  1. Mar 7, 2019 at 11:24 AM
    #4831
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Looks awesome. It's annoying that there seems to be so many more aftermarket light options for the DC's. I was confused when I saw this pics because I thought your truck was light brown metallic based on the picture I quoted earlier. I didn't realize it was silver. Still looks great.
  2. Mar 7, 2019 at 11:26 AM
    #4832
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Plasti dip? I'm not having great luck with the plasti dip I put on last month. It stuck to my wheels and mirrors but it's already peeling off my side steps.
  3. Mar 7, 2019 at 11:35 AM
    #4833
    WutsaZJ
    WutsaZJ New Member
    2006 Double Cab 4x4 trd offroad
    5100s, 285 wildpeaks, snugtop,rear bags, and a bunch of plastiderp
    They're just some regular ass Ebay aftermarket units that I did the mini h1 projector retrofit to. Haha pretty sure Ebay has the earlier model 1st gen headlights as well. Same process for the retro, but they have metal clips on the housing to remove before baking.
  4. Mar 7, 2019 at 11:36 AM
    #4834
    speedtre
    speedtre New Member
    Inland Northwest
    Sunroof and leather were options on SR5s...at least they were for 2005. My old 2005 DC SR5 had both leather seats and a sunroof.
    FirstGenVol[QUOTED] likes this.
  5. Mar 7, 2019 at 11:52 AM
    #4835
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I've never used it. I've always primed and painted chrome and plastic on my tacos. Figured I'd give it a shot
  6. Mar 7, 2019 at 11:53 AM
    #4836
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Rheywood456 @Darkness @Casper421 @anyone else that goes off-road I may have forgotten. I already got Jon's blessing but wanted to run it by you guys as well.
    A few questions:
    1)looking for honest feedback on the Toytech Boss kit. I think this may be the best package for my needs but I value any feedback you may have.
    2)Is there any harm in going with the 700 lb coils even if I'm not sure that I will get a custom bumper? I figured I'd rather have them just in case rather than have to pull them off later to swap.
    3) The add-a-leaf with this kit doesn't look very robust. Am I really going to see much benefit from that?
    3) I considered saving a little money by going with OME but the coilovers are not adjustable.
  7. Mar 7, 2019 at 11:54 AM
    #4837
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I actually think it will hold up nicely on your grill. Please post some pics once you remove all the protective layers.
  8. Mar 7, 2019 at 12:26 PM
    #4838
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I did the Rustoleum peel coat on the chrome bumper strip almost 2 years ago and there's nothing more than a couple rock chips. That's worth no more prep than wiping down with acetone.
  9. Mar 7, 2019 at 12:31 PM
    #4839
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @FirstGenVol I ran a pair of Toytec long ago and they worked well. They have changed quite a bit since then, back when I ran them it was really a non-servicable Bilstein with a threaded collar and 600lb linear coils. These days I am not sure where the shock comes from or if it is serviceable.
    That said...
    1) for some minor off roading like driving on fire roads or something to that effect, they should be alright, assuming you are aware of the increased wear, service needs, and funny arm angles that come with lifting the front end.
    2) 650 and 700 are pretty close. 650 is fairly stiff compared to stock. If it were me I would only run 700 if I definitely plan on a heavy bumper, or if I had a double cab.
    3) the add a leaf is just to give a little lift. It has always baffled me how many guys want to level their truck but bother lifting the rear. To level a truck you only need to raise the front about 2". If its about adding bigger tires, a 35 will fit in the back at stock height no problem, most guys only run a 33.
    4) OME makes pretty good stuff too. A lot of guys went with them years ago, they don't seem as popular these days. Adjustability doesn't matter much, as long as the height matches what is advertised. I suppose it's nice to have if you decide at some point to change stance.
    TUNDRAIN520 and FirstGenVol like this.
  10. Mar 7, 2019 at 12:36 PM
    #4840
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So even leveling with coilovers does weird things to the front end? What way do you have to do it to keep everything happy?
    FirstGenVol and Darkness like this.
  11. Mar 7, 2019 at 12:37 PM
    #4841
    Professional Hand Model
    Hand Protectors
    IIRC, its a tension fit.
    speedtre and Darkness like this.
  12. Mar 7, 2019 at 12:40 PM
    #4842
    Hand Protectors
    Towed a bit the past few days for 10.5 mpg city.
    Road trip today yielded 17 mpg highway with 300lbs weight in truck.
    TUNDRAIN520 and NUDRAT like this.
  13. Mar 7, 2019 at 12:42 PM
    #4843
    Hand Protectors
    They sell that shift washer for $25.
