  1. Jan 29, 2024 at 3:52 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    yea, but i had to grab the top of the shaft with some pliers to keep it from spinning. Ratcheting wrenches were a game changer.
    yours were much more difficult to get on. That link shifty posted reminded me we might have ground on the bushings to get em to fit, while haveing to force the shaft up against the bottom bushing.
  2. Jan 29, 2024 at 4:45 PM
    Azblue
    The Dirty T ( ^_^)_且
    artsr2002, RUSTYNUTS, bmf4069 and 4 others like this.
  3. Jan 29, 2024 at 4:57 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    artsr2002, bmf4069, BroHon and 3 others like this.
  4. Jan 29, 2024 at 5:29 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Wait, what does this mean? Should I have done this with the TT shocks when I installed the HD springs?
  5. Jan 29, 2024 at 5:53 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I'd think the shock want to clamp where they clamp. I wasnt able to compress em, but at full length they were about 1/2" longer than the stockers. The pic with the back of my truck jacked all the way up was over an inch too tall for the 5100's.
  6. Jan 29, 2024 at 6:44 PM
    shifty` Inside his chest they found ten thousand pencils
    Check your bushings on top of the shock. When I lifted the rear mine were freaking squished to hell.
  7. Jan 29, 2024 at 6:51 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Think i just found your clunk.
    J/k probably.
  8. Jan 29, 2024 at 6:55 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I'm letting mine come out naturally, I figure I'm about half way there. :rofl:
    Maybe this summer I will get to it. With those Heavy Duty leafs I doubt if I will even notice the difference though. I mean I put 1200-1300lb in the back and it barely squatted!
  9. Jan 29, 2024 at 7:07 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yeah, here it is, i took a pic. treated 3/4 plywood and wet treated lumber, so prob more than the listed weight. Maybe I'm off on the weight...
    oscardog86 likes this.
  10. Jan 29, 2024 at 7:17 PM
    Nah, I readjusted everything within days of lifting, once it hit home that I spaced on dealing with that.
    Yeah, with HD springs out back and 700lb springs in front, ain’t nothing much moving on this truck. It’s pretty stiff. I measured before and after sticking 320lb of UPS batteries in the bed and it moved maybe 1/16”. And I have the cap on it which adds another 150# or so. The ATS HD springs are no joke.
    oscardog86 and FishNinja like this.
  11. Jan 29, 2024 at 9:08 PM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
  12. Jan 29, 2024 at 9:38 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Inner tie rods are new'ish. What the hell are CV's?
    my trucks a 2wd. it's not nice to make fun of the handicapped. Jesus is watching you.
    You mean you didn't order your underlighting at the same time? Wouldn't need daylight if your chassis was lit. :rofl:
    There's a monthly Toyota meetup here put on by OCYOTA, and they bring a flex ramp for anyone to try out, and talk you thru it for safety of course. I'll grab a pic....
    NOT MY PIC
  13. Jan 29, 2024 at 9:42 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Get some speed built up & that'd probably be a good time.
    NUDRAT likes this.
  14. Jan 29, 2024 at 10:11 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Black Widows.
    455h0le_dachshund and bmf4069 like this.
  15. Jan 29, 2024 at 10:58 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Are you considering the semi-met originals or ceramics (AZ200s).
    1st Gen Tundra - Advic Pads (rear).jpg 1st Gen Tundra - Advic Pads (front).jpg
    I haven't tried them but looks like Advics sells ceramics with shims as
    the AD0976 Brake Pad
    https://www.rockauto.com/en/parts/advics,AD0976,brake+pad,1684
    https://www.amazon.com/Advics-AD0976-Front-Brake-Pad/dp/B0081WW6FQ
    shifty`[QUOTED] likes this.
  16. Jan 29, 2024 at 11:10 PM
    artsr2002
    'Yonder
    If the strobe can be defeated, I may try it out myself after you post a follow-up for us of course. :D Them strobes are annoying AF.
    VR6T[QUOTED] and The Black Mamba like this.
  17. Jan 30, 2024 at 2:17 AM
    artsr2002
    'Yonder
    Updated RockAuto Discount Code valid until March 1st 2024!
    Code: 257228430229800630
  18. Jan 30, 2024 at 3:50 AM
    Be careful of cabin leaks. You may want to buy a new HSML to cab seal on scAmazon.
  19. Jan 30, 2024 at 5:43 AM
    metalpete
    ID
    lol my bad... I forgot that you are 2wd.
  20. Jan 30, 2024 at 5:47 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Rust holds truck together?
    RUSTYNUTS, BroHon[QUOTED] and VR6T like this.
  21. Jan 30, 2024 at 6:20 AM
    This looks like the "Lower ball joint stress tester"
  22. Jan 30, 2024 at 6:38 AM
    VR6T
    And just like that i magicly need new pad, rotors, shoes and drums
  23. Jan 30, 2024 at 6:46 AM
    VR6T
    I have one of those on order already. Didnt like the way the current one looked
  24. Jan 30, 2024 at 6:46 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Not sure about the truck holding together, but sort of, because fasteners are almost impossible to remove :mad::rofl:
  25. Jan 30, 2024 at 7:05 AM
    FishNinja
    Lee
    06DC2wd
    mad annoying as they are. They catch the attention of other drivers so it’s kind of a safety feature.
    I personally dislike getting it in the rear
    artsr2002[QUOTED], BroHon and bmf4069 like this.
  26. Jan 30, 2024 at 7:17 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
  27. Jan 30, 2024 at 7:25 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Powerstop seems to be OK. I know a lot of people have problems with out of round drums when they're not OEM.
  28. Jan 30, 2024 at 7:26 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Although it's not something I've tried, I am with ya 1000% on this.
    artsr2002, shifty`, BroHon and 4 others like this.
  29. Jan 30, 2024 at 7:28 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Is your truck still running WE calipers, or was it upgraded to WL? Now would be the time to buy WL calipers with the pads and rotors
    bmf4069 and oscardog86 like this.
  30. Jan 30, 2024 at 7:43 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    way to be discreet about it.......dick
    As a carpenter, I see it like a piece of fascia thats been completely hollowed out out by termites, but still appears to be well in form and function due to multiple layers of latex paint over the years. Basically an empty shell. Not sure how that's relevant, but that's what comes to mind. Maybe you just need a paintjob @BroHon?:boink::rofl:
    Voss, BroHon[QUOTED], bmf4069 and 3 others like this.
