  1. Mar 15, 2019 at 7:14 PM
    #5011
    Professional Hand Model
    Hand Protectors
    Any chance you can post up some of those requested top secret screen grabs from the stealership files for 2002 v8 4wd transmission service?
  2. Mar 15, 2019 at 7:29 PM
    #5012
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm having the same problem. Noticed it today while washing the truck.
    Jerry311SD[QUOTED] likes this.
  3. Mar 15, 2019 at 7:59 PM
    #5013
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Jerry311SD I believe mine leaks in the same spot but its has only leaked once that I know of. Thanks for the pics, now I know where to look.
    Jerry311SD likes this.
  4. Mar 15, 2019 at 8:11 PM
    #5014
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Huh? You should have a dipstick
  5. Mar 15, 2019 at 9:15 PM
    #5015
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Super easy to do. Try it out
  6. Mar 16, 2019 at 4:48 AM
    #5016
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Started the recommended steps for oxidized single stage paint yesterday.
    Washed-->claybar-->applied Meguiar's #7 and let soak over night. Supposedly this will awaken the oils in the paint. In a little bit I'll remove that coat and inspect. 2nd coat may be necessary. Then I'll do a coat of polish then end with wax. Pictures to come.
    What's wild is when testing the #7 on one panel it actually changed the shade of my paint. Hard to explain over the internet.
    Wife's Rav4 will follow suit.
  7. Mar 16, 2019 at 6:59 AM
    #5017
    Hand Protectors
    That pic helps. The other threads I’ve read show to caulk all the screw clips and it didn’t make sense when it looked like they all drained into a channel when I had the cowl off. Didn’t even look or stick my hand around to test that end one to see if it emptied into the channel.
    Next time I pull this cowl off I’ll be painting it and doing the caulk job on that end one.
  8. Mar 16, 2019 at 7:03 AM
    #5018
    Hand Protectors
    Sounds like self torture. It should turn out nice. Meguiars has great products. Just put some of their Synthetic Wax on the 02’.
  9. Mar 16, 2019 at 7:06 AM
    #5019
    Hand Protectors
    Yes. It does. I’ll be doing a drain and fill maybe today. Thanks for the input.
  10. Mar 16, 2019 at 7:47 AM
    #5020
    empty_lord
    05 rollover special
    If you want the info on doning the filter I think that’s in the manual. But they don’t say anything about flushing the fluid. Honestly drain and fill is perfectly fine to do. I do it on all my cars. Even the sealed trans cars
  11. Mar 16, 2019 at 8:15 AM
    #5021
    Outbound
    Aaron
    Northern Alberta
    Nice! Keep us posted. My white paint has an orange tint, especially on the hood, from iron dust. I'm planning to get that fixed up and was going to use IronX.
    I need to figure out if there are power tools to do this. Clay bar and polishing by hand is something i dont think i have the patience for.
    FirstGenVol[QUOTED] likes this.
  12. Mar 16, 2019 at 8:41 AM
    #5022
    Hand Protectors
    I was looking to go next level and drop the pan and put in a new filter. Maybe tighten some bolts on the assy while it was open. Looking for something I can break, basically.
    Everything works fine and she shifts smoothly as the trans fluid has been regularly changed about every 10-15k miles since hitting 124k on the OD. Sitting at 162k now.
    I’ll stick with whats working and just drain and fill. This is the first time I’ll be doing this, due to pro shops having done all the services prior. Going with Valvoline DEXIII (non synthetic) $14 for the gallon.
  13. Mar 16, 2019 at 8:44 AM
    #5023
    Hand Protectors
    Unfortunately, great patience is needed on any type of finish work. The clay bar is the real deal start to a great finish, but there is no easy short cut for its use.
    Darkness likes this.
  14. Mar 16, 2019 at 10:01 AM
    #5024
    Outbound
    Aaron
    Northern Alberta
    Boo hiss. $200 canuckistan pesos to whoever comes and restores my paint for me.
  15. Mar 16, 2019 at 11:21 AM
    #5025
    Hand Protectors
    Transmission Fluid Change. Drain and fill with DEXIII. Cold drain and fill. Total cost less than $14. One hour total time including drive time to dispose of old fluid.
  16. Mar 16, 2019 at 11:49 AM
    #5026
    Hand Protectors
    Found this resource for transmissions. Will need to register to get into some of those links. Circled are the ones I want to obtain.
    speedtre, Darkness and TheBeast like this.