  14. Mar 7, 2019 at 12:44 PM
    #4844
    because_wumbo-truck
    Jon
    Houston, Texas
    UCAs help
  15. Mar 7, 2019 at 12:47 PM
    #4845
    because_wumbo-truck
    Jon
    Houston, Texas
    mtntop, Brown Bear, the red and 5 others like this.
  16. Mar 7, 2019 at 12:48 PM
    #4846
    Festerw
    Festerw New Member
    04 Tundra DC
    That looks awesome.
  17. Mar 7, 2019 at 1:13 PM
    #4847
    Hand Protectors
    In addition to the pic, go under and grease the other end of the gear cable where it connects to the transmission shift arm at the side of the transmission. Helps smooth out the shifts for sure.
  18. Mar 7, 2019 at 1:19 PM
    #4848
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Looks great. Did you just get those yellow fogs or have you had those? I could have sworn we just discussed that last week and PHM did his amateur photoshop to your truck.
  19. Mar 7, 2019 at 1:20 PM
    #4849
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm aware of the potential strain on the CV's. Can you elaborate on the rest?
    Do you recommend I use the diff drop? I've seen conflicting opinions on this.
  20. Mar 7, 2019 at 1:35 PM
    #4850
    Mike Tread lightly.
    south carolina
    I have the scan gauge2. I have tried a few codes said it might work and didn't. 2003 here.. I believe 2005 and up you can they change to the new bus system so you could see it from scangauge
    lsaami[QUOTED] and FirstGenVol like this.
  21. Mar 7, 2019 at 5:06 PM
    #4851
    Casper421
    In the woods
    06 DC
    1. @Toytec Lifts makes a great product at an aggressive price. Definitely can’t go wrong with their boss system. But, if you’re anything like me, you’ll eventually want bigger and better. Buy once, cry once.
    2. The ride with no weight and 700lb coils is pretty stiff compared to stock. Once I mounted 120lb of skid plates and 240lb of sliders, the ride improved greatly and is now a comfortable sporty drive. I say stick with 650’s.
    3. Depends on the condition of your oem springs. If they’re worn and tired, you won’t get as much lift. A 3 pack aal might be better option then.
    4. Can’t go wrong with OME. Very popular company with the Overland community. Tested and proven everywhere on earth.
    Just a heads up, once you move out West you’ll want some go fast parts, which ain’t cheap. Give the boss kit a try and upgrade in a few years if your needs change.
  22. Mar 7, 2019 at 6:07 PM
    #4852
    because_wumbo-truck
    Jon
    Houston, Texas
    I just added the yellow lamin-x, but I already had these Hella bulbs in the fogs
    Except you know, the right bulb type. 9006 iirc
  23. Mar 7, 2019 at 6:09 PM
    #4853
    because_wumbo-truck
    Jon
    Houston, Texas
    I got the trans codes to work on my 03 taco. I still need to attempt it on my tundra.
  24. Mar 7, 2019 at 6:12 PM
    #4854
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’m eyeballing the ome kit.
  25. Mar 7, 2019 at 6:13 PM
    #4855
    empty_lord
    05 rollover special
    I plan on running the 9012 bulbs in my fogs.. overkill? Yes. But I like em in my corolla
  26. Mar 7, 2019 at 6:19 PM
    #4856
    because_wumbo-truck
    Jon
    Houston, Texas
    Is that the one we're you have to upgrade the wiring and shit?
  27. Mar 7, 2019 at 6:20 PM
    #4857
    because_wumbo-truck
    Jon
    Houston, Texas
    Also I disabled my DTRLs today. Super easy just unplug a plug by the battery. Now I just gotta get around to the fog light anytime mod.
    Jerry311SD and bmf4069 like this.
  28. Mar 7, 2019 at 7:30 PM
    #4858
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    I want the fog lights any time mod :drool:
    because_wumbo-truck likes this.
  29. Mar 7, 2019 at 7:48 PM
    #4859
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I wouldn't mind that too. It would save life on my HIDs for the rainy season.
    Jerry311SD likes this.
  30. Mar 7, 2019 at 10:01 PM
    #4860
    sakana
    sakana New Member
    2002 Tundra AC Limited 4X4
    MT Classic II, Bilstein 5100, 4.88's, BAMuffler catback, 250cc 12-hole injectors, Powerstop Z36 brake kit, Hellwig helper spring and rear swaybar
    Got my Hellwig Rear Swaybar installed today.
    She's going in on Monday for the 4.88 gears, 250cc 12 hole injectors, and BAMufflers catback exhaust install.
