  1. Jan 26, 2024 at 11:40 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I pulled the brakes so i could seperate the balljoints on a vice. Worked so well last time.
    Voss, bmf4069, oscardog86 and 4 others like this.
  2. Jan 26, 2024 at 11:50 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    I see we share the same method of organization... all over the f*ckin place. Ya, pulling the whole knuckle out is so much easier to pull/press the ball joint.
    40mm is the size for my axle nuts. I ordered OEM once and they showed up the same size as the 3rd party that was on my truck; always thought it was supposed to be 35mm? Also, I never had the spider nut and haven't put one on since. Maybe I should do that.
    bmf4069 and oscardog86 like this.
  3. Jan 26, 2024 at 11:56 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Gimme time, i'll get it spread out.
    If i can, i havent really started yet, and my supervisors a hardass.
    Voss, bmf4069, abcinv and 6 others like this.
  4. Jan 26, 2024 at 11:56 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Do you only want to be able to run those lights as fog lights or would you want them on with hi-beams too? If they're aimed high enough you may tie them in with your hi-beams using a relay harness.
    oscardog86[QUOTED] likes this.
  5. Jan 26, 2024 at 12:12 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    YES. I did it
  6. Jan 26, 2024 at 12:13 PM
    metalpete
    ID
    Looks like he's got a bone to pick with you already.
  7. Jan 26, 2024 at 12:14 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Judging by this face. You definitely left a 10mm somewhere it shouldn’t be
  8. Jan 26, 2024 at 12:16 PM
    metalpete
    ID
    Or a 14mm. Those suckers always go rogue.
    455h0le_dachshund likes this.
  9. Jan 26, 2024 at 12:17 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    He's just mad that its past lunch time, and i dont share my beers.
  10. Jan 26, 2024 at 12:17 PM
    FishNinja
    Lee
    06DC2wd
    That reminds me. I need some. I have 1, short, 6 sided left.
    Edit: I can’t go tool shopping. I’m about to drop a decent penny on my suspension. Soooo spam and ramen it is for the week
  11. Jan 26, 2024 at 12:26 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    That's gotten expensive too
    FishNinja[QUOTED] likes this.
  12. Jan 26, 2024 at 12:33 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I cant believe how expensive corned beef has gotten. I can still get cheap steaks & bacon, but the storebought stuff is crazy.
  13. Jan 26, 2024 at 12:42 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    i've done it both ways.
    the round lights are on the factory fog circuit, but my truck came with it, so i didnt have to try to source a switch. They're spread enough and bright enough to work when i need em, and i've always got a finger on the stalk to shut em down. The square lights are hardwired through a relay, and are silly bright. I really only use those for distance or to punish some one in the slow lane. Driver side is aimed at most folks driver mirror, pass side it aimed at truckers mirrors.
    That switch is easy to find, too & the light is easily hidden behind a steering wheel spoke.
    on the titan i had enough room to make the switch location even better.
  14. Jan 26, 2024 at 12:49 PM
    FishNinja
    Lee
    06DC2wd
    just to confirm. The nilights I got; I can solder to the original fog plugs and it should work fine? (Or I’ll be making some connectors to slip over)
    I just wanna make sure my nilights don’t mess with some sort of circuitry. I am by no means an electrician or electronics expert
    oscardog86 likes this.
  15. Jan 26, 2024 at 1:02 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    yes
  16. Jan 26, 2024 at 1:03 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I'd say run the whites seperate, and the ambers on the factory circuit.
  17. Jan 26, 2024 at 1:05 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Dude, i made corned beef and cabbage for the first time last week in the slow cooker. $25 for less than 4lbs! Not sure what it normally cost but that seemed high!
    bmf4069 and FishNinja like this.
  18. Jan 26, 2024 at 1:08 PM
    oscardog86
    Southern California
    Id probably only want them as fog lights. Not sure to be honest. Never really used them as obviously I havent had any installed, but id like to have them for offroading at night and finding campsites. Is there a way to just have them switch on with the switch independently of the hi beams?
    Basically Im just curious if my dummy switch will have the proper connector already installed from the factory?
    And if i got the right relay to put in the fog light position in the fuse box?
    Also any tips on what I need to remove to get the dummy switch out and the real switch installed would be helpful as well!
  19. Jan 26, 2024 at 1:10 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  20. Jan 26, 2024 at 1:12 PM
    oscardog86
    Southern California
    So I have the denso relay that i believe plugs into a slot in the fuse box for "fog" lights. Do i also need a fuse too? As you can see i have minimal electrical knowledge!
  21. Jan 26, 2024 at 1:20 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    My response is in your quote.
  22. Jan 26, 2024 at 1:24 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Me too, its magic, but i bought lights with everything included. I dont know if my relay NEEDS to be grounded by the bracket, but i made sure it is.
    i have a nilight lightbar i havent installed yet, because i'm waiting for someone to explain how to make it strobe. But it has amber mode, and i miss that most, my jeep had amber mode, on a seperate switch, but i could ise it as a warning. Like as soon as i saw an oncomer, i could turn on the ambers, bit after a 5 count i'm damaging retinas.
    These, and the rest of my lights, are traveller from tractor supple have an amber halo around a weak led & wanna wire em for reverse and blinkers, but havent figured out if it'll work, and really dont wanna drill my cap.
    just saying, i know the difference between the red & black wires, but not much beyond that.
    Voss and oscardog86 like this.
  23. Jan 26, 2024 at 2:23 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Pro tip #2 take your one way ratchet wrench off before you get stuck.
  24. Jan 26, 2024 at 2:27 PM
    FishNinja
    Lee
    06DC2wd
    licking it helps
  25. Jan 26, 2024 at 2:30 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    wait until i find a sanitizer station. I've earned my punishment.
  26. Jan 26, 2024 at 4:01 PM
    Squeeze a lemon on it to disinfect.
  27. Jan 26, 2024 at 5:13 PM
    metalpete
    ID
    I'm gonna post this in the buy/sell/trade, but figured I'd give yall a heads up.
    Leafs got some life in em still.
    oscardog86 and Jack McCarthy like this.
  28. Jan 26, 2024 at 5:22 PM
    If you need shipping tips, gimme a holler. Ask @w666 what shipping cost on something like that runs. I think they were 52lb each.
  29. Jan 26, 2024 at 5:44 PM
    metalpete
    ID
    Appreciate it! I do quite a bit of shipping at work and can get a good rate for whoever buys em. I'm only asking to pay the freight anyway.
    shifty`[QUOTED] likes this.
  30. Jan 26, 2024 at 5:58 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    Lookout Mtn Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    Shiner Blonde is my go-to when I can find it!
