  1. Mar 31, 2019 at 7:44 AM
    #5521
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    It very well could be. I could have reacted the second I heard the crunch of my fender and thought I hit something? It was when my tire was in the air that I knew what had happened. I don't think I was on the brakes long because I was still going pretty fast haha
  2. Mar 31, 2019 at 7:53 AM
    #5522
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Pretty scary. I had an "oh shit" moment yesterday when my clutch decided to let go at 7500 rpm in second on my SHO yesterday. The feeling of helplessness as you coast to a stop sucks.
    Darkness likes this.
  3. Mar 31, 2019 at 9:08 AM
    #5523
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    That I completely understand. I used to love working on my 99 Tacoma. Had a ton of sentimental value to me. Of course you still take the cake with your attention to detail
  4. Mar 31, 2019 at 9:11 AM
    #5524
    Robadoo42
    Robadoo42 New Member
    Rob
    Hi Guys,
    I keep looking online and these dealerships I dont trust. I would like to purchase a first gen tundra 4x4 with low miles for its year, minimal rust and runs great. Upgrades are a plus. Distance doesnt matter. If you have something, please hit me up
  5. Mar 31, 2019 at 9:39 AM
    #5525
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Got them a few weeks back, Yoko GO15. My truck has that surface rust color everywhere.
  6. Mar 31, 2019 at 10:27 AM
    #5526
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I had a holy shit moment last Saturday. Car brakes completely failed at work and ran into my brand new toolbox.
    bmf4069[QUOTED] and Darkness like this.
  7. Mar 31, 2019 at 10:28 AM
    #5527
    Dpy
    Dpy New Member
    Well, the cover is not correct. The side that goes down and fastens under the plastic trim ( left side drivers seat where seat heater button is) is too short. These pics show the new cover with plastic trim in place and a pic of the old cover laid on top to compare. My measurements indicate the side piece or (curtain as I believe it is referred to) is a couple of inches too short.20190331_130226.jpg 20190331_130133.jpg
    Jerry311SD likes this.
  8. Mar 31, 2019 at 10:31 AM
    #5528
    Dpy
    Dpy New Member
    Oh and the color although a bit different really blends better with the back of seat than it does in these pics where the old top is shown.
  9. Mar 31, 2019 at 10:42 AM
    #5529
    Professional Hand Model
    Hand Protectors
    Not sure if I missed noticing the film of debris stuck on the side walls of the overflow reservoir, but today noticed some particulate resting at the bottom of the fluid that was freshly dumped and replaced on yesterday. Wondering if I stirred things up?
    Poured out the fluid and thouroughly rinsed out the reservior and filled with fresh. Pictured in yellow is sediment that is heavier than the fluid resting at the bottom. Iron, gasket, and aluminum? Science!
    May end up doing a third drain and refill sometime after putting on some miles.
    NUDRAT and Jerry311SD like this.
  10. Mar 31, 2019 at 11:03 AM
    #5530
    empty_lord
    05 rollover special
    Did you replace the pump recently, thats normal if the pump was replaced because of all the crud that falls in the cooling system when your cleaning the sealing surface.
  11. Mar 31, 2019 at 11:19 AM
    #5531
    Sunnier
    Sunny
    San Diego, CA
    Bummer. What will you do?
  12. Mar 31, 2019 at 12:53 PM
    #5532
    Hand Protectors
    Pump and belt done 50k miles ago. This radiator has about 40k miles on it. Last fluid change 10k miles (drain and refill at a shop).
    Yesterday, in order, these items were performed:
    1) Backflushed heater core, then refilled core with coolant and test drove.
    2) Returned and all systems were good.
    3) Drained 6 quarts from radiator plug. This was all that would empty. Filled 6 quarts. Emptied Reservior and filled. Test drove. All systems good.
    4) Returned and drained 6 more quarts and refilled with 6 quarts. Test drove all systems good.
    Today:
    5) Awoke this morning to check level at cap and added a hair. Looked inside reservior and saw the debris. Emptied and cleaned out and filled to ‘L’ on reservior.
    6) Just returned from a test drive of 25 miles. All systems good. No debris in reservior. Engine is still hot so I’ll wait to see how things ‘settle out’ after cooling.
    Wondering if the debris has been stuck up high on the reservior all this time and I did not notice it until putting in new? That debris is high up on the side wall of the reservior way past the Full Line.
  13. Mar 31, 2019 at 12:57 PM
    #5533
    Dpy
    Dpy New Member
    Well, I will call the place I got it from , not sure that will help because even though They had a 99% good review rating there were others with same problem and some of those were folks giving neutral reviews . I ave thought about tweaking the foam by shaving some off the under side and thus lowering the cover but that would be really wrong . I might try putting some weight om seat and pull down and see what it looks like but I think a seem might bust . Will try to call tomorrow but some others said they tried to call for various issues and didnt resolve anything
  14. Mar 31, 2019 at 2:12 PM
    #5534
    empty_lord
    05 rollover special
    Got my tilt steering done in the truck. Just need to find the trim now.
