  1. Mar 25, 2024 at 10:57 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No judgement here. I had the same experience with that guy. He would post on social media but wouldn't call me back. Great business model dude.
    Voss, shifty`, oscardog86 and 3 others like this.
  2. Mar 25, 2024 at 11:06 AM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Little weekend camp trip. Rained most of the time but the kids didn’t mind
    Voss, BroHon, VR6T and 11 others like this.
  3. Mar 25, 2024 at 11:37 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've left mine alone. If I'm driving at night and my wife is with me and turns on the passenger side light it just projects right to the seat and doesn't bother my vision at all. I worry with removing the cover that it will be in my eyes at night.
  4. Mar 25, 2024 at 5:08 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    Tire rotation, fronts to backs, backs to fronts.
    Pulled and pluged the roofing nail I pcked up the day I stopped to help that over turned semi, no good deed in all....0325241818.jpg 0325241820.jpg
    Then welded up a pinhole in one of my exhaust joints. Did a sound test.
    https://youtube.com/shorts/luU1a4TWbbQ?si=5w72K9WDv0HFNJ90
    Voss, NUDRAT, The Black Mamba and 5 others like this.
  5. Mar 25, 2024 at 5:19 PM
    VR6T
    And these arrived today
    Braied break lines and my Ujoint. Now all I need is a extended Ubolts flip kit. Anyone got any affordable reccomendations. @Mr.bee sent me a few but none for an 00 to 06 tundra 8 inch
  6. Mar 25, 2024 at 5:45 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    U bolts are so weak. Get some W bolts.
    VR6T likes this.
  7. Mar 25, 2024 at 6:46 PM
    VR6T
    And they both got a cleaning. Garage got moved around and cleaned up a bit as well
    Big ole moon tonight
  8. Mar 25, 2024 at 7:48 PM
    VR6T
    Just a reminder for everyone here. After you fuck with your tires drive your truck for 5 to 10 miles and then go check your lug nutss torques spec. I torque mine to 104, OEM max, 100 to 104 FtLb. Did 5 miles 25 to 60mph. Fronts were fine but the rears 10 out of 12 needed re torqued down. But I did all of them as you should.
  9. Mar 26, 2024 at 3:18 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Where does the 104 OEM Max come from? Never heard that before. I always do mine to 90 because I mistakenly thought that was the spec. I think the actual number is 83.
  10. Mar 26, 2024 at 5:39 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Ive been doing 83 for years with no problems and the Toyota mechanic near me does 83 as well.
    Plus it also says 83 ft/lb in my FSM
  11. Mar 26, 2024 at 6:00 AM
    shifty` Inside his chest they found ten thousand pencils
    I've been doing 85 because hitting 83 on my TW isn't easy for my shit eyes. And I can confirm, it's about 25% less than what I used in uggaduggas with a crossbar with my factory alloys, which IDGAF about. I always go back within 100mi to double-check, as should anyone...
    oscardog86 likes this.
  12. Mar 26, 2024 at 6:04 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    Any of you guys had issues with wheel studs breaking over time? When I had my tires replaced the first time the guys broke two studs. When I had my new wheels out on discount tire broke another stud.
    the second time was most likely because the dude at the first shop cross threaded the lug nut, but I’ve never had a vehicle that’s broken this many. I went to Napa and bought all they had as spares and have to replace one of the rears this week still.
  13. Mar 26, 2024 at 6:10 AM
    Yes. I had two break on attempted removal when I changed my tires the first time, after getting a flat. I'm convinced it's because apes at the f'n tire shops my previous owner was using were over-torquing, the threads were clearly stretched on the studs.
    Note: Dorman studs are great. The rears are different length than the front (unless you have discs in rear), which is an important note. Here are the Dorman part numbers for our '06, which any LAPS should carry:
    abcinv, FirstGenVol and oscardog86 like this.
