  1. Jan 22, 2024 at 2:25 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Mine has had a plastic bed liner since we bought it. Dread pulling it and seeing what the paint underneath looks like. My Ferd came with a spray in liner and I threw a horse stall mat in the bed. Its grippy, covers the majority of the bed, nice and heavy, 3/4 inch thick and was 45 bucks. If I remove my DCs plastic liner, I'll probably just throw one of those in the bed.
    HBTundra likes this.
  2. Jan 22, 2024 at 2:42 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I think the MH panel would be a hair short for a DC tailgate.
    Did you consider the easy lift torsion bar for your tailgate? I can't recall if you got one or not.
    oscardog86 and dirtnsmores like this.
  3. Jan 22, 2024 at 2:49 AM
    daveeasa
    David
    Have one. Haven’t installed it yet. It’s the slam-on-open i got tired of.
    I mean, I am pretty fit so lifting it isn’t the concern at all. Also hands are typically free when closing vs full when opening.
    Also crap gets stuck in it, mostly yard waste. I need a trailer at some point. So much green invasive species growth in the back half of the lot.
    I’ll do the torsion bar at some point but this MH panel is dead to me. I may try to cut it into a half piece and replace the OEM panel. But I’d really prefer something thinner.
    I need to install my bushings too, hopefully I haven’t lost them. And weatherstripping for the shell door and windoor.
    running Ethernet cable and doing direct led tube swap on fluorescents is first priority.
    oscardog86 likes this.
  4. Jan 22, 2024 at 4:49 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I still need to install my torsion bar. I've also got the mountain hatch thingy. It is significantly heavier with it on the tail gate.
  5. Jan 22, 2024 at 4:51 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'd ditch mine for an aluminum plate tail gate cover any day. But I've never seen one for our trucks. They used to be a popular truck accessory around here when I was a kid. But mostly saw em on domestic trucks. Like this would be the tits:
    https://www.carid.com/dee-zee/brite...hCNetC3wfOjhwC9VTsIaAlwiEALw_wcB&gclsrc=aw.ds
  6. Jan 22, 2024 at 5:05 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  7. Jan 22, 2024 at 5:19 AM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Guys... For a quick temporary solution I've thought about replacing just that portion of the tailgate that you remove to access the handle with something completely flat and softer like the cutting board material and some sticky back carpet possibly. That would provide plenty of flat surface for knees to climb up and beers to sit on. @HBTundra
  8. Jan 22, 2024 at 5:21 AM
    dirtnsmores
    Southern CA
    That torsen bar makes it significantly easier to drop as well. Pretty much guide it down with a finger and have the other arm free. I usually just drop it and catch it towards the bottom with one hand now. I should've showed you in person
    oscardog86 and 455h0le_dachshund like this.
  9. Jan 22, 2024 at 5:23 AM
    daveeasa
    David
    Yes, this is what I told MH but they gave me the finger. Their approach is heavier and dumb.
  10. Jan 22, 2024 at 5:35 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Go Navy! Minus the lost eye sight lol
    bmf4069 and VR6T[QUOTED] like this.
  11. Jan 22, 2024 at 5:38 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
  12. Jan 22, 2024 at 5:45 AM
    daveeasa
    David
    He only does thirds and only dropoff now.
  13. Jan 22, 2024 at 6:00 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Gotcha, it's a lot of work getting those rear ends off, plus seals and bearings that go with the axle shafts that can only be pressed in.
  14. Jan 22, 2024 at 6:11 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Ask your Ophthalmologist whether he thinks your time in the Navy as a welder could have caused or aggravated your eye condition. If yes ask him to provide you a “Nexus Letter” summarizing your condition and stating he believes “more likely than not your condition was caused or aggravated by your military service and therefore should be considered service connected for disability purposes.” The file a new claim at VA.gov.
