  1. Oct 7, 2023 at 12:33 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    I like those wheels too
    KTM_AJ421[QUOTED] likes this.
  2. Oct 7, 2023 at 1:03 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Cruise Control on 04-06 DC are not illuminated, only the Steering Pad. The 04-06 DC Cruise only has 2 conductors and somewhat surprised your cruise works since there's no pin 5 conductor !
    shifty` likes this.
  3. Oct 7, 2023 at 2:08 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Yeah the airbag side clockspring connector that came with my buttons didn't include the pigtail for the cc. I cut off the pigtail from my existing wiring and spliced it into the new connector. I used a piece of the 4 wires they included, snipped off about 6 inches from the end and popped it into the connector to make the connection to my cc switch. Works just as before.
    The yellow wire here in pin 5 goes to the white wire on my cc connector. I spliced the black together with the black wire and Bob's your uncle or something like that. Lol.
  4. Oct 7, 2023 at 3:29 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    thanks I was on the fence about them but with the new tires I think they look really good. I was going to buy aftermarket wheels but I don’t see a need anymore
  5. Oct 7, 2023 at 3:56 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Falkin wildpeaks are good tires. Subaru uses them OEM on the wilderness trim levels and they hold up really well.
  6. Oct 7, 2023 at 5:05 PM
    -Woodsman-
    -Woodsman- New Member
    NC
    05 SR5 DC Tundra 4WD
    dirtnsmores[QUOTED] likes this.
  7. Oct 7, 2023 at 9:03 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Day 2 hauling Dad's tired old (1986 JD 855) tractor from WI to ID:
    Fergus Falls, MN to Lewistown, MT, about 687 miles. I-94 across ND and then the beautiful two-lane 200 across MT.
    MPG settled at about 8.7 across 3 1/2 tanks. I was expecting better but see that this is typical after reading some trailer towing posts here.
    Trans oil temp was consistently below 160, coolant temps below 200 with a few spikes above that. Ambient temps ranged from 40 to the high 70s.
    Somewhere in MT:
    Earlier in the day I weighed it using the Cat Scales Weigh My Truck app.
    - The front axle is well below the 3,500 lb limit, probably because of the tongue weight.
    - The rear axle is below the limit of 3,760 lbs. Whew, I've got a crap-ton of heavy things in the bed and thought I might be over on this one.
    - The trailer axle plus about 500 lbs tongue weight is well below the 7,100 lb trailer towing limit for the Tundra. It's also below the 7K gvwr of the trailer.
    - The total weight is below the max total weight allowed of 12,600 lbs.
    I think those are the correct limits for a 4.7 with the tow package.
    I was glad to see weights in the ballpark, I tend to underestimate these things.
    The trailer was easy to pull and the Tundra settled into a comfortable pace at 65-70 mph, a few stretches at 75 when the conditions were level and smooth.
    That's what I did to my Tundra today.
    bmf4069, NUDRAT, FrenchToasty and 5 others like this.
  8. Oct 7, 2023 at 11:17 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Dam, If I wasn't so far away I would consider it. Those are in great shape!
  9. Oct 8, 2023 at 6:44 AM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Thanks appreciate it. Excited to build up this truck
    -Woodsman-[QUOTED] likes this.
  10. Oct 8, 2023 at 7:39 AM
    shifty` Inside his chest they found ten thousand pencils
    Whereabouts are you? We have a member running from here to TX in the near future.
  11. Oct 8, 2023 at 7:39 AM
    You’ll likely need a new door. The bed could be reskinned on that side, or body repair could be attempted. The hours spent on body repair end up negating the cost of reskinning.
  12. Oct 8, 2023 at 7:42 AM
    Honestly once you add in paint to go with the reskin, it’s almost more logical just to buy a matching door shell from a salvage yard and DIY swap. I’ve never seen a reskin with paint less than $500 and that was Maaco. And chances of matching paint at that age/fade will be far better with a truck of same year with factory paint than a shop. You’ll always be able to tell it’s repainted.
    KTM_AJ421 likes this.
  13. Oct 8, 2023 at 7:47 AM
    Yeah, replace the door. But reskin the bed. Or if you’re lucky and the donor vehicle has a good bed and door, swap them both. Most body shops will reskin that bedside and replace or reskin the door assembly. And then body work in that back cab corner. Respray them all and blend adjacent panels.
    shifty` likes this.
