  1. May 6, 2024 at 9:52 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    that doesn't explain the midget in the gas tank at idle though
    BroHon[QUOTED] and Jack McCarthy like this.
  2. May 6, 2024 at 9:53 AM
    If it's making the noise at idle not moving, focus on things that move while idling. If it increases with vehicle speed only, focus on things that are wheel speed dependent. If it increases with engine speed only, focus on those things. Keep the parts cannon holstered, diagnose first by ruling things out if the cause is not obvious. Then as it gets narrowed down, test the potential cause before replacing if possible. Soooooo many truck wouldn't start threads on here with new fuel pumps, starters, relays, batteries, ignition cylinders etc and its a bad ground, or a defunct security system.
  3. May 6, 2024 at 9:56 AM
    Pnwtundy
    Pnwtundy New Member
    04 DC SR5 TRD, V8/4WD + LSD/Tow
    After replacing my combination switch, I finally have working fog lights! I also ended up installing a set of dual color LED lights (link), because why not?
    @artsr2002 I did try to dismantle my old switch, however I couldn't quite figure out how to get to the switch without feeling like I was going to destroy it. Any tips on how work on the shaft? ( :thumbsup: )
    Also did a drain/fill on the rear diff.
    bmf4069, BroHon, KNABORES and 2 others like this.
  4. May 6, 2024 at 10:03 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    How do you like the dual color fog light bulbs? I have contemplated picked up a set. I really like amber/yellow lights in snow and rain, but white is certainly the best on a typical day.
    455h0le_dachshund likes this.
  5. May 6, 2024 at 10:18 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    So i was browsing last week on the forum and stumbled upon an image of a members FGT that had the parts in red in my image cut away and I thought it looked pretty good.
    Was it someone from here that had done that to their truck? Was it @FirstGenVol by chance?
    Anyways, was thinking of doing the same to mine so was just curious how you went about buttoning all that up and did you relocate the washer fluid reservoir then?
    Sometimes I get bored and want to do things to my truck, haha. I plan on owning it another 20 years so dont mind cutting stuff to make it more my own!
    455h0le_dachshund and Voss like this.
  6. May 6, 2024 at 10:19 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    With OD off I’m only getting the bump feeling at idle. No hopping upon acceleration. I almost thought it was another misfire. I should go out and buy a fuel pressure gauge; it could be handy.
    Tranny fluid levels are good. Right to the top of the full line as usual while idling.
  7. May 6, 2024 at 10:24 AM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    Well apparently the last time I did this like a month ago didn't hold. Must have flew off whilst driving. So I get to do it again. Also explains the sudden leak I've been having.
    Screenshot_2024-05-06-12-15-00-21_40deb401b9ffe8e1df2f1cc5ba480b12.jpg IMG20240506122045.jpg
    And there's all this today. General service
    bmf4069, BroHon, Pnwtundy and 3 others like this.
  8. May 6, 2024 at 10:37 AM
    I think many on here have aftermarket bumpers with that portion cut away. There's the old "Viper Cut" that the Tacoma crowd has made popular. Basically just modding your factory bumper to improve tire clearance and give it that aftermarket look.
  9. May 6, 2024 at 10:54 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Alright, this has probably come up before- does anyone know why headlights yellow like crazy yet the corner lights stay nice and clear? Is there a logical explanation?
  10. May 6, 2024 at 10:56 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @oscardog86 . I didn't cut that part but I did paint it black to help it blend in with the aftermarket bumper.
  11. May 6, 2024 at 10:59 AM
  12. May 6, 2024 at 11:04 AM
    oscardog86
    Southern California
    Nice ive been thinking of doing that as well instead of cutting. But cutting is more fun!
  13. May 6, 2024 at 11:05 AM
    oscardog86
    Southern California
    Good question! Ive been wondering that as well
    des2mtn likes this.
  14. May 6, 2024 at 11:08 AM
    Pnwtundy
    Pnwtundy New Member
    I like them, though i didn't have time to adjust them and could tell they were pointing too high up so I'm keeping them off until I can. I'll post an update with pics. They're definitely brighter than stock though!
  15. May 6, 2024 at 11:37 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Anything but black or cut really sticks out on every aftermarket bumper I've seen.
    oscardog86 and Voss like this.
  16. May 6, 2024 at 11:39 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    oscardog86 likes this.
  17. May 6, 2024 at 11:44 AM
    Voss
    2003 AC TRD 4x4
    I cut those parts out and relocated the windshield fluid tank. Got a smaller one for a Tacoma which fit well near the air filter7CE2105B-4679-441B-BB8A-4B4A52F3A35B.jpg
    805Tundra, bmf4069, artsr2002 and 7 others like this.
  18. May 6, 2024 at 11:45 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I cut mine with tin shears.
    I did not relocate my.washer reservoir. I just trimmed around it as best I could.
    Voss and oscardog86[QUOTED] like this.
  19. May 6, 2024 at 11:47 AM
    des2mtn
    Shady Grove
    Tonto cover
    That article is over two years old, but as I understand they don't replace the normal gas with E-85, just stations that sell E-85 can continue to do so during the summer. Ethanol contributes to smog pollution in hot weather, which is why they limit it during those months. It's not legal in CA to run a flex fuel conversion kit where a normal vehicles like ours can run E-85 without issues.
    FrenchToasty and Voss[QUOTED] like this.
  20. May 6, 2024 at 11:52 AM
    Voss
    2003 AC TRD 4x4
    Cool. Heard about it recently, guess it’s been done before. This article is for the recent announcement but says only 8 states & you’re right, Cali isn’t one. https://thehill.com/policy/energy-environment/4483469-epa-ethanol-yearround-decision-states/
    des2mtn[QUOTED] likes this.
  21. May 6, 2024 at 11:52 AM
    VR6T
    Voss what front bumper is that?
  22. May 6, 2024 at 11:55 AM
    Voss
    2003 AC TRD 4x4
    Voss’ custom bumper.bestgen
    805Tundra, bmf4069, BroHon and 4 others like this.
  23. May 6, 2024 at 11:56 AM
    oscardog86
    Southern California
    Yea, my white really sticks out like a sore thumb with my diy tube bumper. I might go the route that @Voss went
    Voss likes this.
  24. May 6, 2024 at 11:56 AM
    oscardog86
    Southern California
    Thanks for the info, thats the picture I saw last week. Looks good!
    The Black Mamba and Voss[QUOTED] like this.
  25. May 6, 2024 at 11:57 AM
    oscardog86
    Southern California
    Good to know, maybe ill get away without moving my washer reservoir
  26. May 6, 2024 at 12:00 PM
    Voss
    2003 AC TRD 4x4
    Thanks. I like it. Those areas were sticking way out with my bumper & passenger side windshield fluid tank is right behind it so gotta do something about it if you do cut… a decent amount out
    oscardog86[QUOTED] likes this.
  27. May 6, 2024 at 12:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I painted the white black on mine and trimmed
    oscardog86[QUOTED] and Voss like this.
  28. May 6, 2024 at 12:14 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Pretty sure you should not need to relocate unless you have 35's+
  29. May 6, 2024 at 12:23 PM
    oscardog86
    Southern California
    Yea I think a combination of trimming and painting black would be the best.
  30. May 6, 2024 at 12:39 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    You probably know this as it isn't your first time installing one- but if you have to install it by striking it with your palm or tapping with a mallet, you're using too much force!!!
    Don't be like me:
    bmf4069, shifty`, BroHon and 4 others like this.
