  1. Feb 23, 2024 at 3:48 PM
    Azblue
    The Dirty T ( ^_^)_且
    But what about an SC'ed 5.7? :boink: :poking: :rasta:
  2. Feb 23, 2024 at 3:51 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    How about a foged internals non VVTI turbo camed 4.9L Turbo SC with 3.73 gears and an LSD in the rear end?
    Azblue[QUOTED] likes this.
  3. Feb 23, 2024 at 3:52 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Would you want it in a 4R or a taco?
  4. Feb 23, 2024 at 3:52 PM
    Azblue
    Na, 4.9 is too small, and it's a Ferd.
  5. Feb 23, 2024 at 4:45 PM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    I have no idea why the bottom half just goes MIA. The previous owner of my truck was an avid hunter so I wonder if driving through brush ripped the bottoms out.
    The boots are easy to change. Put the front end on jack stands and measure the length of the tie rods. Cut the boot remnants off and loosen the tie rod nut. Unscrew the inner tie rod from the outer. Remove nut and clamp. I cleaned up the inner tie rod and applied some moly grease to the joint. Slide boot over tie rod, slide on inner clamp and nut. Screw the inner tie rod back into the outer and set the length as it was before.
    The Black Mamba likes this.
  6. Feb 23, 2024 at 4:47 PM
    VR6T
    Nope bored and stroked 2uz
  7. Feb 23, 2024 at 5:36 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Not a tundra, but plugs, wires, and a coil fixed a slight stumble on this svt. Plugs were oily, gonna check the new plugs after a run to town tomorrow.
  8. Feb 23, 2024 at 6:04 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    This checks out.
    Except I actually like how the 5VZ sounds, even stock.
    The 1GR sounds great with long tube headers.
  9. Feb 23, 2024 at 6:07 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'd love a sc'd 4.0 with a 6 spd. If I found a low miles Speedway Blue one... I'd probably be inclined to sell my 03 street queen McNasty.
    :burnrubber:
  10. Feb 23, 2024 at 6:10 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Wait ... No one had any that fit or anything that you wanted or what?
    I should've kept my flow master 40 when I got my DD exhaust installed. But I didn't even think to ask the dude for it. Otherwise I'd give it away. :oops:
  11. Feb 23, 2024 at 6:15 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Was this after or before installing the new LEDs?
  12. Feb 23, 2024 at 7:49 PM
    albru2
    albru2 Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    Just in case you haven't explored this particular first gen crevice: found a pick-n-pull sunglasses holder to replace the garage door opener holder that came with my truck. :spy:It feels like you're going to break something trying to remove these but you can see in the second pic that it's held in by a curved plastic clip. I pried the clip up with a flathead and it popped out without breaking. Strangely satisfying upgrade.
  13. Feb 23, 2024 at 7:50 PM
    VR6T
    This was durring the test fit for the bulbs as the housings havent arrived yet. I was checking my wiring work before work and was getting all heated that the lights wouldn't come on, thought there was a short or a break. I got to work and was like all go check the fuse you idiot, sure as shit....
  14. Feb 23, 2024 at 7:52 PM
    VR6T
    My truck came with the sunglasses holder. Nit sure if it was like that from factory. How well did the garage door opener work?
  15. Feb 23, 2024 at 7:54 PM
    VR6T
    5VZ was the 3400 and the 1GR is the 4.0L correct?
  16. Feb 23, 2024 at 7:57 PM
    albru2
    I never even tried it as I don't have an opener. Even if I did I'd still rather put my sunglasses there I think though.
    VR6T likes this.
  17. Feb 23, 2024 at 7:59 PM
    albru2
    has anyone come up with a clever way to replace a lost heater knob metal clip?
  18. Feb 23, 2024 at 8:02 PM
    VR6T
    Super glue, hot glue or JB Weld lol. But for real, get some release agent put it on the stem and you can fill the knob with hot glue and from fit it.
  19. Feb 23, 2024 at 8:08 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Not wise if you plan to install a new head unit.
    artsr2002 and 455h0le_dachshund like this.
  20. Feb 23, 2024 at 8:08 PM
    albru2
    OK! I was thinking tape on the stem but that sounds more fun
  21. Feb 23, 2024 at 8:09 PM
    VR6T
    Heres the bulbs on the test fit after I went on lunch and got a fuse kit from advanced. They cast pretty good
  22. Feb 23, 2024 at 8:13 PM
    VR6T
    Its not perminently a fixed to the stem. It just form fits it is all. Makes it a snug fit. A long term temporary fix. I did this in my MKiv GLI before a car how to my radio power volume knob. I replaced it like 2 months later with an Alpine head unit. A fellow judge gave me the idea. As long as the stem is metal and you clean it with alcohol before aplying the release agent it should be fine
  23. Feb 23, 2024 at 8:14 PM
    VR6T
    Double sided tape a quality one could work as well.
  24. Feb 23, 2024 at 8:20 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Heat shrink around the plastic if it's split. Drop of E6000 glue inside.
    Edit: double wall or adhesive heat shrink.
    VR6T and albru2[QUOTED] like this.
  25. Feb 23, 2024 at 8:26 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    VR6T[QUOTED] likes this.
  26. Feb 23, 2024 at 8:27 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I just bought a set of three new knobs for $10 on scamazon
    KNABORES and VR6T like this.
  27. Feb 23, 2024 at 8:42 PM
    albru2
    My stems are plastic actually
  28. Feb 23, 2024 at 9:22 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I thought the consensus lately is Moog anything is pretty much trash these days?
    VR6T likes this.
  29. Feb 23, 2024 at 9:25 PM
    artsr2002
    'Yonder
    That's called a taco holder.
  30. Feb 23, 2024 at 9:32 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    You mention some LC Kit that is cheaper way to go? Will it fit 03 AC 4x4 v8?
    Love Toy quality but in this case seems kinda steep at $168 even during 25% off sale to replace the valve cover gaskets and bits when AM kits from RA are like $20-$50, unless someone knows an AM kit that has high quality.
    Worth getting the cam plugs and halfmoons (that don't usually come with those AM kits) along with these other Toy parts, or just get the Felpro kit ok for like $33?!