  15. Jan 22, 2024 at 6:15 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yea I'm still active, 23 years and counting. I'm pretty close to 100%VA, so I think lol. But I've never been around welding other than my few shop welders in my wrenching business. But I do have black floaters which Navy Optomology said is complete normal, SMH! but at least it's documented.
    bmf4069 and VR6T like this.
  16. Jan 22, 2024 at 6:30 AM
    VR6T
    VR6T In fealty to the God-Emperor I serve the Imperium
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    OEM+, 6+1 bastard pack, 4.08 swapped rear end, custom spring shackles, 3 inch flat lift. This list will grow
    And lost hearing, and lost mobility, and.... Lol. At least I wasnt in the Air Force so I got that going for me I guess. Lol.
    bmf4069 and TX-TRD1stGEN like this.
  17. Jan 22, 2024 at 6:40 AM
    shifty` Dead heads and frog legs. Mmm... cake mix!
    daveeasa[QUOTED] likes this.
  18. Jan 22, 2024 at 6:42 AM
    VR6T
    My med record is thicker than a 90s Yellow and White pages combined, I was "so bad off" they just had to med board me out, but only at mear 30% Navy side and only 70% VA..... To quote Bubbles, "something seems; fucky", like oh you don't need a pension... Oh 2 admirals request to keep you by name and should have ceased the med board then and there, yeah those rules dont apply today.... Oh a retired MCPON and a current Fleet Force Master Chief wrote in on your behalf, lol, nope, oh you have litteraly 23 more letters of keep and character.... See ya later HT1. FTN and FTG bro.
    bmf4069 likes this.
  19. Jan 22, 2024 at 6:59 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Dang yea it's sad, us Old sea Dogs get fucked. I've seen new kids now a days, perfect Fn fine! Get Med separated but they call it "Retired" I'm LIKE GTFO! HERE! They got 100% DOD rating and 100% VA! SMDH! I'm on a rant now! Lol. Any who. I'm deciding what's next on my rig: SCS wheels or fully built 3rd. Or VIP box tickets to Silvestone this year, haha! That's like 5K plus hotel and rental.
    VR6T[QUOTED] likes this.
  20. Jan 22, 2024 at 7:04 AM
    VR6T
    Thats my exGF, she got medded out of the Corps not a fucking thing wrong with here 100/ 100% both side, "MH" claim. Aside form some OCD nothing out the norm... Never deployed or left the state's..... Like wtf?
  21. Jan 22, 2024 at 7:05 AM
    daveeasa
    David
    455h0le_dachshund likes this.
  22. Jan 22, 2024 at 7:21 AM
    How does it even attach? Drilling required?
  23. Jan 22, 2024 at 7:51 AM
    daveeasa
    David
    Factory fastener locations with longer lag screws.
    it’s an extra layer on top of the already heavy tailgate and Oem access door.
    add my bed liner as well and it’s just excessive. One quarter the weight by half as thick and replacing the Oem panel (which is super light but bends) would be perfect. Except for perhaps excessively large asses but then those asses should go to the gym.
  24. Jan 22, 2024 at 8:04 AM
    Any thinner and I'd be worried about warpage.
  25. Jan 22, 2024 at 8:19 AM
    daveeasa
    David
    Could be thicker on the inside in the middle if needed. With a groove for the latch rods. Lots of possibilities.
    The one they make warps as it is.
    shifty`[QUOTED] likes this.
  26. Jan 22, 2024 at 8:49 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Nothing much today other than change out my wiper blade inserts with 94048 19” PIAA silicone ones. Ready for the next rain/snow event.
  27. Jan 22, 2024 at 1:39 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  28. Jan 22, 2024 at 1:42 PM
    Jack McCarthy
    Bill
    North of Boston
    Moog? Lifetime warranty. Just gotta find that receipt.
  29. Jan 22, 2024 at 1:56 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    VR6T likes this.
  30. Jan 22, 2024 at 2:03 PM
    Want my OEM take-offs if I still have em?
