  1. Jan 31, 2024 at 7:26 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was planning to just find the guys house and steal the gas door. Thanks for the heads up.
  2. Jan 31, 2024 at 7:37 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    The clocking of LCA bushings sounds a bit strange. I wasn't even aware there was a specific orientation to them as they look the same no matter how it's rotated in the LCA. The only common sense thing is to torque them when the truck is sitting on the ground with its tires.
    BroHon, RUSTYNUTS and des2mtn like this.
  3. Jan 31, 2024 at 7:54 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Nice catch. I totally missed that it didn't have the lock.
  4. Jan 31, 2024 at 8:09 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Anyone just swap the shoes and leave the original drums on? And if not terribly scored is it better to not turn them to keep thickness or turning them works out well and they don't tend to warp because they don't see as much action as the fronts even when properly adjusted? TIA
    oscardog86 likes this.
  5. Jan 31, 2024 at 8:12 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    There's a guy on here who riveted the non locking door to the locking door internals. IMO it looked like ass, put it's been done.
  6. Jan 31, 2024 at 8:32 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'd at least get them turned. Don't put new shoes/pads on old drums/rotors.
  7. Jan 31, 2024 at 8:33 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    Learn something new everyday. Reading this thread I had no idea the truck needed to be on the ground when torqueing the lower control arms in. On past vehicles I've had to replace the arms and always did it with the wheel off. I currently have the lower arms off on my Tundra. Will make sure to torque them in with the truck on the ground. Thanks!
  8. Jan 31, 2024 at 8:45 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Ok, adjusting my alignment, and my rack bushings have less than 1/8" of wiggle. But there is a bit of movement. Is that normal, or should it be clamped tight?
  9. Jan 31, 2024 at 8:47 AM
    Mine have about that much wiggle it seems after repair. I'm not sure if it's normal, I blew out the big circle one on the passenger side and had to replace it.
  10. Jan 31, 2024 at 9:20 AM
    Jack McCarthy
    Bill
    North of Boston
    They tend to warp when the e-brake/parking brake seizes due to non-use and reusing it for the first time after a year or so. Those bell cranks love to seize up after putting the e-brake on and need to be pulled apart every few years and greased or replaced if you live where it snows. (I’m guessing it doesn’t happen as much in the warmer climates)
  11. Jan 31, 2024 at 9:22 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I knew to torque at ride height and understand why. And it totally makes sense to clock for progressives, was just unaware of it. If I woulda done poly bushings as originally planned it wouldn't have mattered, and if problems arise (and haven't LT'd yet) I'll go poly
    yeah, no, there are actually tab markers on each bushing that indicates orientation, and to complicate things, the two bushings are not to be clocked the same. One goes horizontal and one vertical (with the marking tabs). Also good to know that they're not the same parts, front lower forward bushing and front lower rearward
  12. Jan 31, 2024 at 9:27 AM
    Jack McCarthy
    Bill
    North of Boston
    The front and back lower control arm bushing difference is obvious but the ‘tab’ orientation is new to me. I’ve never heard it discussed before but I’ve never had to press in new bushings to worry about it.
    RUSTYNUTS[QUOTED] likes this.
  13. Jan 31, 2024 at 9:36 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Nor have I. I propose Jan 31st to be 'clocked bushing awareness day'. :hattip:
    NUDRAT, BroHon, des2mtn and 3 others like this.
  14. Jan 31, 2024 at 9:38 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Put a jack under the arm and load that corner, if you want to tighten with the wheel off.
    Poly or rubber? Does the steering wheel play feel normal when driving?
    It'll have some play as isn't solid mounted.
  15. Jan 31, 2024 at 10:14 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    they're the OE rubbers, & has always felt normal. I knew it was there, and wasnt worried about it, but now that im thinking about the alignment, i thought i should ask.
  16. Jan 31, 2024 at 10:35 AM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    Swapped in the new and working LED TBL. Things got a bit crispy
    It was going real smooth like, and then the plastics exploded
    Voss, artsr2002, NUDRAT and 7 others like this.
  17. Jan 31, 2024 at 10:38 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Save the HMSL lens. Someone may want / need it
    artsr2002 and RUSTYNUTS like this.
  18. Jan 31, 2024 at 10:38 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Dang atleast your’s didn’t have 3 holes above the bulbs. Mine did. It actually still does. YOLO
    VR6T likes this.
  19. Jan 31, 2024 at 10:45 AM
    You running Halides in that thing? Maximum Carnage! New light looks sweet, Amazon special?
    VR6T[QUOTED] likes this.
  20. Jan 31, 2024 at 10:53 AM
    VR6T
    Oh it's cracked, but I can set it aside if someone wants it, some assembly required.
  21. Jan 31, 2024 at 10:54 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    It looked clean in the pic. Just a thought. I take shifty's approach, never throw away good OEM parts.
    BroHon, RUSTYNUTS and VR6T[QUOTED] like this.
  22. Jan 31, 2024 at 11:02 AM
    ToyotaDude
    ToyotaDude Member
    My problem is the opposite where they fall out of adjustment even with backing up stops and parking brake use and need manual adjustments. Still on original shoes after 270k miles with 3 mm at lowest measurement.
  23. Jan 31, 2024 at 11:09 AM
    VR6T
    Sure, its been like that for god knows how long, way way before i bought it. The passenger side cargo/ reverse light used to work, also the only one that didnt have a hole burned into it. Noticed it wasnt working about 2 weeks ago, forgot about it, remembered bought this
    NSLUMO Led Third Brake Light... https://www.amazon.com/dp/B09DKP4GLW?ref=ppx_pop_mob_ap_share
    Buy weather striping 3M tape
  24. Jan 31, 2024 at 11:37 AM
    VR6T
    Upon further inspection the crack is just a pretty deep scratch. And could be reused. @TheBlackMomba @shifty` would be proud I salvaged an OEM part.
    Also if anyone wants/ needs this the wiring harness would come with 45 shipped
  25. Jan 31, 2024 at 11:40 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I like those 15” aluminum wheels…
  26. Jan 31, 2024 at 11:41 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You would :boink:
    artsr2002 and VR6T like this.
  27. Jan 31, 2024 at 11:42 AM
    VR6T
    Hey hey hey be nice to the special needs and visually impaird kids
    Tundra2 likes this.
  28. Jan 31, 2024 at 11:43 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If you only knew how many Toyotas are in his fleet...
  29. Jan 31, 2024 at 11:44 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    @empty_lord has a lot of kids that need wheels
  30. Jan 31, 2024 at 11:45 AM
    VR6T
    Hey just cuz his vision sucks doesnt mean he cant be loaded with yodas.
