  1. Dec 10, 2023 at 8:34 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I’ve got the windshield top gasket covered in electrical tape and I’m still getting leaks in downpours so I’m hoping the third brake light is another culprit.
  2. Dec 10, 2023 at 8:35 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Having experience with water leaks from a dealership standpoint, the third brake light would have been my first go to. I see more third brake light seal failure than I do windshield seal failure
  3. Dec 10, 2023 at 8:35 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Bring your own dogs?
    FrenchToasty likes this.
  4. Dec 10, 2023 at 8:36 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I tried to bring you…:rofl:
    Bring your own dachshund
  5. Dec 10, 2023 at 8:45 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    No more state computers. Wow. I guess that'll save em some money on the cost to own and maintain their inspection computers, plus the audits.
  6. Dec 10, 2023 at 8:49 AM
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    Thanks @daveeasa.
    I’ll look into the reverse and tuck the gps antenna in. The manual does say that you can't have it in a “closed console,” so we’ll see how it works out.
    After googling for a few minutes, sounds like alpine requires you to set the brake, release it, and set it again to view the settings. Internet has mixed reports of the bypasses working.
  7. Dec 10, 2023 at 8:51 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I guess that means TX must also be doing away with the gas cap pressurization test
  8. Dec 10, 2023 at 8:53 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Lots of people just installed alpine and you need the brake bypass to use the unit to its fullest, most of these guys had no issues with the modules they picked up from flea bay I believe
    https://www.tundras.com/threads/the-great-hu-install-of-2023.129229/
  9. Dec 10, 2023 at 8:58 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I don’t see how they can keep it. North Carolina did away with that back in 2009. I was a North Carolina state inspector up until I moved to Texas. I should just take the inspection glass here.
  10. Dec 10, 2023 at 9:01 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You should, I mean if I could pass it, most of y'all here could :D
    I need to retake it though, mines expired.
  11. Dec 10, 2023 at 9:21 AM
    This is an easy one. Put a piece of clear packing tape completedly over the 3rd brake light (HMSL), so it's completely sealed in a bubble, with the tape contacting paint in a solid perimeter around the light housing.
    Clear packing tape specifically. I wouldn't use electrical tape, it doesn't bond as water-tight as packing tape. If it's still leaking, you know it's 100% impossible the HMSL is the source. If water stops, scAmazon has a replacement seal.
  12. Dec 10, 2023 at 9:32 AM
    This is what I bought (and it worked great) for my Alpine ilx (w650) but it's no longer available on scAmazon:
    I did find that exact unit by MicroBypass listed on a few other websites and on fleaBay by searching for "MicroBypass Alpine"
    However, it appears PAC - which is a brand I'm more familiar with and trust a bit more - also makes a unit that's less expensive. It's the TR-1 (but not the TR-4!!) and works for Kenwood and Alpine units alike. SonicElectronix carries it (link) and I see them on fleaBay also.
    JakeJake, artsr2002 and FrenchToasty like this.
  13. Dec 10, 2023 at 9:45 AM
    It's definitely good stuff, it's what I used to get the grime off my camper. But read the warnings on the label, I sore I saw something funny on there. And don't inhale the stuff, ugh. Since you already have the bottle, I posted the recipe over here to refil with: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1752#post-3379382
    Oh, and the clear version smells awful. It almost smells like mildew and rubbing alcohol to me.
    Wait ... did you use an amp adapter that lets you keep the factory amp, or an amp bypass to use your head unit for sound?
    Amp adapter typically kills your ability to fade - this is a known issue. Amp bypass lets you to retain the ability to fade/balance, by linking your head unit directly to the speaker output wires at the OEM amp.
    oscardog86 likes this.
  14. Dec 10, 2023 at 10:02 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I assume that with most stuff but surprised to hear it about Dawn. When something is sprayed like that it's almost impossible to not inhale it unless you mask up.
  15. Dec 10, 2023 at 10:03 AM
    SharkDog
    SharkDog New Member
    Denver
    Thanks. I'll check it out.
    Thanks shifty for the parking brake bypass info.
    I used a bypass for the jbl amp. Metra 70-8117. It's more than possible I am misunderstanding how something works. Hopefully, I'll get the parking brake issue dealt with, be able to open the settings on the alpine, and fade will be right there and fully functioning.
  16. Dec 10, 2023 at 10:07 AM
    It hurt my lungs and irritated my sinuses, and I'm the kinda guy who's unaffected with chilling in a room full of PB Blaster and even MEK doesn't seem to screw with me, although I know better than to hang out with it.
    I think it's because Powerwash is such a high concentration of isopropyl, maybe?
