  1. Feb 4, 2024 at 5:06 PM
    albru2
    albru2 Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    I installed ATS HD springs today. I got about 1.5 inches of lift from them. I now have 1" of rake, which is exactly what I was hoping for! I had a bit of a scare when I was torquing the u-bolts down for what felt like forever. I suddenly realized I was blindly following fsm spec again (98 ft lbs). After looking at ATS torque specs online they do say up to 100 for non plated and to defer to the factory spec instead of their values. Phew, when will I learn? I also had to cut them down because the nice folks at ATS decided I needed 8 3/4" bolts for some reason. Bit of a hack job but I figure if they're not re-usable then not the end of the world.
  2. Feb 4, 2024 at 5:40 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    I would have but its at my sisters house still.
  3. Feb 4, 2024 at 5:41 PM
    VR6T
    Twinsies
    Jack McCarthy, BroHon and oscardog86 like this.
  4. Feb 4, 2024 at 5:42 PM
    VR6T
    @a55hole_dachshund @shifty` fixed that reverse rake "issue". The rear shocks were blown out completely, zero rebound in them. I swear its level.
  5. Feb 4, 2024 at 6:05 PM
    albru2
    so level! you could shoot pool on that thing
  6. Feb 4, 2024 at 6:06 PM
    VR6T
    It really is just the lighting. My neighbor, first thing he said was its level now. I shouod have took a pic with the sun still up.
    FrenchToasty likes this.
  7. Feb 4, 2024 at 6:08 PM
    Wheel gap looks taller in front. But that's just the way the wheel openings are cut, I believe. It does look like it's squatting in the pic though.
    VR6T[QUOTED] likes this.
  8. Feb 4, 2024 at 6:12 PM
    VR6T
    I went into the photo settings and had it auto level the ground out. I posted the "corrected" photo, i had the camera 3 degrees high on the left hand side.
    So yes the unaided picture does look squated. Corrected picture, well is corrected lol
  9. Feb 4, 2024 at 6:18 PM
    albru2
    haha yeah that looks more level. I thought you were being sarcastic on the first one. Tape measures don't lie though, cameras do.
    455h0le_dachshund likes this.
  10. Feb 4, 2024 at 7:33 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So it is squatting still?
  11. Feb 4, 2024 at 7:35 PM
    VR6T
    No
  12. Feb 4, 2024 at 7:43 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    A big belt wieand 8-71 would hold the nose down.
  13. Feb 4, 2024 at 8:17 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I still think you should be the test mule for one of those pressure washer/sandblasting setups. You & @jpink
    Amazon.com: Rdutuok Pressure Washer Sandblasting Kit,Sand blaster for pressure washer with Replacement Nozzle Tips,Protect Glasses,1/4 Inch Quick Disconnect 5000 PSI for Abrasive Cleaning : Patio, Lawn & Garden
    bmf4069 and ToyotaDude like this.
  14. Feb 4, 2024 at 8:31 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Think more like 70 grit if you want a nicer finish but that bumper looks pretty textured so courser grit would be quicker if the gun tip and compressor will push it.
    Here's a video on comparing different types of 200 micron media.
    And here's a chart on micron to grit conversion.
    BTW, the HF gun probably has a small tip but you may be able to use to clean larger areas. Smaller tips takes a while to clean larger areas, not like this type of unit! The HF gun would likely work fine for cleaning the small rust sections you've highlighted. Blasting takes a lot of airflow so a compressor that can keep up. And suggest some type of Found blasting paint and rust works well where other tools can't really reach (like 90 degree connections) but usually only completely strip smaller objects like a battery hold down, wheel, or sections of frame. Other effective tools include this type of tool for removing paint, fitting angle grinders or with drill attachments in a variety of sizes and configurations.
    Haven't tried but looks like there are videos on multiple ways to remove powder coating including chemical stripper, heat, and blasting.
    Edit: This (but still need to pick media/grit size) ->
    FirstGenVol[QUOTED] likes this.
  15. Feb 4, 2024 at 8:35 PM
    ToyotaDude
    ToyotaDude Member
    Oh sweet. Dustless. And looks like it works based on the reviews showing frames and diffs, etc. stripped. Just got to keep the overspray out of the bucket of media, so white bucket with hole cut in bucket lid with ID matching the OD of the pickup tube.
    NUDRAT[QUOTED] likes this.
  16. Feb 4, 2024 at 8:51 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Is there any adjustability in it? Can you leave a small gap to prevent this in the future? I promise you we ain't gonna give you shit for having a small gap between the bumper and fenders. :D
    oscardog86 and 455h0le_dachshund like this.
  17. Feb 5, 2024 at 3:34 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Unfortunately no. It can't be adjusted. I'd have to cut the fenders. I don't think this caused the powder coat to fail all over though. I had people reach out on Instagram saying it looked like a terrible prep job.
    oscardog86 likes this.
  18. Feb 5, 2024 at 6:04 AM
    VR6T
  19. Feb 5, 2024 at 6:10 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    I installed those Archive Garage leafs about a month ago or so. Only went on one trip with them and didnt do much offroading but definitely felt smooth in the rear now going over bumps. Took the weight of my heavier camper shell perfectly too. Gonna go camping in a couple weeks so ill have a better idea of how they handle then. But so far, im liking them!
    NUDRAT, metalpete, Mr.bee and 2 others like this.
  20. Feb 5, 2024 at 8:44 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
  21. Feb 5, 2024 at 10:02 AM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    7inch cutoff wheel in my angle grinder, sketchy level 9 but worked like a charm. Do not enter the (death) plane of the blade...
    (Pic is not me)
  22. Feb 5, 2024 at 10:12 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm a few pages behind, but figured I'd reply before I forgot. Yall are naming cars after the Ninja Turtles. They actually made Ninja Turtle SHOs back in the 90s. One for each.
  23. Feb 5, 2024 at 10:14 AM
    VR6T
    I remember these being at the Buffalo Auto Show when I was a kid. I was like 9 ot 10 maybe
  24. Feb 5, 2024 at 10:33 AM
    VR6T
    This is why I turn my own wrenches. If I dont have to do a camber adjustment I'll do a home garage alignment. As long as the wheels are straight I have no issue repositioning the steering wheel on the splines.
  25. Feb 5, 2024 at 10:45 AM
    VR6T
    I love Project Farm. If you dont know this guy buys everything he tests and gives you real world data. He also listens to his viewers and pulls ideas from the comments section. If theres a demand for it, he'll test it. Topic today: Winches
    https://youtu.be/WxFh3MmqUos?si=r0XgDEzd_kct15Aq
  26. Feb 5, 2024 at 11:40 AM
    VR6T
  27. Feb 5, 2024 at 6:24 PM
    StockTundra
    StockTundra New Member
    2006 toyota tundra SR5
    Where can I find fender flares like those for my toyota tundra
  28. Feb 5, 2024 at 6:26 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Those are the stock fenders with the flare removed on the front.
  29. Feb 5, 2024 at 6:27 PM
    StockTundra
    Where can I find fender flares like those at for my 06 tundra
  30. Feb 5, 2024 at 6:29 PM
    StockTundra
    Thank Do you maybe know a site that sells stock flares or oem, I cannot find anything online.
