  1. Oct 9, 2023 at 5:41 PM
    KMActual
    KMActual New Member
    Ken
    2006 Blue Tundra SR5
    New Wheels and Tires
    Voss, NUDRAT, Dakillacore and 17 others like this.
  2. Oct 9, 2023 at 5:42 PM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Took the old man to MD Anderson today in the best gen. When we got back I installed the Easylift for him. He’s been complaining about the weight of it when he’s holding the dog leash with one hand. I drilled the hole a little lower as suggested and it has plenty of help to it. I think it slows it down when dropping it as well. Best I could do for pictures:
    Voss, oscardog86, JasonC. and 8 others like this.
  3. Oct 9, 2023 at 5:42 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  4. Oct 9, 2023 at 5:56 PM
    Not sure if this will stick or not, but about searching the FSM for data ...
    FSM is broken up into sections which are tagged XX-# or XX-## where XX is a pair of letters referring to a specific section (DI = "DIagnostics", SA = "Suspension & Axle", BR = "BRakes", MT = "Manual Transmission", AT = "Auto Transmission", TR = "TRansfer case", etc.), and the # is just sequential numbers, the letters and numbers are always be separated by a dash.
    The fastest way I've found to get to the info you need, and how I found the info you needed in like 15 seconds... I was fortunate enough to remember that "SA-" would be the section I'd find it in. Thing is, that section goes from like SA-1 up to like SA-150-something. So here's what I do.
    I know it's in suspension. So use search up/get to section "SA-1"
    Once I'm in SA-1, I know I'm in the ballpark, so I just need to find the exploded with info I want.
    I knew you were hunting rear diff info, so while sitting on the first page of SA-1, I searched "rear diff" and it jumps you right to the rear differential parts way down around SA-100.
    From there, I just tapped 'next' to find the next instances of 'rear diff' and had the torque specs within 3 taps.
    This works for just about everything in there, but sometimes you gotta be particular about what you pic for your term to hone in once you're in the ballpark section.
  5. Oct 9, 2023 at 5:58 PM
    I know you're in TX and it's basically patina for y'all, but I'd be hard pressed not to smear some naval jelly on that rust patch for 10-15 minutes, then rinse and mist it with some rattle can.
    I'll be curious to hear how you're feeling about the tailgate assist after using it a bit. Curious, if you remove the tailgate, do you also need to uninstall the assist mech?
    oscardog86 and txagg[QUOTED] like this.
  6. Oct 9, 2023 at 6:13 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    That gold and blue with the yellow fogs, yes!!!!
  7. Oct 9, 2023 at 6:23 PM
    Nice!! This guy gets it. So glad you didn't go with black/gunmetal wheels.
    Tire specs?
    oscardog86 and FrenchToasty like this.
  8. Oct 9, 2023 at 6:23 PM
    Whoa, easy there fella, put it away. There’s women and chilren present.
  9. Oct 9, 2023 at 6:29 PM
    DJenerated
    Dija
    The Lone Star State
    Details?
  10. Oct 9, 2023 at 6:36 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    yeah, I’ll clean it up when I pull the bed. You would have to remove the easylift to get the tailgate off. I like it for my dad, and it works. I think it’s too primitive for you though, and you won’t like the way it functions mechanically.
    shifty`[QUOTED] likes this.
  11. Oct 9, 2023 at 6:38 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    the old man of the tailgate lift?
  12. Oct 9, 2023 at 6:39 PM
    DJenerated
    Dija
    The Lone Star State
    How's the old man doing?
    What model is that tailgate thingy?
  13. Oct 9, 2023 at 6:42 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
  14. Oct 9, 2023 at 6:48 PM
    DJenerated
    Dija
    The Lone Star State
  15. Oct 9, 2023 at 7:10 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    I just installed this a few days ago. Huge difference. My kids can now put the tailgate up with little effort. Install was about a half an hour just because I took my time with the holes and the measurements.
  16. Oct 9, 2023 at 7:12 PM
    dirtnsmores
    Southern CA
    Westin bed mat finally arrived. Perfect fit for my double cab! Smells terrible. Need to let it air out before I put the tonneau cover back on
    Link: https://amzn.to/3rIxOskPXL_20231009_215228761.jpg PXL_20231009_221434962.jpg
    Voss, NUDRAT, RUSTYNUTS and 8 others like this.