    Ok, I feel like we chatted about this before, I remember someone posting publicly about looking into that harness recently. You're kinda in uncharted territory there, in that I haven't seen others using it. You probably hooked it up correctly, but that specific harness is only 2 channel (L/R) and not 4 channel (Front L/R, rear L/R). Hop in a call or online chat with Crutchfield support. They should be able to confirm.
    SharkDog[QUOTED] likes this.
  17. Dec 10, 2023 at 3:13 PM
    daveeasa
    David
    I like the PAC TR stuff.
    SharkDog and shifty` like this.
  18. Dec 10, 2023 at 4:00 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Like Shifty said. I would use a wire wheel (cheek poker) and clean up as much as you can reach. Once it's cleaned up, then lather it up with the POR. Thats about all you could do with it for the interim.
    shifty` likes this.
  19. Dec 10, 2023 at 4:16 PM
    daveeasa
    David
    I used to really like the alpine double din stuff when they first came out. And I coveted the 7909 and 7800 but never owned one. They sure had some nice stuff back in the day.
    dunno how I feel about floating screens. Seems like everyone is doing them, all the new Hondas all have the same basic screen growing out of the dash. And I don’t really like giant screens in the dash. I’m tough to please. I do like my ‘16 and the Pioneer 6600 a whole lot though.
    bmf4069 and 455h0le_dachshund like this.
  20. Dec 10, 2023 at 4:45 PM
    That's why I like my iLX Alpine (w650). I wish it supported wireless CarPlay, I'd like to give it another shot, looks like it's improved over the years. But it does everything I need, bluetooth audio, and it's just a nice looking screen, sleek, no garish buttons like most others have.
    I've still got a spare OEM 86 radio I wouldn't mind installing, but losing 4.1 RCA outs would be a killer for me with my setup.
  21. Dec 10, 2023 at 5:02 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    The ilx w650 is on my wishlist, but its pretty low on the priority list. Glad to see its shifty` approved ™
    Currently working on my suspension order and trying to talk myself into some spc upper control arms.
    shifty`[QUOTED] likes this.
  22. Dec 10, 2023 at 5:32 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    those wonky looking spc UBJ's might be 1/2 ton chevy bits, available from any local parts store.
    I know the bolt in ubj's on the jba UCA's i ordered are 1/2 ton chevy bits.
  23. Dec 10, 2023 at 6:13 PM
    Save some $$. Buy the Eibach branded version. Will shave off $200-400.
  24. Dec 10, 2023 at 6:14 PM
    JakeJake
    2000 Tundra AC 4X4
    Im after the extra adjustment though. With something like that I would still be limited to the factory Bj location.
    The SPC uca's have up to 4° of caster adjustment and up to 2° of camber adjustment. Im also considering the JBA uca's with 3° of fixed caster and no additional camber adjustment.
    Both are probably overkill, but if I'm going to do bushings and balljoints anyway, now would be the time to do it.
  25. Dec 10, 2023 at 6:15 PM
    JakeJake
    2000 Tundra AC 4X4
    It looks like the Eibach and Mevotech branded units are in short supply. I'll do some more digging before I make a decision.
  26. Dec 10, 2023 at 6:23 PM
    Eibach should be readily available? They show as out of stock at their site but that’s been the case for a while now. If Eibsch is out stock everything should be because they’re the same part with a different box skin, I’m sure all drop shipped from same warehouse or some crap.
    I got mine from Elite Race Fab, they don’t appear to be the cheapest anymore. I’m seeing prices as low as $670. I guess you could call one of these places and confirm stock.
    Ordering the Mevotech would be a bitch, you have to order left and right independently and they always seem to be out of one or the other.
    JakeJake[QUOTED] likes this.
  27. Dec 10, 2023 at 6:24 PM
  28. Dec 10, 2023 at 6:27 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    @RUSTYNUTS has some spare off roading UCAs (MCM maybe?) that he might want to unload, if you ask gingerly.
    shifty` likes this.
  29. Dec 10, 2023 at 6:41 PM
    JakeJake
    2000 Tundra AC 4X4
    Did some digging and I found a set of Eibach's for $678 shipped. All the usual places I like to order through are showing out of stock, but suspensionhouse.com seems to be well reviewed and with their Christmas discount code and free shipping its the best price I found.
    Im still not convinced though, I'll have to do some more noodling about it.
    shifty` likes this.
  30. Dec 10, 2023 at 6:43 PM
    AleHole
    AleHole PNW
    Seattle
    '06 DC SR5 4WD Tow Package w/LSD
    Looking sweet!
