  1. Mar 23, 2019 at 10:20 PM
    #5311
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    After looking at those pics I'm definitely taking mine apart by end of April. When I turn my air on high I can hear twigs and leaves bouncing around, bet mine looks just like that.
    lsaami likes this.
  2. Mar 24, 2019 at 6:08 AM
    #5312
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    @Professional Hand Model when you say more volume, how so? Mine sucks. It almost all comes out of the drivers center vent, barely any out of the other 3.
    Also, where is that located? Pass side floorboard?
    tacoguybill likes this.
  3. Mar 24, 2019 at 6:13 AM
    #5313
    Hand Protectors
    Its considered the ‘resistor, blower’ per specs as I wondered exactly what it was myself and found out after research. Cost $21. Mine was a little corroded so I wire brushed it and then put some dielectric grease on what looks to be a fusable link. After that I sprayed some silicone on the rest. Looked fairly new when finished. I’m sure the corrosion was creating some resistance in itself.
    NUDRAT[QUOTED] likes this.
  4. Mar 24, 2019 at 6:28 AM
    #5314
    Hand Protectors
    Passenger side under glove box. Remove the glove box and you’ll have open access to most duct work. You might have a disconnect somewhere. On the drivers side foot well, I lubed up the control cables a plastic sliding parts just because. There is some duct work over there and depending on your situation, you may need to remove the apron under the steering wheel.
    Driverside with partial ducting removed.
  5. Mar 24, 2019 at 6:31 AM
    #5315
    Hand Protectors
    Smoother sounding volume and not as noisy. Maybe 10% better? The blockage in the coils looked like 30% blockage. The air was being forced to other areas of the coil making more effort and noise.
  6. Mar 24, 2019 at 6:38 AM
    #5316
    Hand Protectors
    Do your dry work first. You’ll need a stiff wire hanger to carefully break up the lower stuff. Vacuum and then spray your water hose in the same hole as the vacuum is pictured. The blower hole you’ll use as a spy hole to see where you are aiming.
    Darkness[QUOTED], NUDRAT and bmf4069 like this.
  7. Mar 24, 2019 at 7:44 AM
    #5317
    NMTundra
    NMTundra New Member
    Let me know how this goes. I just ordered a set of Katanas off of Amazon (supposedly identical to the Supernova V4s and manufactured in the same factory for 1/3rd the cost) but if they don't work out I'm going to start looking at all options. Hate the stock headlight output on this and my wife's 2016 4Runner (why it doesn't have HIDs from the factory is beyond me).
  8. Mar 24, 2019 at 12:50 PM
    #5318
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Half way done.
    One box/ 9sheets was enough to do Both front doors. Outer and inner door skin's. Both sides of the floors .
    I also did the inner kick panel and the plastic parts.
    Also did a little behind the speedo.
    My second box will be here in about an hour.
    I'll do the rear doors and back part of the cab today.
    Acatlin96, Darkness, bmf4069 and 5 others like this.
  9. Mar 24, 2019 at 5:05 PM
    #5319
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Fixed the plastic scuff plates while I had every thing apart.
  10. Mar 24, 2019 at 9:02 PM
    #5320
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    one side apart. ran out of time tonight... plan on getting the driver side all buttoned up (sans valve cover. they're not back yet) tomorrow and starting on the passenger side... man toyota made these cam seals a bitch. now i remember why i dont like doing them at work
    [​IMG] [​IMG] [​IMG]
  11. Mar 24, 2019 at 9:04 PM
    #5321
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That looks fun! But a weird, torturous kind of fun.
    NUDRAT likes this.
  12. Mar 24, 2019 at 9:05 PM
    #5322
    empty_lord
    05 rollover special
    its not as bad as what im doing to my tacoma! lol... that ones been 3 years of torture.. mostly financially.
    because_wumbo-truck and Darkness like this.
  13. Mar 24, 2019 at 9:56 PM
    #5323
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Drove back home from Mexico and averaged a respectable 18.6 mpg. If I keep it 70 or less that seems to be about as good as it will get. I noticed on my trip that if I stay 65 or less I can get 19.
