  1. Apr 30, 2024 at 1:36 PM
    Mine is mounted under the ignition in that inset area. It’s out of the way, haven’t hit my knee in it ever.
  2. Apr 30, 2024 at 2:29 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Oh, so maybe I'm not that worried about banging my knee!
  3. Apr 30, 2024 at 2:33 PM
    metalpete
    ID
    Also, decided to put the sway bar back on. It was alright while it was off, but there was one casualty...passenger outer TRE. Noticed some goop on the inside of my wheel and the sucker had more or less popped. Thinking it had to do with all the extra flex w/out the SB. Made me consider the extra stress on the LBJ's so I put it back on.
    oscardog86, Voss and shifty` like this.
  4. Apr 30, 2024 at 2:37 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    From what I read online, it’s due to a poor resistive connection with the fuse. Best to check the contacts it fits into to see if they’re corroded or oxidized in any way.
  5. Apr 30, 2024 at 2:42 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  6. Apr 30, 2024 at 5:34 PM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Got home to the 50" monitor, wow.
    I think putting yourself in that chair/remote AF/not a soul for Miles/quiet/with that expansive view.... I think that must be some awesome mental reset time.
    I dream of what that must be like. thx again man.
  7. Apr 30, 2024 at 6:00 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    I'll take it if you're not going to use it.
    oscardog86[QUOTED] likes this.
  8. Apr 30, 2024 at 7:02 PM
    TXTundraGuy23
    TXTundraGuy23 One piece at a time
    Dallas
    2004 DC 4.7L 4WD
    6112s up front w/ 650 lb springs, 5160s in the rear, JBA UCAs, Suspension Maxx Links, ATS leafs w/ Wheeler's AAL and overload spring, Toyota Gloss Gunmetal TRD Wheels, Toyo Open Country AT3s 275/70/17
    Man, this is what it’s all about. I’m glad we’ve got people on here who can appreciate this. We’re heading to pagosa springs next month and I’m so excited. Been in school for a while and have 7, 5, and 2 year old boys so it’s been hard to escape to the great outdoors. Hopefully I’ll get to do a little more of this soon. Love the pictures man!!!
  9. Apr 30, 2024 at 7:30 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I'm seeing 5 ladies doing headstands & a purple dinosaur.
    Walked past free-range chicken house Sunday, they were BBQing chicken on the front porch. YES! 1 less.
    oscardog86, Voss, BroHon and 2 others like this.
  10. Apr 30, 2024 at 7:36 PM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    After 4 months of working on this truck for 40 minutes at a time I was finally able to drive it today. It's been on jackstands for months, but replaced upper and lower ball joints and control arms, front bearings, steering rack and lines, brake booster and master cylinder, 9 brake lines, idler pulley, tensioner, alternator, fan clutch, radiator, front and rear shocks, antenna, and tackled a good bit of rust in the front end. A number of the components I replaced were bad and had failed, other components were at the end of their life and showing a good bit of wear and were parts I needed to pull off anyway so I opted to replace them. Went OEM for almost everything.
    My brakes were still soft though. I did bleed them in the right order though. Will look into rear brake adjustment (I know there's a thread on it).
  11. Apr 30, 2024 at 7:40 PM
    https://www.tundras.com/threads/rear-brake-adjustment-theory-and-practice.99575/
    Bed Tundy likes this.
  12. Apr 30, 2024 at 7:45 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    until you get in an accident and the danged controller dislocates your knee cap.
  13. Apr 30, 2024 at 8:01 PM
    Azblue
    The Dirty T ( ^_^)_且
    Meh, you've got 2 knees, one good one should be enough.
    metalpete, oscardog86, Voss and 3 others like this.
  14. Apr 30, 2024 at 8:05 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    They make canes
  15. Apr 30, 2024 at 8:06 PM
    Azblue
    Yep, good point
  16. Apr 30, 2024 at 9:04 PM
    snoope
    snoope The Old Man
    I just replaced front brake pads and rotors and pedal still felt like $hit...even re-checked the work o_O ;)
    I found that setting & resetting the E-brake actually brought my pedal feel back and now when panic stopping it "straight lines" instead of letting the
    "ass Dance"..
    Scary how sometimes "The Easy" actually helps...:thumbsup:
  17. Apr 30, 2024 at 11:44 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
  18. May 1, 2024 at 3:21 AM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    I'll have what he's having please :cool:
  19. May 1, 2024 at 3:39 AM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    artsr2002 and Voss like this.
  20. May 1, 2024 at 4:36 AM
    Only works if the parking break is configured correctly, and the adjuster is functioning.
    The what?
    FrenchToasty and snoope[QUOTED] like this.
  21. May 1, 2024 at 5:20 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Ready for the next 200k miles. Man did near everything needed in one shot.
    FrenchToasty, shifty` and oscardog86 like this.
  22. May 1, 2024 at 5:23 AM
    kentuckyMarksman
    Thanks. That was the goal. PO had a dealership do the timing belt and water pump 2 years ago, so I should be set for a good long while.
    I had to remove so much because I needed to get the rust out of my shock towers and just didn't see the point in putting worn out parts back on.
    BroHon, KNABORES and Voss[QUOTED] like this.
  23. May 1, 2024 at 6:10 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Dude it really is great for resetting! I saved up a bunch of PTO and just left it all behind for 2 weeks. Not a care in the world and offroading and exploring everyday.
    Sitting in those canyons and not seeing a single man made thing around for as far as you can see is pretty amazing. Its like a drug and I think everyone needs to do it once in awhile, haha
    Voss, BroHon[QUOTED], shifty` and 4 others like this.
  24. May 1, 2024 at 6:16 AM
    oscardog86
    Southern California
    Where in California are you located?
  25. May 1, 2024 at 6:30 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If you can see one of the lady's purple dinosaur, they shouldn't be doing headstands in a dress without underwear haha
    NUDRAT[QUOTED] likes this.
  26. May 1, 2024 at 6:47 AM
    oscardog86
    Southern California
    Yea i can imagine its a little harder to get out with 3 kids, but seems like they are getting to the perfect age for camping!
    I just looked up Pagosa Springs, looks amazing. I still need to venture into Colorado one of these days.
    Post some pics of your trip when you get back!
    FrenchToasty likes this.
  27. May 1, 2024 at 7:09 AM
    Are those pecan trees or something else?
  28. May 1, 2024 at 7:31 AM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Awesome, good for you man.
  29. May 1, 2024 at 7:36 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    Redarc makes AWESOME brake controllers.
    I have the Elite in my Land Cruiser and the Liberty in the Tundra
    Beware. You have to cut, grind, heat, press, cuss, cut your fingers, etc to get the knob to fit into the switch blank. If I was going to install another one in another tundra, I would buy the bigger square Redarc switch blank and cut a square hole into the dash. I mounted the box to the steel dash frame directly under the cluster.
  30. May 1, 2024 at 9:07 AM
    snoope
    snoope The Old Man