  17. Oct 9, 2023 at 7:15 PM
    DJenerated
    Dija
    The Lone Star State
    Sounds like I need this for my 2006. The Mountain Hatch tailgate cutting board cover thingy weighs a ton
  18. Oct 9, 2023 at 7:18 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I’d say 30 minutes is accurate, with two kids wrecking hell on me and my dad giving me an ear lashing.
    RUSTYNUTS, bmf4069, shifty` and 2 others like this.
  19. Oct 9, 2023 at 7:33 PM
    I appreciate the honesty. I remove my tailgate several times a year to unload dirt/mulch to keep up with garden (grown food) and landscape crap. I've been mulling over something, but I'd personally prefer soft-open vs. easy close. Nothing drives me nuts more than tailgate slamming open. I had suspicions whether I'd like it.
    That dent above the rear window - should pop out pretty easy with suction. YouTube search for dildo dent repair (not pranking you here) and you'll see. I've now done this on a few different vehicles and found it helps if you clean the metal thoroughly, then heat the sheet metal a lil bit before you slap your suction device on it.
    Usually gets the dent 95% or better out if there are no creases, one of my couple pulls was 100% and my neighbor was ecstatic.
  20. Oct 9, 2023 at 7:51 PM
    DJenerated
    Dija
    The Lone Star State
    Did you use a dildo?
    RUSTYNUTS likes this.
  21. Oct 9, 2023 at 7:53 PM
    Possibly. If I did, it wasn't mine, for the record.
    RUSTYNUTS, bmf4069 and Tripleconpanna like this.
  22. Oct 9, 2023 at 7:57 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Did you lick the suction cup first :boink:
  23. Oct 9, 2023 at 8:00 PM
    Required. Have to choose based on shaft diameter to grip circumference ratio. Too much girth is hard to hold. The more texture it has the grippier it is. The key is repeated quick forceful pulls until it “pops”. Warming it up certainly helps. May have to message the area after to smooth it out.
  24. Oct 9, 2023 at 8:02 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    You'll probably have to join his OF page for the 'instructional' video.
  25. Oct 9, 2023 at 8:27 PM
    The dildo of consequence rarely arrives lubed.
  26. Oct 9, 2023 at 8:30 PM
    Tripleconpanna
    Warming up the surface or the dildo????
    bmf4069, DJenerated and shifty` like this.
  27. Oct 9, 2023 at 8:38 PM
    yes
    RUSTYNUTS, JasonC., bmf4069 and 4 others like this.
  28. Oct 9, 2023 at 9:11 PM
    dirtnsmores
    Southern CA
    i'll youtube it... but i'm gonna have to log out so google doesn't mess with my algorithm. i can see it now... related videos: van life - using dildos in the frozen tundra @shifty`
    RUSTYNUTS and bmf4069 like this.
  29. Oct 9, 2023 at 9:16 PM
    dirtnsmores
    Southern CA
    the assist mech is only a single bar. that's it. nothing else. no nuts, no bolts. just the bar. pretty awesome and genius design in my opinion. I got my tailgate off pretty easily once you learn to rotate the tailgate as you're removing it. I wouldn't mind doing it once a month if i had to. putting it on is much harder than removing. coming down it's a billion times lighter, so it's super easy to guide it down with a finger. No way it'll slam down unless you don't keep your hand there. I dropped the tailgate of my tacoma today and it felt MUCH heavier than my tundra's tailgate after the EasyLift install.
    shifty`[QUOTED], txagg and DJenerated like this.
  30. Oct 10, 2023 at 5:44 AM
    daveeasa
    David
    FWIW, my friend who did the bracket for Taco 3rd gen tailgate dampener on 2nd gen tailgate said the Tundra won’t be possible given how things look. But he is doing an anti theft bracket and @assassin10000 has one I think.
    It’s a bummer since the 2nd gen Taco tailgate is super light (too light) and the Tundra w MH too heavy.
    I’m likely going to remove my MH for now I think. Haven’t decided on the torsion bar yet. Also need to cut and crimp a connector for the camera so I can remove the tailgate if I want to. But I might also just do the anti theft bracket and leave the tailgate permanently on.
    Tempted to swap to a custom flatbed in the 2nd gen Tacoma so I’ll have tray space for batteries for EV conversion. That’s the 5 year plan. It’d be nice to have one flatbed, they can be useful. Maybe some fold down / removable sides too.
    -Woodsman- and DJenerated like this.
