  1. Feb 9, 2024 at 8:15 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    How do you like those sway bar links?
  2. Feb 9, 2024 at 8:43 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Seeing the gauge in that position really makes me wonder if the gauge is seated on the shaft properly.
    Does it bounce when you hit bumps? Maybe it's wrapped all the way around past max and is physically stuck. I'd say pull the cluster and the face and investigate, just keep your greasy fingers off the black cluster face or the finger prints will stay there.
  3. Feb 9, 2024 at 9:08 AM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    I wasnt aware, so most likely not.
  4. Feb 9, 2024 at 9:13 AM
    VR6T
    No it just sits there. I am about to go change out some bulbs, so i will have a looksee
  5. Feb 9, 2024 at 9:58 AM
    VR6T
    Well still no workie. All bulbs replaced. Checked the sensor again. Cleaned the pins. IDFK. Might need physical help with this one. Wish I as better with electronic shit.0209241155.jpg
    Voss likes this.
  6. Feb 9, 2024 at 10:02 AM
    NickB_01TRD
    Nick
    KY
    So you tried to move the gauge around with your finger or what's up with it? No matter where you put it, it just doesn't really try to go anywhere meaningful?
    oscardog86 likes this.
  7. Feb 9, 2024 at 10:28 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I don't recall if these trucks have an panel test. Usually it's something like hold the trip reset down and turn the ignition on. Then it cycles through every light and sweeps the gauges low to high.
    des2mtn likes this.
  8. Feb 9, 2024 at 10:52 AM
    VR6T
    I moved it from its curent position to the max heat mark and it just springs back down to its no reading position.
  9. Feb 9, 2024 at 10:57 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Do you have a multi-meter? Check the cluster/ gauge itself.
  10. Feb 9, 2024 at 11:42 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I thought we were talking about oil pressure
    BroHon and 455h0le_dachshund like this.
  11. Feb 9, 2024 at 12:09 PM
    VR6T
    We are, the max heat or temp level aka the over heating mark
  12. Feb 9, 2024 at 12:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The coolant gauge is measuring temperature.
    The oil pressure gauge is measuring PSI.
    BroHon and The Black Mamba like this.
  13. Feb 9, 2024 at 12:13 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    So we are on the same page, you are referring to the upper left gauge, correct?
    455h0le_dachshund likes this.
  14. Feb 9, 2024 at 12:21 PM
    VR6T
  15. Feb 9, 2024 at 1:02 PM
    shifty` Inside his chest they found ten thousand pencils
    This reminds me, it's been 1-2 weeks since I installed my new LBJ and bolts. I need to get under the truck this weekend to re-check torque, then mark my bolt positions
  16. Feb 9, 2024 at 1:14 PM
    VR6T
    This is the new sensor I put in last fall. Pretty sure its a Doorman. Right above my finger.0209241448.jpg
  17. Feb 9, 2024 at 1:15 PM
    Looks juicy
  18. Feb 9, 2024 at 1:21 PM
    albru2
    albru2 Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    so far so good, but I just got them in last night after work. I wasn't having a problem per se with the originals but the bushings were pretty toast and I did get close to 2" of lift from my springs so I was more following the advice from this forum. It did seem a little quieter on bumps driving around the block but kind of like how my truck sounds better after changing the oil, probably a figment of my imagination.
  19. Feb 9, 2024 at 1:27 PM
    My custom “extended” factory sway bar links are still going strong. Would appear my TRE boots have come loose. Really need some TLC on this front end. Maybe when I do the front wheel bearings….
  20. Feb 9, 2024 at 1:33 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Highly recommend this stuff if you ever need to do touch up paint work. I'm not sure if they offer every color but they have Work Van white.
    Voss, bmf4069, BroHon and 6 others like this.
  21. Feb 9, 2024 at 1:37 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I used that stuff in Toyota natural white 056 for my mismatched door trim and it wasn't even close. YMMV
  22. Feb 9, 2024 at 1:41 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Bro your truck hasn't seen wax since the Bush administration. No wonder it didn't match.
    Voss, khooiii, Dirt Ferguson and 10 others like this.
  23. Feb 9, 2024 at 1:44 PM
  24. Feb 9, 2024 at 1:45 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :anonymous: maybe... :laugh:
  25. Feb 9, 2024 at 2:27 PM
    I got custom mixed touch up paint from AutomotiveTouchup in 056 Natural White and it was really close.
  26. Feb 9, 2024 at 3:00 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    First fill up after gears, this tank consisted of 30 miles in 4low, about 150miles doing 50-65, and the rest in town bs…………. 11.25mpg!!!!
    I’m rather pleased, before I was getting maybe 10.5-11mpg.
    oscardog86, khooiii, bmf4069 and 9 others like this.
  27. Feb 9, 2024 at 3:41 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Don't forget to check operation of the breather valve while you're doing all that. They get gunked up. Of course if you're pulling it to check it might as well do a relocate to someplace higher. Flooding where it never used to flooding seems more likely every year.
  28. Feb 9, 2024 at 3:56 PM
    VR6T
    Yeah that got done as well
    NUDRAT[QUOTED] likes this.
  29. Feb 9, 2024 at 3:59 PM
    VR6T
    Its because I just drove through a small lake of a puddle. Kind of have to coming the back way to work. The dry way was all trafficed up with cant drivers on the road
  30. Feb 9, 2024 at 5:54 PM
    Azblue
    The Dirty T ( ^_^)_且
    But doesn't changing gears change the speedo/odo? My guess is you got 8.25 mpg. :eek2:
