  1. Jan 27, 2024 at 9:38 AM
    B888s
    B888s New Member
    Brandon
    Bakersfield, CA
    2000 TRD Off-Road SR5 4x4 Access Cab
    Original owner!
    I already swapped the best tire onto the spare steel wheel. I have three with tires and one bare. I even have a newer set of center caps. I guess they will just sit until I can find someone to take them or they end up going to the scrap yard.
  2. Jan 27, 2024 at 9:48 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Gracias! I know what you mean, I did everything I could to NOT buy black wheels. Felt it was too easy, but the wheels I really wanted (black rhino shredder) were never in stock and only came in 17".
    But I couldn't be happier for what I "settled" with. Just gotta take the mud flaps off :thumbsup:
    oscardog86 and FrenchToasty like this.
  3. Jan 27, 2024 at 10:29 AM
    What's your suspension story here, what's up with the reverse rake action?
    Progress is good! Looks great! Bet you wish you'd have done this 100k miles ago :rofl:
    How heavy are those wheels? It's the only beef I've ever had w/KMC, they tend to run heavy IME, but I haven't bought any of theirs since the last set of chrome 5-spokes I had bitd.
    Here's a little progress panel of pics from your 2nd or 3rd post on Tundras.com (original lift), new lift w/OEM wheels, and new lift w/KMCs. Great work. Now fix those fucking window trims and do something about that fuel door! :bananadance::crapstorm:
  4. Jan 27, 2024 at 10:48 AM
    metalpete
    ID
    Mr. Encyclopedia Britannica over here! @shifty`
    Thanks man, means a lot. Lol, those window trims are nasty, but if you keep your truck looking just shitty enough, no one will break in... but seriously I need new ones.
    I'm starting to like the black, gas door! :lalala:
    Oh I forgot to say, the wheels aren't too heavy, just under 23 lbs each. With the new tires, probably a 25-30 lb increase per tire.
  5. Jan 27, 2024 at 10:49 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    this is rad. How’s the overall fitment? I’m debating going the same route with 285/75r17 in some gladiator a/t’s. They’re like $60 cheaper for the set vs 285/70r17 same tire.
  6. Jan 27, 2024 at 10:54 AM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    It not that bad honestly. The parking lot is jacked up there. However remember when I shitty lift kit "DIYd" by owner 5...... Yeah. In reality on a leveled surface it is only 3/4 of an inch difference. It's been measured with a Bosh laser level lol. The rear shocks need done as well. So I'm sure that's a contributing factor as well
    shifty`[QUOTED] likes this.
  7. Jan 27, 2024 at 10:56 AM
    metalpete
    ID
    Thanks! Pretty good, gonna take off the mud flaps, bit of rubbing there. But a 17" might have even more rub. Still need to get an alignment, so I haven't gone full lock to lock yet.
  8. Jan 27, 2024 at 10:58 AM
    FishNinja
    Lee
    06DC2wd
    Threw on the Nilights. Originally wired them via the OG fog wiring but forgot that lo-beams have to be on in order for them to get power. So I scratched that and wired them in separate w/ a switch. And I peeled the putter ring of plasti-dip off the grill. Doesn’t look bad. But I did it since I’ll be getting a light bar later on and I’ll wind up painting a portion of the hood flat black. I think the paint-matched outter ring should help add good contrast when that happens.
    Also got this last weekend. I messed w/ arc welding when I was in my early twenties. Not good but figured I’d give it a go since I’m not some shithead anymore. Gonna build front pre-runner style bumper, sliders, and make a high clearance rear end.
    also order my suspension via Hotshot Off-road. So here’s lunch and dinner.
    Voss, oscardog86, shifty` and 3 others like this.
  9. Jan 27, 2024 at 11:07 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Did you photochop the fuel door out of the first pic?
    FirstGenVol and metalpete like this.
  10. Jan 27, 2024 at 11:11 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Another Texan I see. Wanna join the crüe?
    VR6T likes this.
  11. Jan 27, 2024 at 11:23 AM
    FishNinja
    Lee
    06DC2wd
    What is this krue you speak of?
  12. Jan 27, 2024 at 11:35 AM
    Note the Tundra badge in that photo, and you'll know what I did.
    NUDRAT and metalpete like this.
  13. Jan 27, 2024 at 11:37 AM
    Before you do that, talk to some of the dudes running 33s @ 285/70r17. I'd wrather spend the extra $240 on tires than beat and cut the snot outta my truck to tuck rubber.
  14. Jan 27, 2024 at 11:43 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    He's a witch!
    VR6T likes this.
  15. Jan 27, 2024 at 11:44 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It's pretty exclusive.
    VR6T likes this.
  16. Jan 27, 2024 at 11:45 AM
    I see what you did. You found a stock photo of a RHD Tundra that looks just like his! Genius
  17. Jan 27, 2024 at 11:47 AM
    metalpete
    ID
    I agree with shifty @FishNinja
    Part of the reason I stuck with 16" wheels. I'm technically just a gnats ass under 33", but that same tire on a 17" would have put me closer to a 34". Granted, I haven't wheeled with this set up yet and I'm sure I'll find out real quick where it needs adjusting.
    oscardog86 likes this.
  18. Jan 27, 2024 at 11:49 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Don't listen to em @FishNinja bigger tires are the way of our people.
    If I had bought 17's in the first place I'd have gone with the taller, skinnier 285/75r17.
    But I ended up with 16's so I went with the tall n fat 295/75r16 instead.
    oscardog86, metalpete and FishNinja like this.
  19. Jan 27, 2024 at 11:52 AM
    FishNinja
    Lee
    06DC2wd
    Oh im pretty set on the 285/75’s. She doesn’t go off the beaten path enough to warrant worry about major rub/damage. I’m basically building a truck to haul my kayaks back forth from mi casa to the coast and work out of.
  20. Jan 27, 2024 at 11:53 AM
    FishNinja
    Lee
    06DC2wd
    Let me know the deets via pm lol
  21. Jan 27, 2024 at 11:54 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    We'll get ya out to some off-roady stuff soon enough. :thumbsup:
    What part of TX are you in?
    Jamboree is in May
  22. Jan 27, 2024 at 11:58 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Patience grasshopper.
    batman900 likes this.
  23. Jan 27, 2024 at 12:02 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Are OEM replacement the only way to go or is there a good/cheaper after market?
  24. Jan 27, 2024 at 12:10 PM
    Cool, I got 275/70r17 and I rub pretty regularly with mostly in-town driving and the occasional mountain trail/lake trail. With more than 2" lift front and rear. That's 32.2". 285/70r17 is 32.7", step up to 285/75r17 and you're at 33.8, not only are you going to be eating gas and accelerating like a pile of dogshit, you're going to need to be cutting shit, even with street driving. If I'm rubbing at 32.2" of tire on a 17 and 2" lift, which is only 1.6" above stock diameter, you're talking about going 1.6" diameter beyond where I'm running.
    That's pretty nuts, but not necessarily in a good way?
    oscardog86 and metalpete like this.
  25. Jan 27, 2024 at 12:10 PM
    Aftermarket option is available. It's been posted about on here quite a few times. I'm too lazy to look it up.
  26. Jan 27, 2024 at 12:11 PM
    And even what assdog is talking about on 16s is only 33.4"
  27. Jan 27, 2024 at 12:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You just need to properly adust your SPC caster. Maybe your coilovers preload too.
    Honestly one or the other would likely solve your rub. Both definitely would.
    FirstGenVol likes this.
  28. Jan 27, 2024 at 12:19 PM
    Disagree wholeheartedly. Caster isn't going to stop tire eating into the top of the fender wells, which I do, any time I'm turning and compressing at the same time.
  29. Jan 27, 2024 at 12:19 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yes, 33.4" x11.6" vs 33.8"x11.2"
    So pretty comparable when talking about rub factors.
    We're talking 1/5" when you think about it
  30. Jan 27, 2024 at 12:22 PM
    metalpete
    ID
    Oem probably last longer, but more $$. As it do, ya know? I've only tried to search for them a couple times, without much luck either way.
