  1. May 12, 2024 at 8:33 PM
    daveeasa
    David
    From the talk of polycarbonate, anyone interested in a bulk buy of 1/8” HDPE? I want to do a tailgate panel to replace the OEM metal piece. But HDPE is $$$$ even in 1/8” and shipping is miserable. I could look into a local supply option if I could get a few others interested.
    oscardog86 and RUSTYNUTS like this.
  2. May 12, 2024 at 9:31 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Dude, if you can see under the truck, it’s not low enough. If you’re gonna drop it, then slam it. I wanna see that thing sittin on the ground. And don’t start whining about having to notch the frame, you signed up for this. :thumbsup:
    That’s debatable. :boink:
    you do have a lot of ‘thinking outside the box’ ideas, and many are on the better side, but cmon man. Let me just remind you of the snowplow/catapult front bumper idea. Just sayin…….. :anonymous:
    they can’t all be zingers
    is that the white plastic used for chain guides and cutting boards?
    bmf4069, shifty`, oscardog86 and 3 others like this.
  3. May 12, 2024 at 9:46 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    if i'd have known college kids would be speedbumps again, my truck could be front
    Page material.
  4. May 12, 2024 at 9:58 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Maybe someday. I gotta learn to fabricate or at least weld first. @Mr.bee found me this front bag kit I may try out someday several years from now.
    https://airbagit.com/products/airarm-to20xx
    For now I need to order the correct fitting lowering blocks from SOS and new u-bolts.
    Next is to find a junkyard Sequoia front sway bar and get these 4.10 gears and TrueTrac installed. Finally I still await tuneabily from VF Tuner. My ECU's Cal ID currently is not supported :pout:
    Right now this build isn't about being low, as much as it is about being sporty and general street hoonability.
    :burnrubber:
    oscardog86 likes this.
  5. May 12, 2024 at 10:08 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Not today but yesterday I popped the Kenwood out the dash to try and figure out why its not dimming even though I have the dimmer on Sync mode. The Metra harness has the orange/white dimmer wire and the stock plug has a green wire in that corresponding spot. I could've swore it used to dim when I first put the Kenwood in it. I didn't think to check for 12v at that green wire though when turning the headlights on and off so maybe the issue is there and not at the Kenwood headunit. I also went ahead and ordered a Chinesium wireless AA unit with a capacitive screen so we'll see how it goes. Meh.
  6. May 12, 2024 at 10:11 PM
    daveeasa
    David
    Comes in white and black but yes. Mountain Hatch has a thick as F design for us that I hate. I just want to replace the crappy OEM metal piece with something light with spots for cupholders and won’t bind against the tailgate rods.
  7. May 12, 2024 at 10:40 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    But it would look SOO sick sittin on the floor. I'm not saying it's gotta be rollin 3 wheels on switches, I mean, that would be the sickest, but tryin to keep it realistic. Up front, just remove your shocks and let it ride on the bumps. Out back, just remove your leafs and strap the frame to the axle. It'll be a bit of a bumpy ride, but cheap and easy.
    :duh::crazy::rofl:
    Man, I did a job at a manufacturing plant last year that made that stuff. Coulda probably scored a couple sheets for free, and should have. I got some pieces to mess around with, but they're smaller blocks, discs and cylinders, all at least an inch thick. Nothing big enough format for what you want to do tho.
  8. May 12, 2024 at 10:54 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :laugh:
    So the rear I could slam this week if I really wanted to. The SOS kit flips the axle and the shackles. If I were to swap the stock shackles back in, the rear axle would probably contact the frame without a c-notch. If I were to bag the front, I'd probably do just that to the rear, except notch it. At least until I could link and bag the rear.
    oscardog86 and JakeJake like this.
  9. May 12, 2024 at 11:18 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    You're welcome
    Sooo sick
  10. May 12, 2024 at 11:28 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Tight tight.
    Now shave it and add some chicks :cool::D
    JakeJake likes this.
  11. May 13, 2024 at 5:22 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Grainger has it. If I remember correctly you don't pay shipping to pick up at the stores.
    BroHon and oscardog86 like this.
  12. May 13, 2024 at 6:26 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    So after adjusting the rear brakes, bell cranks and taking slack out of the parking brake... The brakes feel so much better! The pedal engages much sooner and no more sponginess. Also now the parking brake is fully tight after like 8 clicks or so, which is in the range that the FSM recommended.
    Everytime Id get in the truck after driving my other car, id think I didnt have brakes because of how spongy they felt compared to my other car. Always had to get used to the FGT sponginess. Not anymore!