  17. Mar 16, 2019 at 12:31 PM
    #5027
    Casper421
    In the woods
    06 DC
  18. Mar 16, 2019 at 12:53 PM
    #5028
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You trying to make it slower? o_O
    Went outside and decided a few things.
    1) Not gonna drink this Suntory neat anymore.
    2) Its a great day to take a nice drive, I think I'll do that.
    3) I should check my mystery tire pressure.
    Got put the compressor and the gauge and checked all 4 corners. My suspicion was that the tire guys went with factory specs of 26/29 psi. To my surprise they seem to have gone 40 psi on 3 tires and 36 psi on the 4th.
    I looked at the foot prints and decided I will start at 40/42 and after my nice drive I will do the chalk test to see where that puts me.
    I'm also thinking I will grab a few bottles of diff juice so I can have a fluidpalooza night. Change my diff fluid, change the Honda diff fluid and Honda oil. Tomorrow I'm taking the throttle body off the Honda to clean the IACV and see if that fixes the idle.
  19. Mar 16, 2019 at 1:09 PM
    #5029
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Since I can't seem to find any xgauge that actually reads the ATF temp on my 5 speed auto, I'm thinking about buying a Bluetooth OBD2 adapter and the Torque app. Anyone here have expert going this route?
  20. Mar 16, 2019 at 1:28 PM
    #5030
    Hand Protectors
    Anatomy of an oil cap. Pics below with descriptions. Not pictured is the oil cap prior to all the reinvestment work put back into the 02’. The cap had some oil sludge build up (not snot).
    Pic: Oil cap after doing an oil clean purge with Liqui-Molly and full conversion to Mobil1 Full Synthetic. Pictured is the cap with 1,500 miles. From research the snot looking residue indicates some moisture in the oil finding its way up to the cap. Never saw it before. I wiped it off and its not appeared since.
    Pic: Oil cap has a nice shiney appearance. Very clean and no snot. Cap with 2.5k miles after the snot.
    Conclusion: The dynamics on this engine have changed for the best. New PCV Valve allowing for better engine airflow and Full Synthetic Oil detergents cleaning the sludge. I’ll be monitoring, as always... the transmission, oil, and rad levels for problems.
    speedtre, Filthyphil and NUDRAT like this.
  21. Mar 16, 2019 at 1:30 PM
    #5031
    Hand Protectors
    I think you may have to spend some big$$$ to get you what you want. How much is this bluetooth deal?
  22. Mar 16, 2019 at 1:36 PM
    #5032
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    Prepping for Tundras to Sedona..
  23. Mar 16, 2019 at 1:52 PM
    #5033
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Just drove the back roads to Thousand Oaks. Lots of hills and curves through the nicest greenery thanks to the rain we had. Left the radio off and windows down to enjoy the sounds of my truck.
    bmf4069, Jerry311SD, Sunnier and 2 others like this.
  24. Mar 16, 2019 at 2:15 PM
    #5034
    carpartcountry
    carpartcountry New Member
    2005 Toyota Tundra TRD
    3 inch life, tinted windows,
    Had this exact same problem with my 02 tundra. The passenger doors were faded but everything else looked great. Same color too
  25. Mar 16, 2019 at 2:40 PM
    #5035
    because_wumbo-truck
    Jon
    Houston, Texas
    Shit Amazon has em cheap AF. Starting price is like 10 bucks and it's compatable with my Android phone. The app is 5 bucks
  26. Mar 16, 2019 at 2:48 PM
    #5036
    Hand Protectors
    Whoa!!! What are you waiting for?
    Did I read that app is glitchy? False readings, updates $, etc.
  27. Mar 16, 2019 at 2:55 PM
    #5037
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The thing I wonder about is can they read the ATF if the Scangauge can't?
    because_wumbo-truck likes this.
  28. Mar 16, 2019 at 3:17 PM
    #5038
    Hand Protectors
    Hence me saying big $$$ to get what he wants. The $3-4k scanners can do it from my research. If he buys the cheapy app and it works, thats awesome.
  29. Mar 16, 2019 at 4:30 PM
    #5039
    because_wumbo-truck
    Jon
    Houston, Texas
    This is what I'm wondering... But I think it comes down to actively updating the app vs finding the programming an xgauge. If it works, it's a game changer at the price and ease of use.
  30. Mar 16, 2019 at 4:31 PM
    #5040
    because_wumbo-truck
    Jon
    Houston, Texas
    Never heard of such a scanner lol that's crazy money
