  1. Dec 9, 2023 at 10:45 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    2 choices on blue, either it broke the bolt somewhere or the weldnut on the frame broke off.
    Not sure if you could do it but maybe a holesaw through the bed around the ones that won't come out. Then you could remove the bed and work on getting them out with more room.
  2. Dec 9, 2023 at 11:09 AM
    daveeasa
    David
    How long did it take you?
  3. Dec 9, 2023 at 11:11 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Induction heaters can be tricky because of the ability to get full access to the bolts to heat them up. The ones up front in the bed are especially difficult to get access to anything more than the tip of it.
    FrenchToasty likes this.
  4. Dec 9, 2023 at 11:13 AM
    Nah, I'm just saying, if you plan to get spray-in liner, be thoughtful about how it's applied.
    If you choose a drop-in liner, make sure you clean out underneath it.
    You may not need to worry about anything, given you're in the tri-state(ish) area and not farther north.
    jpink[QUOTED] likes this.
  5. Dec 9, 2023 at 12:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Thirty mins maybe
    daveeasa[QUOTED] likes this.
  6. Dec 9, 2023 at 2:19 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Changing the carrier bearing this afternoon. Got all the bolts out. Only problem is the dirty deeds equal length x-pipe runs right under the drive shaft, just after the bearing. So I can't take the two shafts down to the ground, at an angle, to split them, the easy way. Going to try yanking them apart, to the side. Or maybe just completely unbolt one side of the drive shaft from either the transfer case or the third member entirely.
  7. Dec 9, 2023 at 2:57 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    well with step one being to sand the paint on the bed before spraying.... Maybe annual waxing is the best option. The plastic liner in my Taco bed is easy enough to remove 1x a year.
    shifty`[QUOTED] likes this.
  8. Dec 9, 2023 at 3:07 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Well - you never know - he may be dumb enough to want to use the old bed to build a Matchy-Matchy Tundra trailer.:anonymous:
    20171209_170332.jpg 20180114_170301.jpg 20180114_132726.jpg 20190609_190548.jpg
    Voss, txagg, oscardog86 and 6 others like this.
  9. Dec 9, 2023 at 5:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Might as well line the underside while you have it off too.
  10. Dec 9, 2023 at 11:06 PM
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    Finally got the stereo installed. It took me all day. New speakers all around. Hertz 170 components up front and hertz 130 coaxials in the back door.
    I also put some sound deadening in the doors and a couple more pieces along the back wall. It’s hard to know if it made a difference, but it all sounds way better than the beat jbl stuff. I’m happy with the sound.
    Alpine ILX 507 for the head. I didn’t hook up the gps antenna, which evidently means wireless CarPlay doesn’t work. I’ve got to plug the phone in for CarPlay. That’s dumb. I figured I didn’t need the gps antenna since I’m using my phone for navigation. I got lazy and didn’t want to figure out how to run it to the top of the dash. Lesson learned.
    Also, I didn’t hook up the reverse camera or the parking brake. I ran out of time and motivation for both of those.
    Is there a ready made parking brake cheater? Some way to trick it?
    I bought everything from crutchfield, which made the wiring simple. It seems that I may have lost the ability to fade front to back, which is a bummer. There was only one set of rcas on the crutchfield harness. Without the parking brake hooked up, alpine won’t let me look at the head units settings, so I haven’t confirmed that yet.
    only photo I took was this cluster.
    Voss, txagg, oscardog86 and 3 others like this.
  11. Dec 9, 2023 at 11:11 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    GPS is required for wireless carplay? BAH. antenna should still work well enough under the dash right above the radio. thats how factory GPS in that era worked.
  12. Dec 10, 2023 at 12:01 AM
    SharkDog
    SharkDog New Member
    Denver
    I hope your right. I am going to try it all tucked up first.
  13. Dec 10, 2023 at 4:50 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Today my truck received her final Texas state emissions inspection. Safety only from here on out:thumbsup: Yes @JakeJake Denton County is one of those ;)
    bmf4069 and 455h0le_dachshund like this.
  14. Dec 10, 2023 at 5:23 AM
    daveeasa
    David
    I stuffed my gps antenna inside the dash on my ‘05 Tacoma. I don’t believe my Pioneer 4660 needs one though as my ‘02 Tundra doesn’t have one and I use wireless CarPlay in it.
    you can ground the parking brake. That’s an easy cheat.
    Mine does complain about the speed sensor not being hooked up. I need to deal with that at some point. But it doesn’t block functionality.
    reverse is available from the integration relay (where your fuses are in the cab) as an external relay next to the flasher relay (good opportunity to swap the flasher with a smart tap too.). For me the wire was red with black stripe. Probably other locations to grab reverse as well.
    SharkDog likes this.
  15. Dec 10, 2023 at 5:50 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  16. Dec 10, 2023 at 6:32 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  17. Dec 10, 2023 at 6:34 AM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
  18. Dec 10, 2023 at 7:05 AM
    Jack McCarthy
    Bill
    North of Boston
    That’s odd. 23 years before you’re exempt? I only had to wait 15 and I’m in one of the most communist states of the country. Go figure.
  19. Dec 10, 2023 at 7:47 AM
    Jack McCarthy
    Bill
    North of Boston
    Decided to cover the gap around my third brake light with electrical tape to determine if the interior leak of the roofline above the rear view mirror is from rain penetration at that point. The onslaught of a downpour is an hour or two away so I’ll see if I need to address it to keep leaks permanently away.
