  1. Apr 9, 2019 at 3:21 PM
    #5791
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Will do when I get off my lethargic a$$ :)and go get some new blades, theyre bad anyways
  2. Apr 9, 2019 at 3:48 PM
    #5792
    Professional Hand Model
    Hand Protectors
    This is possible and what I thought originally, but the ‘over’ swing is both ways (on both arms). It would make sense if the over swing went only one way that the wiper arms were mis-installed by others. Seems like its over swinging both ways and maybe something loose. Hope its an easy fix!
    His glass looks after market.
    Darkness[QUOTED] likes this.
  3. Apr 9, 2019 at 3:48 PM
    #5793
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Ordered a set of these as well. I may eventually get the rear ones.
    Anyone think the rear set are worth it?
  4. Apr 9, 2019 at 3:53 PM
    #5794
    Hand Protectors
    Not unless you plan on stomping some long distance landings. Only time I’ve ever hit the rear bump stops is when carrying over max load 1600lbs. in the bed and hitting just some regular bumps in the road at normal speeds.
  5. Apr 9, 2019 at 3:59 PM
    #5795
    Hand Protectors
    Those front bump stops interest me and seem like a well designed improvement helper for our shocks for dampening frontal heavy suspension dips. Our OEM ones are hard as rocks right up on the frame.
    Only thing is do the come into play on regular street driving? If not much, then the only benefit is for off-road abuse. Cost from memory is $100 each?
    Sunnier likes this.
  6. Apr 9, 2019 at 4:08 PM
    #5796
    Eugene406
    Eugene406 New Member
    Montana
    2002 Toyota Tundra SR5 TRD
    Bone Stock.
    What lights did you install in your other rig? Do you have any close up pics?
  7. Apr 9, 2019 at 4:23 PM
    #5797
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I have to think they help any time you hit a big pot hole. They are $65 for the front set and wheeler gives a 5% forum discount. Their shipping is high though. Also, I'm sure those original bump stops are shot after nearly 2 decades.
  8. Apr 9, 2019 at 4:44 PM
    #5798
    Hand Protectors
    Wow. $65 isn’t bad even if they rarely get used on potholes. I wish I could test these out on the street before buying them.
  9. Apr 9, 2019 at 4:54 PM
    #5799
    Eugene406
    Montana
    Bone Stock.
    Do these fit the first gens?
  10. Apr 9, 2019 at 5:05 PM
    #5800
    Casper421
    In the woods
    06 DC
    Yes
  11. Apr 9, 2019 at 5:13 PM
    #5801
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes. I sent them a message here on the forum and they said the ones for the Tacoma or newer Tundra are basically the same. You can order either and they will work.
  12. Apr 9, 2019 at 8:38 PM
    #5802
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Nah - 2003+ has a much better smile. Every time I look at the front of my 2003 it's smiling at me. Just a happy truck, makes me smile back.
  13. Apr 9, 2019 at 10:11 PM
    #5803
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I agree. I wish my truck had the newer bumper design. It looks better.
  14. Apr 9, 2019 at 10:11 PM
    #5804
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The front ones do add dampening on the street, maybe moreso if you aren't lifted. I think they were about $100 for a pair and you use one per side. To your point I think the rears won't do a lot unless a full progressive spring pack were used, the original leafs don't often compress enough to gain benefit from a softer bump stop.
  15. Apr 10, 2019 at 2:55 AM
    #5805
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    yes. I have them installed. Not sure why they out 07+ instead of 00+
  16. Apr 10, 2019 at 3:13 AM
    #5806
    because_wumbo-truck
    Jon
    Houston, Texas
    I did the rear just in case since I removed my overloads when I did the progressive AAL in hopes of extra flex out of the stock leaf packs.
  17. Apr 10, 2019 at 4:03 AM
    #5807
    Hand Protectors
    These $100 ones are the same ones FirstgenVol is talking about? $65 a pair plus shipping?
    With my front end Billy Jeans set at one notch up from stock height, will these bump stops need a spacer in your opinion? Looks like they sell a 1/4” and 3/8” spacer.
  18. Apr 10, 2019 at 4:06 AM
    #5808
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
  19. Apr 10, 2019 at 4:47 AM
    #5809
    Hand Protectors
    revtune likes this.
  20. Apr 10, 2019 at 5:02 AM
    #5810
    Dpy
    Dpy New Member
    On my first test drive after all the things I did to truck, felt it drove and rode pretty good but still hoped for a bit better ride with the new taller Mich tires . My first instinct was , I need to check air pressure. Upon checking the pressure , they were all reading around 35 pounds, truck sticker says 29 on front and 32 on back so I brought them down to the correct pressure and then drove about 15 miles and definitely an improvement.
  21. Apr 10, 2019 at 5:31 AM
    #5811
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Looks like your wiper arm spring had come off and the arm had extended to far.
    NUDRAT likes this.
  22. Apr 10, 2019 at 5:41 AM
    #5812
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Oh - good catch, it does look too long.
    Maybe someone was in the cowl to stop the clip leak & the reinstalled the arms on the wrong sides, maybe left arm & right arm are swapped. That would make sense, are they different lengths?
  23. Apr 10, 2019 at 5:57 AM
    #5813
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Same thing. They come to $80.22 with shipping.
  24. Apr 10, 2019 at 7:17 AM
    #5814
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    No spacer, it's pretty tight for space once the truck is on the ground. I had picked up 1/4" spacers and found I didn't need them, I don't think they would even fit.
    I'm not sure about the $65 ones. Check my build thread and you'll see some installed pics and comparisons with stock.
  25. Apr 10, 2019 at 8:41 AM
    #5815
    Hand Protectors
    Will do. I remember you had to jack up the front to let the lower control arms hang to fit the bumps in. I’ll check it later.
  26. Apr 10, 2019 at 8:50 AM
    #5816
    Hand Protectors
    Your windshield has been replaced. The watermark is aftermarket.
    NUDRAT[QUOTED] likes this.
  27. Apr 10, 2019 at 9:16 AM
    #5817
    Need to know stuff
    Maybe, ill check after work, thanks
  28. Apr 10, 2019 at 9:19 AM
    #5818
    speedtre
    speedtre New Member
    Inland Northwest
    Just FYI for everyone, since the first gen tundras are not listed as supported for these, I e-mailed Wheelers and this is what they said...
    "People have used them on the first generation Tundra's.
    They just don't have a warranty on them because of the way they mount.
    They are a little angled once mounted.
    People normally shave the bottom to help them become more straight up an down
    for when it makes contact."
  29. Apr 10, 2019 at 9:20 AM
    #5819
    Need to know stuff
    Do your guys have 2 bumps per side?
    Mine does, on either side of the control arm. I use them alot :)
  30. Apr 10, 2019 at 9:51 AM
    #5820
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    No bumstops = more suspension travel. Just delete them.
    :D