    Also added some shots of my rear seat delete/storage
    And some shots of my behind the bumper cut away that I think came out pretty good
    Also made a little bracket for my lil washer fluid reservoir since removing the stock one. Its kinda small but I dont really use it much so we'll see how it works out. I can get a larger one if i need to but for now it fits nicely just behind my passenger headlight.
    PXL_20240510_225152817.jpg PXL_20240510_225248257.jpg PXL_20240511_035555993.jpg PXL_20240512_021154200.jpg PXL_20240512_162157804.jpg
  13. May 13, 2024 at 7:08 AM
    shifty` Inside his chest they found ten thousand pencils
    Looks awesome as it is, but I think right here's about where you need to be. Maybe a little more up in the ass-end, half inch or so.
  14. May 13, 2024 at 7:13 AM
    But at that point ^^ you're roughly 2"-2½" lower front and rear than current. Here's what 1-1½" from your current will get you, which I think looks pretty f'n awesome also. Very sport-lowered truck appeal, ready for the strip.
    455h0le_dachshund likes this.
  15. May 13, 2024 at 7:17 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It was already up another inch before the block. I didn't hate the rake, but I much prefer where it's at now.
    I asked Tom at SOS if he could make me a 7/8" block just so I could have the piece of mind of seeing a few more threads. He sells a 1/2" block as an option with the kit and he offered to make me a 1" block. Still no reply as to whether he can do the 7/8" or if he has any longer u-bolts. I'll email em again next week. I'm in no rush. The priority right now is to get the 4x4 back in action.
    oscardog86 and shifty`[QUOTED] like this.
  16. May 13, 2024 at 7:21 AM
    For some reason I had it stuck in my head dimming wasn't an option on our trucks, like, there's no dimmer wire support at all. Maybe I'm nuts, or maybe I'm thinking about my last truck. I've done too many installs, a lot of it is a blur.
    BroHon likes this.
  17. May 13, 2024 at 7:24 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    For my 00 it dims when I turn the lights on, but I don't have control beyond that.
    shifty`[QUOTED] likes this.
  18. May 13, 2024 at 7:36 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    :p
  19. May 13, 2024 at 11:10 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Nice. Welcome to the, “now what do I do with my air intake” club
  20. May 13, 2024 at 11:22 AM
    oscardog86
    Southern California
    What do you recommend? haha
    Voss[QUOTED] likes this.
  21. May 13, 2024 at 11:37 AM
    Snorkel!!
  22. May 13, 2024 at 12:05 PM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    Finally got my CB installed....
    AmericanKing06, Voss, NUDRAT and 4 others like this.
  23. May 13, 2024 at 12:45 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I have been having some steering issues lately where my wheel isn't returning to center and driving straight has the wheel slightly off from center, but only sometimes. I looked and I think I'm having some movement in my steering rack.
    I'm curious if the slightest movement in the rack could be causing this issue? If so, what is the recommended remedy, new bushings?
    Voss and jerryallday like this.
  24. May 13, 2024 at 1:27 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  25. May 13, 2024 at 1:53 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    @shifty` - back to U-bolts, I seem to recall from college engineering classes that hardened steel is more brittle than mild steel. Of course that was like 45 years ago and I may be wrong.
  26. May 13, 2024 at 1:57 PM
    Possibly. I don't know the mechanical engineering component here, and how much more prone to bolt shear a fastener is when thread stretch occurs on mild steel versus no stretch on hardened steel.
    As with everyone, i'd encourage folks to use their best judgement. I know what I do, and I haven't had any catastrophes in 30 years (knock on wood), but I don't expect everyone to follow my lead, I may just be lucky. YMMV, full disclaimer, you do you, yadda yadda (I hate the word yadda)
  27. May 13, 2024 at 2:11 PM
    bfunke
    South Carolina
    I been reading about U-bolts and I think the OEM bolts can be reused provided they were properly torqued and the threads are no damaged. The torque value of 80 ft-lbs provides about 15k of clamping force with is considerable less than the elastic limit of these bolts.
  28. May 13, 2024 at 2:39 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    I ended up buying the 2-4" kit and he sent me the extra .6" spring mount for the front. I was going to install it after finishing the cat shield but had to fix evap issues first.
  29. May 13, 2024 at 3:40 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    don't forget to Lambo your doors. :rolleyes:
  30. May 13, 2024 at 3:42 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I like that side pocket upgrade next to the CB
