  1. Oct 24, 2023 at 11:58 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    … with the nos tank :devil::headbang:
    You’re a Manx and a sandrail:lalala:
  2. Oct 24, 2023 at 12:27 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I changed engine oil today. I ran a can of BG EPR through it. That shit was nasty coming out.
    Voss, bmf4069, NUDRAT and 5 others like this.
  3. Oct 24, 2023 at 2:08 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Wait - you left your skid plate on during oil change?
    02TundraIdaho likes this.
  4. Oct 24, 2023 at 2:08 PM
    I leave mine on
    The Black Mamba likes this.
  5. Oct 24, 2023 at 2:11 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yes. No need to remove it to access the drain plug.
    FrenchToasty likes this.
  6. Oct 24, 2023 at 2:25 PM
    bfunke
    South Carolina
    What about filter? You changing that?
  7. Oct 24, 2023 at 2:30 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Filter is easy to reach from the top side. IIRC.
  8. Oct 24, 2023 at 2:55 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    The 2UZ may be different. On my 5VZ, I can finagle my arm up in there to access the filter from the bottom. It doesn't sit directly over the skid plate so if I lose oil, it's not going to get on the top of the plate.
  9. Oct 24, 2023 at 3:25 PM
    bfunke
    South Carolina
    Gotcha. 4.7 has to come off to avoid big mess
  10. Oct 24, 2023 at 4:26 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Nah, that’s what brake clean is for:rofl:
    artsr2002 likes this.
  11. Oct 24, 2023 at 5:11 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    Did plugs today. I’m pretty sure they were the originals, after 158k miles they were overdue. Seems to run a little better.
    Voss, bmf4069, KNABORES and 4 others like this.
  12. Oct 24, 2023 at 5:13 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Were they Denzo plugs that came out? Mine in the 5VZ are NGK
  13. Oct 24, 2023 at 5:14 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    yea the ones I got from the dealer were the same as what came out
  14. Oct 24, 2023 at 5:15 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I stated that wrong. I intended to ask about the ones coming out of the packages, but you answered it. Thank you.
  15. Oct 24, 2023 at 5:23 PM
    Azblue
    The Dirty T ( ^_^)_且
    Na, not at all. I used to put some old rags or if I had some a piece of old carpet under the filter on the skid and was pretty good at getting it off with minimal spillage. Much quicker than screwing with the skid.
  16. Oct 24, 2023 at 5:26 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You can do it from above with some hand yoga moves, also a half gal milk jug cut and capped can catch all the drips and majority of the fluid.
  17. Oct 24, 2023 at 5:44 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    PHM vibes
    Hi06silver, Voss, BroHon and 5 others like this.
  18. Oct 24, 2023 at 5:46 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    LOL, X2
    Voss and RUSTYNUTS[QUOTED] like this.
  19. Oct 24, 2023 at 5:52 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I like to hit it from the side.....
    But even with Skid Row I still make a little mess removing the filter.
    Voss, oscardog86, bmf4069 and 5 others like this.
  20. Oct 24, 2023 at 6:03 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Either the 2UZ has a different skid than the 5VZ or my 00 has a different skid than your 02.
  21. Oct 24, 2023 at 6:22 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Skid Row is an aftermarket skid plate company. That's what I have and that's why I'm able to access the filter from the side.
    oscardog86, 02TundraIdaho and des2mtn like this.
  22. Oct 24, 2023 at 6:28 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Weirdest thing happened yesterday night. I was headed into a pretty strong headwind while going uphill, and had to keep my foot on the pedal to maintain 60. Within the course of about a mile, I watched my fuel gauge drop from approximately halfway down to under a 1/3 of a tank, and bounce around a little. It stayed there for a bit until I got out of the RPMs/ wind, then it returned back up to just under halfway.
  23. Oct 24, 2023 at 6:47 PM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    I washed it yesterday. Ended up buffing out some scratches from where the fender flares used to contact the paint, pretty happy that most of the scratches there came out :D
    Voss, oscardog86, BroHon and 10 others like this.
  24. Oct 24, 2023 at 6:47 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    About 3 years ago headed to work one morning going up I77 north at about 70mph my gauge slowly dropped from 3/4 down to 1/4. I had to pull off and check to ensure I didn't have a massive fuel leak. After I found no leak I continued on and the gauge sat at a 1/4 for about 5 miles and then righted itself. I’ve never seen it so that again.
    Voss and des2mtn[QUOTED] like this.
  25. Oct 24, 2023 at 6:55 PM
    des2mtn
    Shady Grove
    Tonto cover
    Yeah, I thought I had a massive fuel leak too, but had nowhere safe to pull off and get back on. Think my truck just really wanted to let me know I was probably getting 6-8mpg at best...
    Voss, whodatschrome, bmf4069 and 2 others like this.
  26. Oct 24, 2023 at 7:01 PM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Ooof 6 to 8 mpg, :goingcrazy:
  27. Oct 24, 2023 at 7:11 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Yeah that's an option if I could make it look halfway decent.
    Hard to say where it's coming from, I probably would have not even worried about it if I knew about the shipping charge before hand. Just didn't really think much of it.
  28. Oct 24, 2023 at 7:13 PM
    NickB_01TRD
    Nick
    KY
    This is conflicting, I had never heard anyone call it that until the last couple years and very rarely at that.
    I stick a doubled grocery bag under the filter and spin it off and let it drain. Worked for me the last couple times.
  29. Oct 24, 2023 at 7:17 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    My 72 Olds Delta 88 convertible got 8 mpg.
    (gas was $1.30/gal back then though)
  30. Oct 24, 2023 at 7:21 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Dad used to squeeze 12mpg out of a Dodge powered 28' brick-shaped class-A RV. Probably not when we were in the Rockies though. LOL
