  1. Mar 16, 2024 at 8:21 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Are you sure that’s not just an extra fuse holder? Looks like ‘radio 1’ should be that 15 amp one above the Densor relay, and it should be a 20amp, not 15.
    87warrior, shifty` and NUDRAT like this.
  2. Mar 16, 2024 at 9:05 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I’m going to mess with it in the morning . Everything started working instantly after I put a 20amp in that empty slot
  3. Mar 16, 2024 at 9:16 PM
    PenderBen
    2003 Tundra AC 4x4
    Weird, I don’t honestly know offhand, just how I’d interpret the schematic, but strange if there was nothing in there and it’s been working all this time. Post a follow up, I’m curious.
  4. Mar 17, 2024 at 8:07 AM
    Wait ... you're not dating @Mikewinters1976's girlfriend are you?
  5. Mar 17, 2024 at 8:09 AM
    I think if you look carefully in there, you'll see there's no metal contacts, it's for you to install a spare fuse. Are you sure you didn't just have a gremlin for that specific run cycle, and it stopped when you pulled the key and drove again the next time?
    FYI your RAD #1 fuse is currently a 15A and should be a 20A.
  6. Mar 17, 2024 at 8:11 AM
    Key off this 7.5A fuse and compare everything around it on the two pics.
    BroHon likes this.
  7. Mar 17, 2024 at 8:37 AM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    The location circled in white is the spare fuse holder.
    The 15 amp fuse next to it is for the radio.
  8. Mar 17, 2024 at 11:52 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Tinkered with the E-brake cable and sprayed some PB blaster on the inside of the the rubber boot covering the bell cranks and moved them back and forth. Helped everything some. Got into adjusting little star thingy from backside.of backing plate and ran outta time. Slack is mostly gone after bell cranks freed up some and now when I push E-brake and release it there isn't a big ass droop anymore. Took up some slack at the turnbuckle under drivers seat too.
    Now I need to read through @Aerindel posts before the adjustment process happens again so I fully understand everything.
    I saw a video and read somewhere that it's best to start from the back with elthe E-brake cable and components and work towards the front for adjustments in general?
  9. Mar 17, 2024 at 12:12 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Washed both vehicles and gave each a coat of Griots 3-in-1. So much faster than waxing and seems to last a long time. Confirmed most of my leaks on the camper shell are fixed. I think it will be mostly dry once I replace the window seals. Also changed the oil.
    Ravioli still looks good for being 12 years old.
    txagg, Voss, bmf4069 and 9 others like this.
  10. Mar 17, 2024 at 12:14 PM
    Looks like the cap has another 1/2" or so it can move toward the cab.
    abcinv and FrenchToasty like this.
  11. Mar 17, 2024 at 12:37 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No it's pretty close as is. I moved it too close once and it touched and made annoying noises against the cab.
    shifty`[QUOTED] likes this.
  12. Mar 17, 2024 at 12:46 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    V6 by chance???
  13. Mar 17, 2024 at 2:48 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No. I sometimes wish I bought the V6 but money was tighter back then. The 4 banger has been adequate.
    abcinv[QUOTED] and FrenchToasty like this.
  14. Mar 17, 2024 at 4:02 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Threw some 3/4” drop shackles on the rear since everyone is so jealous of my perky rear end…..
    wasn’t to bad of a job, maybe 3 beers. I didn’t jump on the rear end or anything after but it looks like I lost about 1/2” of lift total, I could go for another 1/4-1/2” so I’ll check later this week after driving it a bit.
    63AAA02A-94CE-451B-AD3E-138E3658FA23.jpg I also noticed on the inboard side of both hangers, the bushing rubbed into the metal a decent amount, so I need to be better about pumping them with grease more often….. more often than never hahah
    Voss, 805Tundra, bmf4069 and 7 others like this.
  15. Mar 17, 2024 at 4:05 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah I never grease mine either hahaha
    But I'm the opposite on the shackles, I want to invert mine like they should've been designed in the first place, to gain some lift. I don't think I could go any shorter as is, but inverted would gain some inches and then I could go longer (not that it would be necessary)
  16. Mar 17, 2024 at 4:06 PM
    FrenchToasty
    Mo
    Bone stock
    Yeah I wish it was that simple with our trucks
  17. Mar 17, 2024 at 4:08 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I watched some 1"BL install videos last night. First Sequoia and first gen Tacoma. Seems simple enough. I might finally dig my 4crawler 1"BL out of the parts pile and install it soonish.
    oscardog86 and KNABORES like this.
  18. Mar 17, 2024 at 4:09 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The SOS drop kit inverts their shackles, so it doesn't slam the rear, because it also flips the axle to SUA. It would probably be like a 6 or 8 inch rear drop otherwise. Would be sick, but probably require a C notch frame
  19. Mar 17, 2024 at 4:12 PM
    I think I need this to run 33” tires
  20. Mar 17, 2024 at 4:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If you don't want to trim, then it would probably be ideal. I bought it to fit 35's eventually
  21. Mar 17, 2024 at 4:16 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The rear was too high?
  22. Mar 17, 2024 at 4:19 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I cant make sense of this. What did you watch?
    FrenchToasty likes this.
  23. Mar 17, 2024 at 4:43 PM
    FrenchToasty
    Mo
    Bone stock
    Yeah it seemed to be, even fully loaded it was a hair high. We will see how it settles out and how I like it loaded. Next option would be swap shackles back and possibly pull a leaf
    805Tundra and RUSTYNUTS like this.
  24. Mar 17, 2024 at 4:50 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I liked the stinkbug stance.
    how much more could you have lifted before the driveshaft fell apart?
    Voss and FrenchToasty like this.
  25. Mar 17, 2024 at 4:59 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Videos of people installing a one inch body lift on first gen Tacoma and first gen Sequoia
  26. Mar 17, 2024 at 5:29 PM
    FrenchToasty
    Mo
    Bone stock
    Hahah I didn’t want to find out, but I’m sure my splines are happier now
    805Tundra likes this.
  27. Mar 17, 2024 at 10:07 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
  28. Mar 18, 2024 at 2:52 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I just have to figure out how to jack up my body with my sliders already welded to the frame. I know it can be done. I just have to figure out the logistics. Probably going to need @Mr.bee level planning
    Voss and BroHon like this.
  29. Mar 18, 2024 at 6:00 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Bought a welder 2 years ago, just a cheap flux core. Learned from youtube and have been making all sorts of cool shit.
    I tell anyone even remotely interested in welding... Do it! Such a fun skill even if your welds arent the best. Was getting my alignment done a few weeks ago and some of the guys were asking about the stuff on my truck I had welded. One guy said when he saw my flux core welds, "Dude just prep the metal correctly and its gonna hold. Using gas is almost cheating." Yea im not welding up a roll cage or something that my life depends on, but for most welds you can definitely just teach yourself and get by.
    Voss, 805Tundra, BroHon and 1 other person like this.
  30. Mar 18, 2024 at 6:08 AM
    oscardog86
    Southern California
    BL?
    Nevermind, just caught up and saw what BL was, haha
