  1. Jun 1, 2023 at 7:53 PM
    If the pizza joint is La Prima, our friends ordered some pies for us last night to eat at their place. Was solid. Tomorrow hitting Hennessy lake for a 6mi loop, not sure what else is going on. Glass beach is on the list, and where we're staying in Manchester has more than 2-3 miles of private beach, apparently. Drive-thru tree is on the list. I love Old Rasputin, so North Coast was a must-go. I'll check out Ave of Giants. Appreciate the suggestions, we always leave a few hours of flex time here or there for extras.
    Voss, JasonC., bmf4069 and 3 others like this.
  2. Jun 1, 2023 at 9:19 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Just came back from Ave of the Giants a month ago. It was incredible and definitely worth it. Had this place all to myself. Hidden little spot that technically was day use only, but no one bothered me at all. Or even showed up
    IMG_20230417_174705620_HDR~2.jpg IMG_20230417_174511978_HDR.jpg IMG_20230417_174338975_HDR.jpg IMG_20230417_181545889.jpg
    Hi06silver, Voss, JasonC. and 19 others like this.
  3. Jun 1, 2023 at 10:42 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Awesome! So much so, that it almost looks fake.
    #enchantedforest
  4. Jun 2, 2023 at 6:58 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Going down this rabbit hole currently. I will probably end up buying a kit for both my vehicles. While I was at T2S, a mouse made itself home in the Corolla's cabin filter. I took apart most of the Corolla's dash and sanitized the vents and everything the best I could, fished a Clorox wipe through the ducts with bailing wire. Really only want to deal with this once, so I'm doing everything I can to do it "right". Toyota has a good video showing the process you typed out:
    https://www.youtube.com/watch?v=AR6yF2NzRBc
    Voss, KingSequioa007, bmf4069 and 3 others like this.
  5. Jun 3, 2023 at 2:06 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Decided to believe the local weather report stating no rain this afternoon and sure enough it rained while I was starting to bleed my rear brakes. Muscled through the two rears and proportioning valve before it got too heavy because that’s how I roll. :rain::muscleflexing:
    (Actually I didn’t want to get caught and pay the $100 HOA fine doing it at home)
    Speedi-bleed system worked but it was anything but speedy. Only dropped a couple psi on the right rear but not the left rear (weird).
    Now need to wait for a break in the rain or do the fronts another day. Brakes are now much tighter. Looks like I had a lot of air in the rear brakes I guess. Now I don’t get a pronounced vibration in the front rotors when I brake at highway speeds.
    Voss, bmf4069, NUDRAT and 4 others like this.
  6. Jun 3, 2023 at 3:28 PM
    des2mtn
    Shady Grove
    Tonto cover
    Swapped in a reman CV since my old one was clicking and the outer joint has a little play.
    Oil pan skid has been doing its job.
    oscardog86, Voss, txagg and 11 others like this.
  7. Jun 3, 2023 at 3:52 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Do you remove the 4 LBJ bolts to swing the spindle out, or remove the castle nut and break the joint?
  8. Jun 3, 2023 at 3:56 PM
    des2mtn
    Shady Grove
    Tonto cover
    I do it it by removing the four LBJ bolts and swinging the spindle.
    oscardog86, Voss, Casper421 and 2 others like this.
  9. Jun 3, 2023 at 4:03 PM
    w666
    Maryland
    That then provokes a bonus question...do you reuse the bolts?
  10. Jun 3, 2023 at 4:09 PM
    des2mtn
    Shady Grove
    Tonto cover
    Figured that was coming, yes :) They have 30,000 miles and this is the third time this set will be taken off and put back on. I will apply the Harbor Freight medium strength thread locker again.
    Before these, I did reuse my originals a few times. If I had the smaller bolts, I would probably replace them every time.
    oscardog86, Voss, shifty` and 2 others like this.
  11. Jun 3, 2023 at 4:45 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    My weather Dominatrix said we'd get rain today & I got none. Cut down 4 trees, cleaned it all up. Thought about cleaning the truck, but nah. So basically I ignored my truck today.
  12. Jun 3, 2023 at 5:08 PM
    Jack McCarthy
    Bill
    North of Boston
    Yeah, it hasn’t let up around here yet. It’s just a miserable dull and dreary day with rain continually falling as a mist and fluctuating in intensity.
  13. Jun 3, 2023 at 7:17 PM
    vst
    vst New Member
    Scott
    East TN
    2005 DC 4wd
    Where do you get the reman axles from local dealer?