    Checked out a kind of museum while I was down there and saw some pretty cool antiques.
    Pretty sure this is the oldest water heater I've seen.
    Old motorcycle
    Ancient lawnmower with...
    Ancient run flat tires ;)
  14. Mar 24, 2019 at 10:05 PM
    #5324
    Casper421
    In the woods
    06 DC
    So much jealously right here!
    lsaami and Darkness[QUOTED] like this.
  15. Mar 25, 2019 at 4:20 AM
    #5325
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Me too. I filled up yesterday. Went 280.2 miles and filled with 24 gallons for a whopping 11.675 mpg. I dont tow, no lift, stock size tires, no mods. And I'm 60% hwy.
    lsaami likes this.
  16. Mar 25, 2019 at 5:05 AM
    #5326
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Good to know I’m not the only 1st gen getting beans for mileage. I’ve finally worked my way up to 13 mostly highway.
  17. Mar 25, 2019 at 5:11 AM
    #5327
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Flat land or hill country?
  18. Mar 25, 2019 at 7:13 AM
    #5328
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    :eek:
    :spending:
    That's brutal.
  19. Mar 25, 2019 at 7:28 AM
    #5329
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Does anyone else think we need a daily discussion or "ask a question" thread so we don't clog this one up?
    I know I'm bad about asking questions in this thread and steering it off course. Let me know if you think we should leave it as is or have a separate sticky for things that don't involve work we've done with/to our trucks.
    bmf4069 likes this.
  20. Mar 25, 2019 at 7:28 AM
    #5330
    Hand Protectors
    Thats my towing city average. You riding with your foot on the brake?
    Darkness likes this.
  21. Mar 25, 2019 at 7:34 AM
    #5331
    Hand Protectors
    Maybe? When I got here last year it was pretty slow, so I started clogging things up with stupid questions as it seems things are more responsive in this area. Spring is here and more goons, like us, are getting on board here. A Daily Discussion Area might be nice.
  22. Mar 25, 2019 at 7:37 AM
    #5332
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah and I don't mean to direct that towards anyone in particular. You're actually posting pictures of the work you're doing. I just thought a separate thread to ask questions might be helpful. I'll see if a few more agree. I'm good with it either way.
  23. Mar 25, 2019 at 8:40 AM
    #5333
    Sunnier
    Sunny
    San Diego, CA
    You want it tied to First Gens, or just a catch all for anything anyone on the forum wants to ask?
  24. Mar 25, 2019 at 8:42 AM
    #5334
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I meant specific to first gens. Good question.
    NUDRAT and Sunnier[QUOTED] like this.
  25. Mar 25, 2019 at 8:59 AM
    #5335
    Sunnier
    Sunny
    San Diego, CA
  26. Mar 25, 2019 at 9:00 AM
    #5336
    Sunnier
    Sunny
    San Diego, CA
    Or you could start a new thread, so you could set up parameters with your first post.
    Casper421 likes this.
  27. Mar 25, 2019 at 9:03 AM
    #5337
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    Wait, so how did you fix it? It looks like you cut off the protruding plastic piece on the scuff plate... What did you add to insert into the clips??
    Am I looking at it wrong?
  28. Mar 25, 2019 at 9:07 AM
    #5338
    abcinv
    Tommy
    NW Georgia
    Hit 63k thousand this weekend. Going to start swapping out fluids and probably do the Timing Belt and associated parts this summer. 13 years may be pushing it a little...
    Please ignore the part where I took the picture driving 60mph...
  29. Mar 25, 2019 at 9:44 AM
    #5339
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Most of the tabs were broken on the scuff plates. So put the white nylon clips into the hole of the truck.
    So now the screws that hold on the plates go through the plate and into the nylon clips in the truck.
    No more loose plates, cheaper then buying new scuff plates.
    NUDRAT and Casper421 like this.
  30. Mar 25, 2019 at 9:50 AM
    #5340
    abcinv
    Tommy
    NW Georgia
    aahhhh, got it. I need to do that as well...
    Thanks!!
    Jerry311SD[QUOTED] likes this.
