  1. Nov 5, 2023 at 5:30 PM
    Basically you pull this tab toward you, it's part of the windowscreen housing. When you do, you can slide the one movable half-window forward, using that vertical bar you see above and below the circle. Now I need to figure out how to remove the screen so I can clean it, or better yet, replace it, because the passenger side has a tear in it.
  2. Nov 5, 2023 at 5:50 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    My cap’s cab-side window has a center slider that matches the truck’s rear slider perfectly. The whole cab-facing window is also fully removable, which is pretty cool. Makes the bed really water-tight.
    shifty` likes this.
  3. Nov 5, 2023 at 6:00 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I gave up trying to actively keep my windows screened. Just spline in a channel that holds the screen on, should be able to get the spline out with a pick or screwdriver fairly easily. If you need new spline, this should work: https://www.amazon.com/gp/product/B000NYAHK6?ie=UTF8 My original spline was trash and the spline I had on hand was too thick
    FrenchToasty and shifty`[QUOTED] like this.
  4. Nov 5, 2023 at 6:24 PM
    This one does too. Perfect match, really. While in the bed, I just can’t seem to figure out how to slide the center window. There’s no handle for the center on the bed side, and it’s, like, inset between the two sides. Super weird. Maybe you can only open from inside the truck?
  5. Nov 5, 2023 at 6:29 PM
    des2mtn
    Shady Grove
    Tonto cover
    Me thinks a little elbow grease and then some Sil-glyde in the window channels afterwards might help. The channels may be pinched in slightly from the PO to keep the window from sliding open as easily. The center window on mine will open while I'm driving/ offroading. My cap had "handles" glued on the cab-side and bed-side of the window, and the bed-side one came off from over-use. Can still open it from inside the bed though with the tips of my finger.
    FrenchToasty likes this.
  6. Nov 5, 2023 at 6:34 PM
    Definitely confirmed on the passenger side window. It’s caked. This bastard is gonna need some PHM-level TLC spa treatment. Or is it a hand job?
    I think I’ll call a local Leer dealer or two tomorrow to see if they carry slider windoors. Word I’m finding on the internet is if they’ve got em, they’re either going to be batshit crazy $450/ea or possibly as little as $150/ea.
  7. Nov 5, 2023 at 7:29 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Beware the junky aftermarket drums. They can come out of the box not round.
    That's an interesting way to do that. Cheaper than extended links.
    Whats the frame recall status on your truck?
    How bad were the brake pad pins to get out of there?
    That's the same way my windows are on mine. Those may even be the same window assemblies as mine has. Shape looks the same. I've never really determined what kind of cap I have. It's got a name on the back but I don't even remember what it is off hand.
    shifty`[QUOTED], bmf4069 and des2mtn like this.
  8. Nov 5, 2023 at 7:33 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Easy peasy. I changed them out a year or two ago with new ones.
    Something I do every few years to avoid having to drill them out like the first time I did my brakes many years back.
    NUDRAT and NickB_01TRD[QUOTED] like this.
  9. Nov 5, 2023 at 8:12 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  10. Nov 5, 2023 at 8:16 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Looks like polo is in your bed again
  11. Nov 5, 2023 at 8:41 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Yea, this became 'our' sleeping bag, and he started calling me comrade.
    txagg, bmf4069 and BroHon like this.
  12. Nov 6, 2023 at 3:10 AM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Negative, I've looked into it a couple times, can't remember all of the info. I was just under the back end this weekend and got my eyes and hands right up in that spare crossmember... it's solid, no perfs, no debris either. Inside the front frame rails was treated with some kind of coating too, so I think it was "dealer" checked/treated/ and cleared.
    NickB_01TRD[QUOTED] likes this.
  13. Nov 6, 2023 at 4:43 AM
    Jack McCarthy
    Bill
    North of Boston
    Okay, we’ll that’s just unacceptable for HVAC generic 194 bulb replacement. I’ll have to put in the Sylvania 168s to see if it’s better before going the LED route.
  14. Nov 6, 2023 at 5:26 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    Huh. So then I wonder if the idea’s that you can swap that whole window frame around to have it open from either side?
  15. Nov 6, 2023 at 5:35 AM
    daveeasa
    David
    My front glass slider for the leer 100xq I have on the ‘16 has a knob accessible from the front. So you open the truck slider then the shell slider from within the truck.
    You can still open the slider from inside the shell with dry hands and enough friction. Or you can remove the window entirely from within the shell using the tabs at the top.
    It’s an OK design but knobs on both sides would make sense to me.
    shifty` likes this.
