024 at 4:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Oh shit, so you got some extra drop out of em? Nice! Now I'm jealous haha.
    One of these days I'll buy some front 5100's and maybe I can get em to make me some with extra drop. Then I can try to sell these 4600's with the 2" drop. Hmm...
    FrenchToasty likes this.
  9. May 14, 2024 at 4:33 PM
    Chrisfrom1986
    Central CA
    06 AC SR5
    Yeah well see how it turns out. I found a DC rear axle because I didn't want to cut anything off my stock one. I still need to find a lsd rear end, the one that came out of my sequoia was non lsd unfortunately.
  10. May 14, 2024 at 4:43 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That will be nice, because it will fill the rear wheel wells nicely with the extra inch or two of width. I ended up putting 1.25" spacers on my rears to fill in the wheel wells better. Truck looks great now. I'm still thinking I may move the 1.25" spacers to the from and buy 2" spacers for the rear. I rub frame on full lock turns in front.
  11. May 14, 2024 at 4:50 PM
    Booooooo
  12. May 14, 2024 at 4:52 PM
  13. May 14, 2024 at 4:57 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I'm sure most of you knew this already, but I just learned today - rivet guns are awesome. Making progress on the topper rear window. Plexiglass will be here soon, so I'm trying to get everything else ready.
  14. May 14, 2024 at 5:47 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Absolutely, didnt really use one until last year and its really nice to be able to rivet somewhere you cant get a bolt and nut in without access to the backside of something. And you can just drill them out when you want to remove them.
  15. May 14, 2024 at 6:05 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Whelp I took the time to remove the Kenwood and install the Chinesium stereo in Ye Olden Tundra. Yeap, its gonna be going back. Its crappy but I had a feeling already.
    https://www.amazon.com/SJoyBring-Bluetooth-4-Channel-Capacitive-Touchscreen/dp/B0CN94Z1ZM
    Screen: The Chinesium model Joy-W019 has a sharp screen but its not very bright. At its brightest it's not as bright as the Kenwood. During the daytime driving I did today, the screen was kind of washed out as well. I set the brightest setting for the daytime and dropped it to 15% percent brightness for night time. When I kick the truck into reverse, the camera comes up at the daytime brightness but when I go back to drive or park, it switches the display to night time. Every. Damn. Time. The icon to change the brightness setting is tiny at the top of the screen. When in wireless Android Auto, which connects quickly but not every time, there is no menu to bring up settings, have to go to home, and then use the icon up top, or go into the settings and mess with it there. Meh.
    Audio: I knew going in this wasn't going to have the same sound capability as my Kenwood. It has basic fade/balance, a several band EQ, and "Loudness" for shaping the sound and its all very meh. Because there are no filters either on my headunit or in my mini amp, the speakers get full sound and distort at moderately medium sound levels. Speakers sound like teeeny boomy mess and awful at more than 12 or so volume (out of 40 max.)
    Build: Its Chinesium. My crackers weigh more.
    Controls: I tied in the blue/yellow wire coming from my Maestro SWC to both SWC wires on the Chinesium and tried to learn the wheel controls. They all turned into next/previous track for some reason. I then removed the Maestro from the wiring and tied both the SWC wires from the Tundy to both SWC wires of the Chinesium and half buttons on left side worked correctly. Powered it off, and swapped the two SWC wires and was able to learn all left side buttons successfully. Volume + and - as well as Next/Previous tracks and Mode button. My right hand controls I set the Answer/Hangup buttons as Volume+ / Volume - as I am used to the volume buttons on the right side of the wheel on my Ferd. This unit has basic SWC functions so no hold options available for each button. Not sure how I would program single press vs long hold options as the unit requires you to long hold the wheel button and then quickly press the corresponding screen screen button to program it.
    Cameras: The screen is sharp, claiming a 1280x720 resolution and the backup cam looked nice and sharp. It also came with a dash cam that can be tied into the unit and viewed on the screen. On my test bench, I wired it up but the picture was not very good and had noise interference. Probably the cheapest cams they could find to throw into the box. Meh.
    Conclusion: Its very meh. I'm sending it back. I gonna throw the Kenwood back in there for now or I may get the Alpine 670. I just hate the crappy resistive screen of the Kenwood. While the Chinesium unit was in the truck, I tested the Kenwood on the bench and as soon as I apply 12v to the Illumination wire it dims the display correctly. I tested the wire in the truck and it too gets 12V when I turn on my headlights so I'm confuse as to why the Kenwood doesn't dim properly when installed in the truck. Meh.