  14. Mar 26, 2024 at 6:12 AM
    oscardog86
    Southern California
    Broke a couple when I first bought the truck and the shop i had work done at over torqued it. Ever since always doing it myself at 83 ft lbs its been fine.
    Whenever I need to get work done that I cant do, I try to tell the shops 83 ft lbs for the lug nuts. That goes over real well, lol. However the last time I got new tires, Discount Tire obliged and hand torqued them all! I watched them do it, was very pleased.
  15. Mar 26, 2024 at 6:20 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    My 2000 spec is 83 ft-lbs. Awoke to a flat with broken valve stem yesterday and had to remove wheel to replace valve stem. I looked it up.
    des2mtn and oscardog86 like this.
  16. Mar 26, 2024 at 6:39 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    One thing I like about Discount Tire is that they always use a torque wrench on my vehicles. If you notice, the torque spec is even printed on the receipt they give you. I wish they would be a little more careful with the air gun when removing but that's wishful thinking.
  17. Mar 26, 2024 at 9:05 AM
    VR6T
    I "found"/ read it in a "Toyota" PDF I down loaded looking for the torque spec for the UBJ castle nut torque spec. It said for the reassembly process to torqe the lugs to 100 to 104, so thats what ive done for the last 4 years
    455h0le_dachshund likes this.
  18. Mar 26, 2024 at 9:10 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    same, I emailed him, he responded once and never again. unfortunately, I'll never recommend the fellow TX boy known as "firstgenoffroad".
    Hiit up @memario1214 from HotshotOffroad.com, he came to me (when I was asking about SL.com) and his communication/replies were very timely and he price matched SL.com[/QUOTE]
  19. Mar 26, 2024 at 9:16 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    FSM has it listed multiple places as 83 ft/lb. I personally do 86, that's what Discount seems to always use on my truck.
    BroHon, oscardog86 and FirstGenVol like this.
  20. Mar 26, 2024 at 9:51 AM
    des2mtn
    SW
    Tonto cover
    I second Hotshot Offroad as an excellent vendor. They have a bigger catalog than what's listed on their site if there's a certain product you're looking for.
  21. Mar 26, 2024 at 10:30 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    Is there a vendor list that indicates what vendors support the FGT even though their websites indicate otherwise? Other than the replies here, I had never heard of Hotshot. I did stumble across Hotshot while shopping but noticed their website doesn't even mention the BEST GEN TUNDRA so I went elsewhere :rolleyes:
  22. Mar 26, 2024 at 10:34 AM
    FishNinja
    Lee
    06DC2wd
    not that I am aware of. But Hotshot went out of their way to order my parts and put them together. And kept me in the loop the entire time.
    flyfisher and oscardog86 like this.
  23. Mar 26, 2024 at 11:07 AM
    Vendor subforum is a place to check for official vendors. https://www.tundras.com/categories/official-vendors.7/
  24. Mar 26, 2024 at 12:32 PM
    87warrior
    Kansas
    2004 DC 2uz 4x4
    shifty`[QUOTED] likes this.
  25. Mar 26, 2024 at 12:33 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Be better. You been here long enough to know there is
  26. Mar 26, 2024 at 12:43 PM
    FishNinja
    Lee
    06DC2wd
    I literally only come to this forum and maybe the fishing one. It took me awhile to even realize there were more subforums.
  27. Mar 26, 2024 at 1:04 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  28. Mar 26, 2024 at 1:12 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I’ll have my truck running again before @455h0le_dachshund has his parts in hand :rofl:
    Pulled the driveshaft to begin replacing the RMS. I’ll get a good pic of the completed motor once the engine bay is washed down.
    Voss, NUDRAT, BroHon and 7 others like this.
  29. Mar 26, 2024 at 1:26 PM
    You replacing the engine rear main seal or the transmission output shaft seal?
  30. Mar 26, 2024 at 1:26 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Rear main. getting ready to pull the trans
    BroHon and 455h0le_dachshund like this.