  15. Mar 31, 2019 at 5:49 PM
    #5535
    Casper421
    In the woods
    06 DC
    Ran a few wires in some loom through the frame to the bed in preparation.
    Put in the longer rear braided brake line.
    After bleeding the whole system, including the lspv, twice, I’m starting to think I have an issue with the mc. Going to bleed it again after work tomorrow.
    Brown Bear likes this.
  16. Mar 31, 2019 at 6:13 PM
    #5536
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Alrighty, makes sense. I planed on refinishing the front sway bar since mine has a lot of paint flaking off.
    I think I’m going to go with the beefier TRW end links. Haven’t decided on bushings yet. For rubber options it seems like Moog is the main choice, but if their quality is down then not sure. Poly is tempting, but I don’t want squeaking or something too stiff. I’ll figure it out and report back.
    Thanks for the input, it helps!
  17. Mar 31, 2019 at 6:16 PM
    #5537
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
  18. Mar 31, 2019 at 9:24 PM
    #5538
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Out having fun in the snow with the ol' beauty
  19. Apr 1, 2019 at 5:29 AM
    #5539
    Hand Protectors
    Wow. My hand would freeze off in that weather!
  20. Apr 1, 2019 at 7:50 AM
    #5540
    NMTundra
    NMTundra New Member
    94F995ED-0F8B-4A6C-9F9E-85FAB33ED44C.jpg AB179D0B-6A07-4376-A532-F964CF5A0FCD.jpg
    Replaced the interior lights with SuperBrightLeds, definitely a huge difference and makes the truck feel more modern (not to mention useable) for sure.
  21. Apr 1, 2019 at 8:02 AM
    #5541
    Hand Protectors
    Cowl clips and rear brake shield plugs are in.
    Darkness, NUDRAT and 00TundraZ like this.
  22. Apr 1, 2019 at 8:27 AM
    #5542
    Sunnier
    Sunny
    San Diego, CA
    Looks good! What seat covers are those?
  23. Apr 1, 2019 at 9:29 AM
    #5543
    NMTundra
    NMTundra New Member
    The driver's seat just has a cheap foam cushion I found on Amazon. My seat bottom foam has broken down near the door and the leaning kills me on long drives. I tried to find a more elegant solution like padded seat covers but didn't have much luck.
    Sunnier[QUOTED] likes this.
  24. Apr 1, 2019 at 9:38 AM
    #5544
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Replaced the drive shaft carrier bearing this weekend. I was hoping it would fix my shuddering, but no such luck. My u joints are in good shap as well. :annoyed:
  25. Apr 1, 2019 at 12:05 PM
    #5545
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Ordered the Wheeler's Offroad Anti-Sway kit to replace my bushings on my sway bar and end links. Have new Moog end links coming. Amazon had them for under $24 each and I have prime so free shipping. I'll put the wheeler's poly bushings on the Moog end links and see how it does! the wheeler's kit includes new bump stops as well. I'll throw those on too. I was intrigued by that honestly. I liked how it was a very comprehensive bushing kit, honestly my main reason for purchase.
    I'll report back once installed!
    Tonight I'm scraping down and repainting the front sway bar. It's rusty and crusty! :goingcrazy:
  26. Apr 1, 2019 at 12:38 PM
    #5546
    empty_lord
    05 rollover special
    Got me a new control arm for the tundra.
    [​IMG]Courtesy If a rusty old frame
    Going to try and get the other side loose, replace all the bushings after I sand blast and paint them
  27. Apr 1, 2019 at 12:41 PM
    #5547
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    First thing I saw was the chunk of old frame you cut out. My eyes were huge, I thought, "Oh my gosh, what is this guy doing!?". Definitely gave me a good laugh!
    Great idea, use that donor stuff and make your life easier!
    Darkness, NUDRAT and Sunnier like this.
  28. Apr 1, 2019 at 1:52 PM
    #5548
    Hand Protectors
    Coolant reservior looks very clean with no debris. I found some pics from a few weeks ago when painting the battery hold down brace that show the reservior had that splotch build up. My thoughts are that the debris stayed in the reservoir.
    I’ll check the engine later once it cools off. Need to post up those pics of the stainless clamps on the power steering reservior, too.
    Filled up today. 11 mpg. Lots of idle time and city short trips.
  29. Apr 1, 2019 at 3:05 PM
    #5549
    Hand Protectors
    Stopping your reservior leaks.
    TX-TRD1stGEN and NUDRAT like this.
  30. Apr 1, 2019 at 3:07 PM
    #5550
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Decided to pull the cab visor off to see if that would help my MPGs. I’m not liking that I found...
    Acatlin96 likes this.
