  1. May 6, 2024 at 12:47 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    how are the transmission and engine mounts?
  2. May 6, 2024 at 1:00 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Tranny mounts are fine. Engine mounts work but are rusted to crap. Only way to see what might be happening would be jacking up the rear axle, putting it in drive (pointed towards the woods) and look from the side to see if anything shudders.
  3. May 6, 2024 at 2:06 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    just gotta rachet strap it to another truck. It won't go nowhere; even if it makes it off the stands lol
  4. May 6, 2024 at 2:20 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    I think we need to talk about that
  5. May 6, 2024 at 2:21 PM
    VR6T
  6. May 6, 2024 at 2:22 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Voss[QUOTED] likes this.
  7. May 6, 2024 at 2:23 PM
    Jack McCarthy
    Bill
    North of Boston
    VR6T[QUOTED] likes this.
  8. May 6, 2024 at 2:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  9. May 6, 2024 at 2:32 PM
    VR6T
    O- O- O'Riley's 89.99 on discount brand muffler special baby. Total cost for a resonator back pre axle dump about 140 bucks, plus my time to weld it up. Factory piping to a step up to a 2.5 in and a 2.75 out
  10. May 6, 2024 at 2:35 PM
    VR6T
    Oooffff. Yeah I do the palm rub thing till it's in place. But hey every mistake it a teachable moment.
    FiatRunner[QUOTED] likes this.
  11. May 6, 2024 at 2:37 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So I need to replace my driver side axle seal on the front diff. It leaked out all the diff juice. Anyways is there a brand besides OEM y'all recommend? I was going to shop around AutoZone and O'Reilly's because they're both walking distance from me. Just want to make sure no on has had any horror stories about non OEM brand seals
  12. May 6, 2024 at 2:38 PM
    VR6T
    E Free gas 4 to 5 times a year to help clean out the ethanol residue will guve your fuel system and cylinders a wonder of a cleaning. Add some sea foam to it twice a year and it'll never give you an issue. I run 90 E Free once a month in the Tundra. My truck used to run out of gas at a "quarter tank", it doesn't any more cause all that residue that was gumming up my float and level sender is gone now. It may be a bit pricey but it does help out in the long run.
    oscardog86 likes this.
  13. May 6, 2024 at 2:41 PM
    VR6T
    Yeah it's sitting in the garage, you looked right at it last you were here
  14. May 6, 2024 at 3:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Last I was there you said you didn't have one and that's why I offered you mine, since I sold my skid to @txagg a long time ago. You didn't say anything about having already sourced one.
  15. May 6, 2024 at 3:37 PM
    VR6T
    Yeah I did me and Casey went and he helped me pull it. I know we told you. Meh it's not important lol.
  16. May 6, 2024 at 3:38 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Ah, makes sense y'all got it on the second trip that I missed
  17. May 6, 2024 at 4:43 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Well . . . I puss'd-out and payed a local shop to re-do my rear brakes.
    A few family health things at home, and a bad back on me were the deciding factors.
    I took them a new doorman bell crank kit, and they put on new drums, shoes, etc.
    Great local guys who did the work . . . afterwards they showed me all the old parts & how rusted everything was back there, BRUTAL . . . made me relieved that I made the right decision this time to have them do it.
    Another thing is that my truck barely clears my garage door . . . and once inside I wouldn't have been able to jack it up to the height needed to do the job w/o htting the garage door opener.
    And I really wasn't into to doing it outside on our steep driveway for all the neighbors to rubber-neck and heckle me . . . . so anyways . . . it's done.
    Gotta say, the braking is soooooo much better . . . . rear brakes and parking brakes were non-existent . . . no wonder I was chewing through front brake pads ! LOL. Plus I have a parking brake now that actually works ! . . . who'd-a-thunk !?!?!
  18. May 6, 2024 at 4:46 PM
    I’m pretty sure all the complaints from way back in the day about poor braking performance really just boiled down to the rears not self adjusting properly. Not undersized calipers.
    bmf4069, oscardog86, HBTundra and 5 others like this.
  19. May 6, 2024 at 5:11 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm surprised you could safely drive it. I've driven my truck when the rears were not adjusted and it was legitimately dangerous. I turned around on my street.
    My Lexus calipers were actually messed up but I agree with you. Even the slightest misadjustment in the rear has a huge impact. I hate the drums.
  20. May 6, 2024 at 5:46 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    some of it is the headlight is taking a direct hit from all the road debris, some of it might be the headlight lens getting hotter with a big chromed chamber behind it (assuming clogged vent tube).
    The side markers get glancing blows of debris & the air chamber to heat up is much smaller.
    But that's just guesswork with a splash of fuzzy logic mixed in.
    bmf4069, oscardog86 and BroHon like this.
  21. May 6, 2024 at 6:31 PM
    I like this logic. Heat is probably the #1 cause. If it was UV then all the lenses would do it.
  22. May 6, 2024 at 6:45 PM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    bmf4069, VR6T, Jack McCarthy and 2 others like this.
  23. May 6, 2024 at 6:47 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Finished installing the 7 way. Not too bad, more annoying than difficult for sure. If i wasn't sick, probably would have only taken 3-4 hours.
    Haven't installed the controller yet just ran all the wires. Still not sure where to mount that sucker, but that's a problem for next weekend.
    NUDRAT, bmf4069, VR6T and 14 others like this.
  24. May 6, 2024 at 6:57 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    His rack is……….. top shelf aswell
  25. May 6, 2024 at 8:30 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    I could see it being the heat maybe, from the bulb too, that makes sense.
  26. May 6, 2024 at 10:06 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    That seal is easier to install IMHO compared to the other side but sugest OEM. FWIW can read here that seated a non-OEM per spec on the passenger side (after initially installing OEM seal too deep) because needed it running next day. But it leaked. Replaced with OEM, and all good. Aso cleaned the breathers just in case.
  27. May 6, 2024 at 10:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah @Mr.bee mentioned I should clean the breathers. I still need to do that tomorrow.
  28. May 6, 2024 at 10:15 PM
    ToyotaDude
    ToyotaDude Member
    Sorry didn't see his reply. Yeah don't know if cleaning the breather is what fixed the issue or swapping in the OEM seal. Did both as didn't want to do it again.
  29. May 6, 2024 at 10:16 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Nah, he told me in person when we were working on my truck a few weeks ago.
    I totally forgot til you mentioned it just now haha.
    I think I'll do both too. This is the second time this seal has blown.
    ToyotaDude[QUOTED] and Mr.bee like this.
  30. May 6, 2024 at 10:39 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Those spindles come in yet?