  14. Jun 3, 2023 at 7:24 PM
    des2mtn
    Shady Grove
    Tonto cover
    From a local Toyota dealer - part number 43430-0C010-84. There's a few other threads on here where I've discussed these remans before.
    oscardog86, Voss, vst[QUOTED] and 3 others like this.
  15. Jun 4, 2023 at 1:54 PM
    Jack McCarthy
    Bill
    North of Boston
    So how do people here get access to the bolts with an impact to remove your wheel axle from the rear axle housing for changing wheel bearings?
    Looks like you need to remove the rear brake lines, the parking bell cranks and the U-bolts/plates holding the rear axle to the leaf springs to get enough clearance.
    Or is everyone here just using a long ratcheting wrench?
    oscardog86 and Tripleconpanna like this.
  16. Jun 4, 2023 at 2:03 PM
    des2mtn
    Shady Grove
    Tonto cover
    Socket and extensions/ ratcheting wrench works. U-bolts don't need to be touched, but if you're pulling the rear axle shafts, the rear brake lines gotta come off. There's a little clip and pin on the bell crank for the e-brake line that comes out easy.
  17. Jun 4, 2023 at 3:29 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    Lookout Mtn Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    Just a quick wash and drive to keep her running. Tucked away afterward; couple of hundred miles under 78k..
    (Getting gravel in a couple of months for the pole barn)
    oscardog86, Voss, txagg and 9 others like this.
  18. Jun 4, 2023 at 4:27 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    consider putting a sheet of plastic under the truck. moisture comes up from under daily, gravel or not. It's amazing how fast a vehicle parked on a dirt barn floor will rust out underneath while looking cherry topside.
    I'd lay a long pole under the center of the truck, lay out a sheet of plastic & park on the plastic. The pole gives slope to dissipate any moisture on the plastic, encourages it to drain off. Plastic only slightly wider/longer than the truck.
    Truck is looking beautiful.
  19. Jun 4, 2023 at 4:35 PM
    abcinv
    Tommy
    Lookout Mtn Georgia
    I have a tarp I plan to put under the truck, being used at the moment though.
    Good advise, thanks
    NUDRAT likes this.
  20. Jun 4, 2023 at 6:27 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    You've really got to stop doing actual work on your truck... you're making the rest of us look bad :anonymous:
  21. Jun 4, 2023 at 6:33 PM
    Jack McCarthy
    Bill
    North of Boston
    So only changing oil and car washes for you? I miss those days. Hopefully soon I’ll have a new truck.
  22. Jun 4, 2023 at 6:43 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Y'all wash y'all's trucks? Mine got a rain bath last night.
    Voss, NUDRAT, bmf4069 and 1 other person like this.
  23. Jun 4, 2023 at 6:44 PM
    Jack McCarthy
    Bill
    North of Boston
    I sort of gave up somewhere between year 5 and year 10 unless it’s covered in yellow pollen. I hate that stuff.
    The only other time is during the winter to get the salt off.
  24. Jun 4, 2023 at 8:53 PM
    Tripleconpanna
    You Sir, clearly missed my epic Gen2 repair post...:rofl:
    14260
    Just kidding... but on a serious note though, I was just being a little jealous of the fact that so many of you on this side of the forum handle your own major repairs. I don't have the space or mechanical skill/knowledge to have done this repair on my own (The tranny one; I think I could've handled the lower oil pan :thumbsup:).
  25. Jun 5, 2023 at 7:17 AM
    daveeasa
    David
    Pretty sure I own the title of least qualified mechanic here. Line starts at my ass.
    oscardog86, Voss, bmf4069 and 2 others like this.
  26. Jun 5, 2023 at 9:06 AM
    Lundy
    Lundy New Member
    San Diego
    2004 Dual Cab V8, Automatic, 4x4, SR5 w/tow pkg
    Took off the body side moulding, patched holes, changed color.
    1genjunky, oscardog86, Voss and 15 others like this.
  27. Jun 5, 2023 at 9:19 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I was about to ask how in the hell you got such a clean finish painting outside like that, then quickly realized you wrapped the sumbitch. very nice. Color upgrade for sure
    oscardog86, Voss, JODOOR and 2 others like this.
  28. Jun 5, 2023 at 11:59 AM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    swapped my corner bulbs for some yellow leds, first thing ive done on this thing in awhile haha
  29. Jun 5, 2023 at 12:06 PM
    Starting to look like your avatar
    Voss, shifty`, txagg and 6 others like this.
  30. Jun 5, 2023 at 5:13 PM
    DJenerated
    Dija
    The Lone Star State
    Shaved door handles as well? Jk
    that would be gangster AF though.
    oscardog86, NUDRAT and Tripleconpanna like this.
