  1. Feb 23, 2024 at 9:51 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Been there. Dig through various bits drawers in garage and find a little piece of metal like a picture hanger strip or corner bracket. Get them needle nose and cutters out and bend new clip. Test fit, adjust, discard, repeat as necessary. Key is for it to put outward pressure on knob and then can bend gap ends inward to grab the stem.
    But once found these would prolly do this next time. Way easier.
  2. Feb 23, 2024 at 9:53 PM
    ToyotaDude
    ToyotaDude Member
    Truck came with both. Garage door holder still in little cardboard box in garage.
  3. Feb 23, 2024 at 10:33 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I have an 06 double cab and I went with these bolts when I did mine they are way cheaper. I paid $1.27. They should work on your 03 AC and save you $20
    part number 90080-10330
    txagg likes this.
  4. Feb 23, 2024 at 10:55 PM
    ToyotaDude
    ToyotaDude Member
    https://www.rockauto.com/en/moreinfo.php?pk=916948
    Thanks. Are those the valve cover bolts? Just planning to swap the rubberized bolt washers. My bolts have all been loose and snugged up fine recently (but cover still leaks) so don't think any will snap when removing.
  5. Feb 23, 2024 at 11:42 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    If you find the small metal clip, put a dot of super glue on there so it'll stay on the knob and let it dry before you pop the knob back on the dash. I've had to do that before.
    albru2[QUOTED] likes this.
  6. Feb 23, 2024 at 11:46 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    That’s the bolt with the washer combo
    ToyotaDude[QUOTED] likes this.
  7. Feb 23, 2024 at 11:47 PM
    artsr2002
    'Yonder
    LOL :D
    FishNinja and bmf4069[QUOTED] like this.
  8. Feb 24, 2024 at 5:11 AM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
  9. Feb 24, 2024 at 5:33 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  10. Feb 24, 2024 at 5:36 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    VR6T[QUOTED] likes this.
  11. Feb 24, 2024 at 5:40 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I weld about as good as I play basketball. I don't play basketball or own a basketball.
    Time for new spark plug tube seals and a valve cover gasket!
    They wanted me to drop it off for a few hours but i had shit to do. The other placed had flowmasters, but i dont want a flowmaster.
  12. Feb 24, 2024 at 5:40 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  13. Feb 24, 2024 at 6:41 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    if the plugs are clean after a run to town & an oil change, i'll put it on the list. Gonna jack it up & pull the wheels to check the suspension & brakes, too.
    no tacos
    No panic
    bmf4069[QUOTED] and BroHon like this.
  14. Feb 24, 2024 at 8:11 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Why you no likey the Flowmaster? I thought it made my truck sound great.
    When I first got the DD exhaust, I really missed the Flowmaster and thought I had made a mistake.
  15. Feb 24, 2024 at 8:20 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    No seatbelts :p
    FrenchToasty likes this.
  16. Feb 24, 2024 at 8:24 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    No fucks
  17. Feb 24, 2024 at 9:22 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    Installed my steering rack, and pressed out the hubs, wheel bearings, and upper ball joints. Bearings came apart when pressing the hubs out but thankfully the inner bearing races didn't stick to the hubs.
    My steering knuckles are rusty and have some broken bolts on them so I plan on removing the rust, painting, and trying to get these bolts out.
    des2mtn, shifty`, bmf4069 and 4 others like this.
  18. Feb 24, 2024 at 10:45 AM
    The Black Mamba
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  19. Feb 24, 2024 at 11:17 AM
    VR6T
    I infact did not say that, however it is good to know. I ws just learning engine codes is all lol.
  20. Feb 24, 2024 at 11:26 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    5VZ-FE: The bullet proof V6 of the gods. Hand crafted with the Uchide no kozuchi, a legendary Japanese "magic hammer" which can "tap out" anything wished for, and is wielded by Daikoku-ten in popular belief.
    The Black Mamba, bmf4069 and VR6T like this.
  21. Feb 24, 2024 at 11:34 AM
    VR6T
    :rofl::rofl:
  22. Feb 24, 2024 at 12:07 PM
    I have my old OEM spares. I sent a metal clip to at least one member. But that said, the square black plastic part likes to crack which is how the metal clip slides out. Replace the knob. Know the cheapies on scAmazon tend to allow light to bleed out around the edges of the knob. Cheap quality.
    I tried tons of different stuff, shrink wrap, a couple types of glue, I couldn't get anything that would hold, and not allow the knob to slip. Once the plastic cracks, it seemed like a waste of time to try repairs.
    "LC" kit?
    https://www.tundras.com/threads/valve-covers-fix-or-leave.105385/#post-2712883
    All parts and process are there. I re-used my half moons, saved me $30. I replaced my hardware with the washer+bolt (p/n 9008010330) which are about a buck a piece at $18 total, saved me another $30-40. I'm VVTi so cam seals aren't an option for me to do easily.
    But hey, if you want to go Felpro, go for it. I trust their stuff. I figure I want to do this once to hold me over the next 10-15 years, so if I'm spendng $30-40 more to go OEM and get OEM longevity, I'm going to do exactly that.
  23. Feb 24, 2024 at 1:37 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Whoops, shoulda specified double wall adhesive heat shrink. It's lined with hot glue.
    des2mtn likes this.
  24. Feb 24, 2024 at 1:40 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Anyone who’s done a valve cover job know if the PCV valve grommet comes through to the other side visibly? I’m wondering if I’m at risk for dropping a piece of gasket inside (where I can’t fish it out) in case it tears trying to pry it out.
    No luck so far with the engine cold. Will try again after it’s been running hot.
  25. Feb 24, 2024 at 1:52 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Fixed the fog lights (fuse), reverse lights (switch on trans), coolant leak (tightened clamps), mismatched lug nuts, license plate lights (bulbs), & the plugs are still good & the stumble is still gone. Oddly, no money light & the o2 sensor was loose. Put some led headlights in it, but waiting for dark to aim em.
  26. Feb 24, 2024 at 1:55 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    There is a baffle under the grommet but pieces can still migrate through the spaces at the ends of the baffle. WhenI did mine the grommet broke but I was able to grab it with a needle nose.
  27. Feb 24, 2024 at 2:05 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Decided I've procrastinated long enough and I'm going to tackle the inner tie rods. Any last minute tips I should know? My understanding is that the new inner has a washer that has to be bent/staked as a fail safe?
    I have new OEM bellows going over Moog inners.:anonymous:
    Hoping you guys aren't lying about Moog inners being fine.
  28. Feb 24, 2024 at 2:22 PM
    Jack McCarthy
    Bill
    North of Boston
    Good to know. Thank you!
  29. Feb 24, 2024 at 2:25 PM
    Jack McCarthy
    Bill
    North of Boston
    I seem to recall there being a tab on a washer you have to bend 90 degrees? Been a while. Should be obvious when you look at it.
  30. Feb 24, 2024 at 2:38 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Well I was planning to reuse these OEM outers. They have around 33k miles on them. What does Tundra Gang say? I mangled the tip and it's leaking.
    Voss likes this.