  20. Dec 10, 2023 at 7:55 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    texas is going to safety only. I've seen what the paper plated city dwellers drive. Its terrifying how lax it already is.
  21. Dec 10, 2023 at 7:58 AM
    empty_lord
    05 rollover special
    I live in a state that’ll literally let me plate a tank. BUT because I’m so close to Chicago, we have emissions every 2 years for any vehicle 1976 or newer. UNLESS you get historic plates
  22. Dec 10, 2023 at 8:05 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The Junkyard threw in this free intake for John. That is one nasty air filter someone was running.
    I recently discovered Dawn Powerwash. I'm hooked.
    Voss, oscardog86, bmf4069 and 5 others like this.
  23. Dec 10, 2023 at 8:15 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It's actually 25 years. Which is excessive. What Mamba is saying is his inspection of his 2000 will last until Dec. 2024 and the state gives you a one month grace period, so call it Jan. 2025, at which point his Tundra will be 25 model years old and exempt from further emissions testing. Unfortunately they don't go by the build date.
  24. Dec 10, 2023 at 8:18 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I thought I read that its ditching the safety inspections, but going to stay the same as far as metropolitan areas and emissions inspections. So basically it changes practically nothing for a lot of us, unless some rouge counties, far from metropolitan areas, currently require emissions. As far as I know, it's only the metropolitan centers and their adjacent counties. Which is probably why you just berely skirt the emissions inspections where you are. I assume your county does not touch the county that SATX is in.
    Edit: well I was wrong, your county does touch. No clue how you got so lucky.
  25. Dec 10, 2023 at 8:26 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I still see some white on the filter. Just needs a Texas Tune Up, aka smack the filter on the ground multiple times, to knock the crap out, then put it back on. :D
    shifty` and The Black Mamba like this.
  26. Dec 10, 2023 at 8:28 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I had that same leaking spot, but it was the windshield and rust under it causing the leak
  27. Dec 10, 2023 at 8:30 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Also, they probably don't expect yalls cars and trucks to last 15+ years in the rust belt, let alone 25+ years :boink:
  28. Dec 10, 2023 at 8:30 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    This is true. Texas is changing its inspection process Jan 2025. The irony in this is, as ass_hole dog said, I will be emissions exempt by the time that comes around :(. Being a Texas state inspector, he would know.
    Texas is also going to be transitioning from a dedicated state inspection machine to a BYOD process. I don’t know the exact details of this yet, but my shop has opted in to be a beta tester for this.
  29. Dec 10, 2023 at 8:32 AM
    Jack McCarthy
    Bill
    North of Boston
    So true. :D
  30. Dec 10, 2023 at 8:33 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Long post, but here are the details I have so far:
    Attention Vehicle Inspection Stations:
    The Texas Department of Public Safety is excited to share that the Vehicle Inspection Connection Bring Your Own Device (VIC BYOD) project is officially coming soon! While stations are not required to switch to BYOD immediately, BYOD will become the only method of inspection entry starting 1 January 2025. BYOD enables inspectors to use a cell phone, tablet, laptop or desktop computer to record vehicle inspection information. Refer to the information below for important information about the VIC BYOD launch.
    Station Owner Action Request: Complete this brief survey (https://deloittesurvey.deloitte.com/Community/se/3FC11B2664F7A70E) to indicate whether your station plans to opt-in to the BYOD program. Your feedback is essential to VIC BYOD launch planning.
    • Note: VIC BYOD adoption is not required at this time, and legacy VIC units may still be used upon VIC BYOD launch. BYOD is strongly recommended for a more seamless and adaptable inspection process.
    Key Details & Reminders:
    • VIC BYOD Project Overview: The VIC BYOD project empowers station owners to choose an inspection reporting device that best supports inspector working environments (e.g., phone, tablet, laptop). Use of mobile devices/tablets allows flexibility for inspectors throughout the inspection process, including a camera-enabled VIN scanning feature. Additionally, BYOD walks inspectors through each step of the inspection process and offers a straightforward and user-friendly experience.
    • Launch Date: A communication including the official BYOD launch date will be shared in the coming months.
    • Required Equipment:
    ◦ Printer: Vehicle Inspection Reports must still be printed at the conclusion of each inspection. Inspection stations adopting BYOD are required to have a printer that accommodates printing from the mobile device or computer being used. DPS will not provide a printer and does not recommend a specific type of printer.
    ◦ Mobile Devices: Station owners are responsible for determining the BYOD device(s) that best fits their station's needs. DPS will not provide BYOD equipment.
    • Training: Training videos and user guides that provide detailed guidance on how to complete inspections on your device will be released in the weeks before BYOD launch. If your email or the point of contact for your station has changed, be sure to update your information on file with DPS.
    • Internet Browser Requirements: The software is a web-based solution designed to work on the following browsers: Chrome, Edge, Safari and Firefox. Internet Explorer will not be supported.
    • Questions: Contact either our VIC Call Center—open daily from 7:00 am to 8:00 pm Central Time at (855) 845-0842—or your DPS representative with questions you may have prior to launch.
    Thank you for your participation in the Texas Vehicle Inspection Program. We ar
    e excited to launch this modernized approach to vehicle inspections!
