  1. Feb 11, 2024 at 6:32 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Those covers can be pried on and off multiple times over...at least on both my 2000 and 2004 AC trucks. I was doing the whole lock tumbler swapperos on both side doors, passenger side airbag key, tailgate key, and ignition key! The locksmith wanted $75 per lock. I passed on his offer. Instead i did it myself. I used a small Wera flat blade screw driver to pry the stainless steel lock cylinder covers off the cylinder itself.
  2. Feb 11, 2024 at 6:39 PM
    whodatschrome
    lots of dents
    try looking at it from a male point of view...
    https://m.youtube.com/watch?v=2OKwRsnWO84
    455h0le_dachshund likes this.
  3. Feb 11, 2024 at 6:46 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    My cousin & grandpa are into it. Well, they've enjoyed the 15 minutes of gameplay, and are confused by the 2.5 hours of ads.
  4. Feb 11, 2024 at 7:10 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    No sludge?
  5. Feb 11, 2024 at 7:21 PM
    shifty` Inside his chest they found ten thousand pencils
    No sludge but a hefty amount of varnish all over the heads and crust cooked into the valve covers.
  6. Feb 11, 2024 at 7:29 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I bought my 06 with 199k for $9500 and my 03 with 336k for $2800.
    oscardog86 and metalpete[QUOTED] like this.
  7. Feb 11, 2024 at 7:34 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    Everything I did today. Went to do the front brakes, none of my caliper tool work on the tundras front calipers. Ordered a cornwell ratchet piston pusher.
    Spent a 3 hours scrubbing the captians chair arm rests. Pass side went from blue brown to just blue. Driver side went from black caked on stuff and human skin cells to just blue again. Its amazing what you can clean with Dawn, water, some brushed, 99% isopropyl alcohol and a shop vac.
    Carpets went from mudded blue brown to blue, aside from the driver side, its gonna need chemical guys cleaner. But it looks, smells and feels clean.
    Then on my way to Orielys to get 3m double sided weather strip tape my dome light blew out, replaced it with a Sylvania 6000k led. Im not a fan of the color, too blue. I need/ want a more a white temperature color.
    Replaced my axle pressure vent.
    Pulled my third brake/ cargo light and removed the dog shit weather strip that came from chy-nna and applied the before mention 3M weather tape.
    Got some chineese on the way home, tightened the side mirror housings as they were loose..? somehow.
    Ate a gummy, now on the couch fir the rest of the night. I did all of that after cutting my lawn, doing the trim, welding and failing to build a fire pit out of tree rings surrounds. Not all metal will or wants weld up nicely. So I just cut a 55 gal drum in half, and I'll go get pavers to make a new fire pit.
  8. Feb 11, 2024 at 7:40 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I've always just used a c-clamp or two and old brake pads to push in the pistons.
  9. Feb 11, 2024 at 7:55 PM
    This is all I’ve ever done with new pads, my entire life. No specialty tools. Use the old pad if multi-piston, c-clamp directly if single piston.
  10. Feb 11, 2024 at 8:14 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Well shit. I seem to have bitten off more than i can chew.
  11. Feb 11, 2024 at 8:24 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What else did you put back there since you left here?
    So, next time maybe take advice from a guy who might know a thing or two about AALs :boink:
    Or hell, what'd you do with those helper bags I gave ya?
    oscardog86 likes this.
  12. Feb 11, 2024 at 8:28 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    :oops: I know... its in the plan, but i found a dismembered tree carcass, and kept loading until it was level. Well, its level. Albeit squatting like a dog with worms.
  13. Feb 11, 2024 at 8:30 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Y'all are fancy. I just use my 460 channel locks with a rag.
  14. Feb 11, 2024 at 8:30 PM
    des2mtn
    SW
    Tonto cover
    Break out the spare leafs and the angle grinder :sawzall:
    Also get that wiring in the frame rail you animal
    Voss, txagg, shifty` and 3 others like this.
  15. Feb 11, 2024 at 8:31 PM
    des2mtn
    SW
    Tonto cover
    You mean the big blue oil filter wrench?
    Hi06silver, Voss and bmf4069[QUOTED] like this.
  16. Feb 11, 2024 at 8:34 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's gonna be a fun drive on the i10
    shifty` likes this.
  17. Feb 11, 2024 at 8:39 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I'll drop some off at my brothers. Theres a giant chunk of trunk i want i'm gonna try to get him to help me with.
    Voss, metalpete, VR6T and 1 other person like this.
  18. Feb 11, 2024 at 8:41 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    He does have the leaf packs we took off my 03 in his truck bed...
    des2mtn[QUOTED] and Mr.bee like this.
  19. Feb 11, 2024 at 8:43 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I need longer u-bolts.
    des2mtn likes this.
  20. Feb 11, 2024 at 8:48 PM
    ToyotaDude
    ToyotaDude Member
    Don't have a full set of steelies but the original starfish don't get as dirty and clean up with just a smidge of elbow grease and mag polish.
  21. Feb 11, 2024 at 8:48 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I bet we can find some at the AutoZone or O'Reilly that are both about 100 feet from my house. Or the Napa about three blocks away. Or the Advance about a mile away.
    I'm supposed to do a four hour training on the computer at my new job tomorrow. They still haven't told me what time to come in. I'll call em while taking my morning walk. But we could maybe do some science shit. I got a angle grinder and sawzall and a band saw. Or if it's a workout you want, I got hand saws.
  22. Feb 11, 2024 at 9:12 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    VR6T, txagg and des2mtn like this.
  23. Feb 12, 2024 at 3:35 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That's the ones! But mine are yellow handle knockoff Kleins. Guess I should call them "pump pliers" instead of channel locks.
  24. Feb 12, 2024 at 6:00 AM
    VR6T
    Now thats a suspension kift
  25. Feb 12, 2024 at 6:03 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    You out there burl huntin'?!
  26. Feb 12, 2024 at 6:32 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    just a big ash. And i dont wanna burn all my oak, and finished off my cedar pile.
    Voss and metalpete[QUOTED] like this.
  27. Feb 12, 2024 at 8:40 AM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    Got my oil changed today and learned that I had coolant leaking into my oil. So that should be a fun journey.
    Voss, Filthyphil and VR6T like this.
  28. Feb 12, 2024 at 9:08 AM
    VR6T
    Dam man, hopefully its something non fatal. But it was a good catch
    Worst come to worst engine rebuild with 11.0:1 CR pistons and upgraded connecting rods.
    whodatschrome likes this.
  29. Feb 12, 2024 at 9:11 AM
    Solid Snake
    West TN
    2006 AC 4x4 V8
    It wasn't there (or at least it wasn't brought to my attention) at my last oil change in September, so its probably a new problem. Its been driving just fine. I'll look into getting it fixed next month sometime.
    Voss and VR6T[QUOTED] like this.
  30. Feb 12, 2024 at 9:24 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Next time, unzip, remove 14mm bolt. Separate fabric from foam and throw in washing machine. Air dry and reassembly. Time is money.
    Voss, Filthyphil, BroHon and 2 others like this.