  16. Nov 6, 2023 at 5:44 AM
  17. Nov 6, 2023 at 6:02 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  18. Nov 6, 2023 at 6:08 AM
    Jack McCarthy
    Bill
    North of Boston
  19. Nov 6, 2023 at 6:11 AM
    w666
    Maryland
    All white...much better
  20. Nov 6, 2023 at 6:48 AM
    That would put the two residental-window-style flipout locks on the outside of the truck, which doesn't make sense to me.
    I'll hafta double-check to see if I've got tabs. I'll take a pic of it in a bit, stuck in a meeting at the moment listening to people drone on.
    Interesting. I think I'll just get a miniature clear suction cup and plop it down into the corner if I find out this does in fact slide.
  21. Nov 6, 2023 at 9:28 AM
    SateenC1
    SateenC1 Fossil
    Bob
    Lake Tapps Washington
    2004 Blue Marlin Pearl Tundra SR5 DC 4×2
    Bilstein 5100s, Helwig Swaybars and Helper Spring, Flowmaster dual exhaust, AfE Cold Air Intake, Dirty Deeds 12 hole 250cc Injectors, MSD Coils, Pedal Commander,Yakima bars and cargo box,17" wheels.
    The greatest thing about retirement for me, is no more meetings. There's always those that must say something just to say something and cause the meeting to go on forever. You have my deepest empathy Shifty.
    NUDRAT, txagg, FirstGenVol and 3 others like this.
  22. Nov 6, 2023 at 9:41 AM
    Only a few more years of this left, save some of that empathy for the young bucks 40 and under. :D
    (I appreciate it though!)
  23. Nov 6, 2023 at 9:46 AM
    Jack McCarthy
    Bill
    North of Boston
    I’m sure I have a few post PDR meetings to goto when I get back to work. I already attended a PDR walk-thru and two dry runs.
    You’d think the PDR was getting published and going to the customer, but it’s not.
    Now comes the post-PDR minutes to discuss and action items to close out.
  24. Nov 6, 2023 at 10:15 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    I could use it. I still have 30+ years until retirement.
    Hi06silver and shifty`[QUOTED] like this.
  25. Nov 6, 2023 at 11:57 AM
    SateenC1
    SateenC1 Fossil
    Bob
    Always pluses and minuses. It's a shame that for most of us, a main requirement for retirement is you gotta be old!
  26. Nov 6, 2023 at 12:01 PM
    It's not the age part I mind so much. It's the fact that I've noticed, the closer I get to retirement, the more aches, pains, and difficulty moving I've got, which is going to make it harder to retire the way I want to.
    Honestly, the whole model is a sham. By the time I'm able to rollout my 401k, I'll be spending all that $$$ on medical. Such BS. :rofl:
    abcinv and SateenC1[QUOTED] like this.
  27. Nov 6, 2023 at 12:05 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    If this were Wheel of Fortune, my 401K couldn't even buy a vowel.
  28. Nov 6, 2023 at 12:13 PM
    I'm fortunate to be on the other end of that spectrum.
    It's the one thing I did right: I got in with a company 25 years ago, they offered 401k with matching, and even though it hurt I started funneling 10% of everything into it, setup highly aggressive, then buckled in for the ride. And it's been a ride. At this point, I'm working to pay the bills and any extra going in is what it is. As long as the whole program doesn't go insolvent or something, I'm alright.
    I can honestly say, I believe this is probably one of the only great financial decisions I've made in my life. I've done so much stupid stuff, I'm glad I bit the bullet and suffered through the 1st ten years or so of 10% of my paycheck rerouted. And anyone on here that's under 35, I can't impress upon you enough, if you're with a company that offers 401k, especially with matching, you'd be stupid not to take it. Not to say someone in their 40s or even 50s couldn't get started, but ... I got lined setup in my early 20s when I honestly hadn't a clue what it would really snowball into.
    NUDRAT, txagg, bfunke and 5 others like this.
  29. Nov 6, 2023 at 12:20 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I started at 4% and increased it a percentage every year. I did stop at 8 only because it would hurt to go up to 9. 10 is awesome. Good on you. My company's match sucks, they do 0.5% upto 1.5%. Stingy bastards.
    shifty`[QUOTED] likes this.
  30. Nov 6, 2023 at 12:27 PM
    I started at 6 to maximize my companies matching and increased 1% every year. Last year they cut off the matching due to max contribution in November. I was at 14% contribution myself. So I dialed it back to 11% to get the full year long matching and maximize my employers contributions. The extra I put into a separate retirement account now.
    Hi06silver, txagg, abcinv and 5 others like this.