  14. Oct 8, 2023 at 8:13 AM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I think I’m just going to touch it up and put some clear over to keep it from rusting it’s used to haul dirt bikes so I don’t care if it’s not perfect
    dbittle, NUDRAT and shifty`[QUOTED] like this.
  15. Oct 8, 2023 at 9:19 AM
    artsr2002
    'Yonder
    Well I went ahead and put the dash back together for now. Waiting on the switch and wires that assasin sent me. This way I'll be able to use the truck if I need to. One thing I noticed just now is that I have 2 wires in my top clockspring connector that don't appear to have corresponding wires coming out of the bottom connector. I wonder if that has something to do with how weird my buttons are functioning.
    The top yellow wire and green wire don't have corresponding wires coming out of the bottom connector.
    In the bottom pic my wire colors will probably not match anyone else except the right three wires in the lower spots. Those top 3 and the red wire are the 4 wires that were included with my Chinesium buttons so I used them to make the 4 additional wire connections that my bottom plug was missing originally.
  16. Oct 8, 2023 at 2:14 PM
  17. Oct 8, 2023 at 9:53 PM
    daveeasa
    David
    shifty`[QUOTED] likes this.
  18. Oct 9, 2023 at 4:06 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I'm up in the bitch mitten Shifty (lower MI)
    shifty`[QUOTED] and DJenerated like this.
  19. Oct 9, 2023 at 11:50 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Silver truck is out of the body shop. Looks great!
    Dad is going to sell it soon. Would anyone here want it?
    bmf4069 and DJenerated like this.
  20. Oct 9, 2023 at 11:54 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Buy a trailer, drag it out to sandy eggo & throw a cali pricetag on it. That'll more than pay for the trailer & gas.
  21. Oct 9, 2023 at 3:31 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I feel like there aren't a lot of words in this post but there is definitely a lot to unpack here.
    What all was done at the body shop? Gonna post up some pics?
    He's gonna sell it huh, seems like it's been super reliable and dependable for all these years and now it's just up on the chopping block? I remember a few years ago saying that you'd never let that thing go.
  22. Oct 9, 2023 at 3:53 PM
    DJenerated
    Dija
    The Lone Star State
    For real. I think Noah should take it for a second truck.
    txagg likes this.
  23. Oct 9, 2023 at 3:54 PM
    DJenerated
    Dija
    The Lone Star State
    Today I filled up both my first gens. Gas was only $2.94 a gallon.
  24. Oct 9, 2023 at 3:57 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Definitely more to unpack than the 22 words in that post.
    I don't have pics since it went in, but basically a front end refresh due to deer damage. I only saw it for a few seconds as I was skootching through town. I'll post em when I have em.
    He wants something easier to get in/out of for his worn out body, and easier on gas. It has been reliable, and has never missed a beat except when I did those goofy projectors for my tiny alternator. That was my fault. Not the trucks.
    A few years ago seems like such a long time ago, but it wasn't. I don't have the means to keep it, nor the need. I've got Crackie. He's got more :muscleflexing:, and more capabilities regardless.
    He, and I hate it, but it's where we are at. Honestly, I've pushed him enough to selling it to someone here if possible, so I can buy it back later, maybe. Like @daveeasa situation maybe. Dunno.
    I've made my peace with a lot of things lately, Nick. I've had a good run with it, and it's still got plenty more to choogle on for another 360k miles. I'm at peace with it. I'm not conflicted about it like I was with listing Crackie.
  25. Oct 9, 2023 at 4:16 PM
    DJenerated
    Dija
    The Lone Star State
    Is it manual? Rust free? Leak free? Do you know what he's planning on asking for it yet? 2wd or 4wd?
    Whoever buys it better slap on a brand new Magnuson TVS1320 supercharger though and report back, for science of course.
  26. Oct 9, 2023 at 4:45 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Just got done changing front differential, transfer case and rear differential fluids. Added some torque specs that I couldn't find to torque sticky. Thanks @shifty`. I have the PDF of FSM but it's a pita to search I don't know if it's me or the computer or both...
    oscardog86, bmf4069, shifty` and 3 others like this.
  27. Oct 9, 2023 at 5:28 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  28. Oct 9, 2023 at 5:30 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    bmf4069, assassin10000 and DJenerated like this.
  29. Oct 9, 2023 at 5:35 PM
    -Woodsman-
    NC
  30. Oct 9, 2023 at 5:38 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    This should be their first thought when purchasing it.