    Carry on Gentlemen.
    Update: It turns out my mini amp NA2-320.4 does have a high pass filter option that I'm pretty certain I currently have set to all-pass. I will try that and see if it improves the sound any.
    KNABORES likes this.
  16. May 14, 2024 at 6:15 PM
    FishNinja
    Lee
    06DC2wd
    weld it
  17. May 14, 2024 at 7:12 PM
    oscardog86
    Southern California
    So I started trying to get my fender removed today and I believe all the bolts are removed and it wiggles pretty good but it looks like there is a welded portion on my fender that needs to be cut!
    Maybe the earlier years had this spot below the arrow welded? Did you run into this @Voss?
  18. May 14, 2024 at 7:12 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I thinks that’s just sealant
  19. May 14, 2024 at 7:14 PM
    oscardog86
    Southern California
    Oh damn you might be right lol!
  20. May 14, 2024 at 7:18 PM
    FrenchToasty
    Mo
    Bone stock
    It takes a village. I’m just L-I-V-I-N
    Mater, FirstGenVol, bmf4069 and 2 others like this.
  21. May 14, 2024 at 7:22 PM
    03Limited
    03Limited New Member
    Shifty, On your back up cam install. I'm ready to add the BU cam to the radio replacement (other thread). Today when I measured the back up bulb voltage, it was 10.8 volts (expected 12.2). 2003 tundra. The ground wire has no 'ground' (>200K). This surprised me. The wires are red/blue 12.8 volt, and 'ground' is white/black. The voltage was measured with ignition on, motor not running (safer in reverse). I suspect this would work to tap both and use that as the signal to the head unit. Your thoughts? My 'taps' are soldered connections and heat shrinked as done with the many connections for the radio. I am mostly puzzled that ground is floating.
  22. May 14, 2024 at 7:37 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Nope
  23. May 14, 2024 at 8:00 PM
    oscardog86
    Southern California
    Haha yea it was just sealant like @FrenchToasty said. Had one more sneaky bolt down below that I hadnt removed so it wasnt coming off. Once I found that bolt the sealant broke away pretty easily. Thanks guys!
    Now any idea how to remove the antenna assembly to get this fender completely off my truck??
    Voss and FrenchToasty like this.
  24. May 14, 2024 at 8:42 PM
    Voss
    2003 AC TRD 4x4
    It’s got some fancy bolt on there that doesn’t come off. If you unbolt the antenna holder inside the fender, the antenna wire is long enough to rest the fender on the ground.
    and oh yeah, there’s one bolt at the bottom of the fender near the door
  25. May 15, 2024 at 5:12 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I'm not shifty` but I'll chime in. I tapped mine using the wires from the back up lamp socket on the driver's side. Literally positive and ground. Works just fine for my back up camera.
    sportbike37, shifty`, BroHon and 3 others like this.
  26. May 15, 2024 at 5:46 AM
    FishNinja
    Lee
    06DC2wd
    +1
    I used positive side of bulb and actually grounded the ground to the truck.
  27. May 15, 2024 at 6:21 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    @03Limited
    I 3rd what @FishNinja and @The Black Mamba said. I just did this to get reverse lights on my camper... well, it doesn't have reverse lights, but you can imagine them working if it did, right?!
  28. May 15, 2024 at 6:30 AM
    MT-Tundra
    Montana
    Boy that would be nice! My camper has little white plastic spots on the tail lights so I'm guessing I could get reverse lights going...but never looked into it. There were several years I was living out of my camper in the summer, and they really would have come in handy since I was driving it around town at least once a week. But now that I only camp with it, I'm not as concerned. Would still be really nice though. In fact I'm not sure why it's not a requirement. Can't see anything back there...people are on their own if they drive up behind me when I'm backing!
    BroHon, oscardog86 and metalpete like this.
  29. May 15, 2024 at 6:44 AM
    FishNinja
    Lee
    06DC2wd
    or just got some white pod flood leds and hook them up as reverse.
    metalpete likes this.
  30. May 15, 2024 at 6:51 AM
    MT-Tundra
    Montana
    Yeah there are options. I'm just surprised it's not part of the 7-pin (or would that make it 8?) connection. For enclosed cargo trailers and camper trailers, seems like it ought to be standard.
