  1. May 10, 2024 at 6:03 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'll let you know if it ever happens to mine.
    You'll be the first to know.
    I got you on speed dial.
    BroHon[QUOTED] likes this.
  2. May 10, 2024 at 6:05 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    ACBC :thumbsup:
  3. May 10, 2024 at 6:05 AM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    A hack mangler that needs to be punched in the face, and denied breeding rights. And made to sober up.
  4. May 10, 2024 at 6:42 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    https://youtu.be/V01OuuGlbbo?si=BCiqYN15rJFlsgN8
    chrisfix with the answer in the first minute.
    basically they're one way vents to keep pressure from building up and shattering any tempered glass. Air can't come in therefore hvac is sealed and you're protected from the elements. But air can escape incase of excess pressure and keep the windows from shattering.
  5. May 10, 2024 at 7:59 AM
  6. May 10, 2024 at 9:39 AM
    Pnwtundy
    Pnwtundy New Member
    04 DC SR5 TRD, V8/4WD + LSD/Tow
    I just can't unsee the face
  7. May 10, 2024 at 9:58 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Something off the shelf like a kneaded sausage product :) will work fine for as small as the holes are.I would even be tempted to use regular ole JB with a packing tape dam on the backside. Sanding is going to suck, but its only a 1/4" spot.
  8. May 10, 2024 at 10:17 AM
    Bare Grilles, don't make it drink its own pee.
    Got all the FMS foams pulled and adhesive removed, scrubbed all corners, prepped for filler, waiting for it to dry overnight to start filling holes, so I can sand and skim it with Rage for final sanding and prime. Inner mesh pulled, cleaned thoroughly (it was nasty af!) and tucked away.
    Gotta order 7mm and 5mm replacement foams for the outer and inner rims, respectively.
  9. May 10, 2024 at 10:19 AM
    FishNinja
    Lee
    06DC2wd
    I'll fight all of you
  10. May 10, 2024 at 10:29 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    AC is the OG :fistbump:
  11. May 10, 2024 at 10:35 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I have a mesh insert sitting in the box. I need to find another stock grille to cannibalize since mine is broken.
  12. May 10, 2024 at 10:55 AM
    I have a DC grille in the shop. Got it from @wandering_boy. I'd give it to you, only issue is, it's white, chrome capped, and it cost an arm and a leg to get from CA to GA, so I'm sure it'd cost a fortune to get back. Then you'd need to paint. And one of the chrome rails lost a tab in transit.
  13. May 10, 2024 at 10:57 AM
    That was my thought train also. I've got regular JB, and I have a stick of JB Plastic Epoxy. I was thinking the latter may be the better option, but I'd prefer to flow something in from behind with metal flashing tape on the face.
    I'm going to let it dry out overnight. I may toss it in the oven at 150 for an hour or two to expedite. Drinking some coffee and mulling it over. Slept like shit last night.
  14. May 10, 2024 at 11:27 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Agonizing and day dreaming. Thinking about the next stages of speed. Ordered the Orange Virus VF Tuner and their 'canned' 2UZFE VVTI tunes. Still waiting on that arrival. (Side note: when that arrives I will show their 93 octane tune dyno results).
    Got the VF tuner so I can adjust my fuel/spark maps as I add mods. But this brings me to my present dilemma...
    Kelford 251/251 drop-in cams: $1,500
    Or
    4.30:1 ring and pinion re-gear: $1,000
    I haven't decided which way to go next. I really want to see how a stock springed single pattern cam will do on this engine. It's 30*i/24*e longer duration with 0.5mm higher lift than the stock cam. About as agressive as you want to go with stock springs and without having to limit/disable the VVTI.
    Buuuut I know how much quicker the truck will feel with 4.30:1 gear. Before the comments roll in, I'm running 285/60-R18 tires and don't want to be RPM crazy on the highway. Math says 4:30:1 will do better for my application than 4.56:1.
  15. May 10, 2024 at 11:30 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    What rpm does that kelford move peak torque to?
  16. May 10, 2024 at 12:11 PM
    Riverdale21
    OTP ATL
    Kelford advertises the 251/251 at increasing low to mid range power. No RPM value given.
    Next step up are the 264/258 which are advertised as mid range but need their springs.
    I've focused everything so far on increasing low-end torque. We mostly drive these trucks below 3,000RPM. I've picked up quite a bit of low end oomph with the Tri-Ys. Dyno showed about 40 lbs-ft off the rip with just DD 12 hole injectors, headers, and single 2.5" straight through exhaust.
  17. May 10, 2024 at 12:20 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Some trucks just have longer beds than others. Nothing to be ashamed of DCs
  18. May 10, 2024 at 12:28 PM
    Pnwtundy
    Pnwtundy New Member
    A bird in the cab is worth 2 in the bed
  19. May 10, 2024 at 1:05 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    boooooo
    shifty`[QUOTED] likes this.
  20. May 10, 2024 at 1:51 PM
  21. May 10, 2024 at 1:52 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Dont feel bad, some people just need a truck to be a truck, at least the DC isnt over compensating like the newer ones.
  22. May 10, 2024 at 2:00 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    If the DC bed is deeper, doesn’t that mean it can hold more than the shorty AC?
    Voss likes this.
  23. May 10, 2024 at 2:02 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    More water? Tie-downs tie 'down' for a reason. The lighter weight helps a bit. The narrowness helps alot.
    455h0le_dachshund likes this.
  24. May 10, 2024 at 3:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Pnwtundy[QUOTED] likes this.
  25. May 10, 2024 at 3:18 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Where'd you find a new 4.30 ring and pinion for sale? I know Yukon used to have one but I think they quit making em. I thought you had to get lucky in the junkyard with a 00-04 V6 4x4 auto trans FGT
    Also where'd you find tri-y headers?
  26. May 10, 2024 at 3:22 PM
    Voss
    2003 AC TRD 4x4
  27. May 10, 2024 at 3:23 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Who you calling shorty? Last I checked the AC was an inch longer than DC lol
    Jack McCarthy likes this.
  28. May 10, 2024 at 3:40 PM
    Riverdale21
    OTP ATL
    I got the last set of tri-y ever made by Stan before he retired. There's a company in Australia that make a mid-length tri-y for the 100 series right hand drive Land Cruiser but they won't fit the LHD Tundra.
    Our only options for headers are JBA shorties or Dirty Deeds long tubes.
    And Summit still carries a wide variety of Yukon gears for our trucks.
    https://www.summitracing.com/parts/yga-24589/make/toyota/model/tundra/year/2006
    Local offroad shop quoted $1,000 for parts and install. I've already got the factory LSD, but some spicier gears would improve acceleration.
  29. May 10, 2024 at 3:41 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah I got some of the last sets of JBA longtubes. I'm also tuned and have the DD12's, so I'm excited to see your dyno results.
    Voss likes this.
  30. May 10, 2024 at 3:50 PM
    Riverdale21
    OTP ATL
    Red line: tri-y, DD 12 hole, custom 2.5 single exhaust.
    Blue line: stock with DD 12 hole.
    I'll dyno again after the VF chip.
